Dash \ Kick Panel Question
Discussion in 'Audio & Video' started by mix123, Feb 20, 2009.
  1. Feb 20, 2009 at 7:28 PM
    mix123
    mix123 [OP] Member
    Canada
    09 SR5
    I am going to be installing my Sirius receiver tomorrow in my '09 taco. I just received the adapter and cable to use the existing factory antenna. I haven't tried removing any panels yet or anything, I thought I would just ask first. The drivers side lower kick panel that I need to take off to hook up the antenna cable to the port...how does it come off? Does it just pop off?
    I am also going to be wiring into the cig/aux for power. How do I get the panel off that those are mounted in to get to the power and ground wires behind the panel?
    Any help would be appreciated to make everything go smoothly.
  2. Feb 20, 2009 at 7:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    pop up the black foot rest, pop up the door jam trim, remove the black screw on cap thats under the foot rest, then the panel will come right out
  3. Feb 20, 2009 at 7:47 PM
    mix123
    mix123 [OP] Member
    Canada
    09 SR5
    Thanks...And now for the other panel with the aux/cig or how to get to those wires
  4. Feb 20, 2009 at 7:53 PM
    The_Hodge
    SC
    now that one i have no idea...lol. havent been that far into it yet
  5. Feb 20, 2009 at 8:32 PM
    mix123
    mix123 [OP] Member
    Canada
    09 SR5
    I think I will just tap into fuse box instead of taking all that stuff apart
  6. Feb 21, 2009 at 10:22 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I tried tapping into the cig lines when doing my GPS. It involves taking apart most of the dash, but I managed to take apart the bare minimum.
    Read here
