Dash lights on, brake pedal no vacuum and constant beeping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smoseley6, Jun 10, 2020.
  1. Jun 10, 2020 at 7:51 PM
    Smoseley6
    Smoseley6 [OP] New Member
    05 Tacoma 4.0 access cab
    trd headers, y pipe, true cold air intake, trd tune
    05 Tacoma 4.0 access cab.
    After filling up, all my dash light came on, brake pedal feel was like having no vacuum, constant beeping. Scanned for codes and no codes can be read. Tried clearing codes, nothing happens. Performed overall check on engine bay, speed sensors. All looks good. Checked fuses, all.good.
    Truck has 228k.
  2. Jun 10, 2020 at 10:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Jun 10, 2020 at 11:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I assume you meant filled with gasoline.
    Does it start and run at all?
    Brake has no vacuum. If the engine isn't running and the vacuum vented from booster from pressing the pedal it would be normal.
    What are "all the dash lights"?
    How did you check the fuses? Meter or Visual. Use a meter, you can't go by sight.
    Hard to think there are no codes with all that going on.
    IMO you have a blown fuse probably. Get a meter or test light and verify.
    TnShooter likes this.
  4. Jun 14, 2020 at 8:13 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Another one post wonder!
    I hate these!
