Dash Rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by S-Runner '01, Nov 30, 2010.
  1. Nov 30, 2010 at 12:39 PM
    S-Runner '01
    S-Runner '01 [OP] Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    I've finally discovered the reason for a rattle coming from the right side of my dash panel. Now I need to find a way to fix the problem.
    If I hold my hand on the passenger side airbag cover and press down on it a couple pounds the rattle is completely eliminated.
    Can someone please point me to where I might find instructions to tighten up the airbag cover. I looked in my Haynes Manual but am unable to find any reference to the airbag installation.
    Any help will be appreciated.
    TIA
    jj
  2. Nov 30, 2010 at 1:23 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    I stuffed a 1/4'' diameter wooden dowel stick (about 12" long) wrapped in rubber bands in between the windshield and the dash. Works like a charm.
  3. Nov 30, 2010 at 1:25 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  4. Nov 30, 2010 at 4:54 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Turn the radio up? :)
  5. Nov 30, 2010 at 5:01 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    subscribed
  6. Nov 30, 2010 at 5:02 PM
    ajreyno1994
    ajreyno1994 Active Member
    00 tacoma sr5
    ion alloy wheels, toyo 31's, k&n air filter, chrome tube running boards
    I have the exact same problem. Every one and a while it will just start rattling, but if you push down on it a little it quits. I'd love to know how to fix it!
  7. Nov 30, 2010 at 5:06 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Mine doesnt rattle? :confused:
  8. Nov 30, 2010 at 5:25 PM
    Wayner275
    Wayner275 Member Me
    Regina, Saskatchewan
    09 Tacoma
    Step bars, Weathertech mats, Sirius sat., Fold-a-Cover G4 Elite, Pop-n-Lock (ditched the PopnLock and went with the Dyno Lock, RedLine hood struts, Cloud-rider Grill insert,
    I had the same problem. I removed the glove compartment along with the roof of the compartment. This gives you access to the airbag. I stuffed some 1/2" by 3/4" closed cell weather stripping foam between the perimeter of the airbag in the space between the metal framework that holds the airbag and the airbag.
    There is also an electrical component that is mounted on a metal bracket on the inside of the dash (the component is about the size of a cigarette pack). Experiment with the foam weatherstripping to make this unit fit tight in the bracket.
    The weatherstripping works well because it has an adhesive strip on one side and it stays secure when you apply it.
    My dash rattles were more pronounced when my vehicle was cold and got marginally better when the interior warmed up. I am happy to say that they are now totally gone.
    Sorry, don't have pics to explain as I am away on business right now. All I can say is that it is super easy to remove the glove compartment to get at these problems rattles. Don't forget to take care removing the glove compartment shock by squeezing the split post together so you can slide the shock off of the mounting post at the bottom end of the shock.
    Good lucK. I can assure you that you will be happy with the results once these F#%$ing rattles are gone!
  9. Nov 30, 2010 at 5:28 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    usually my solution
  10. Dec 1, 2010 at 11:52 AM
    javadoody
    javadoody Active Member
    mine was driving me nuts so i had my wife stick card stock between the dash, and in this case, the a-pillar. it's stopped the rattle coming from the airbag cover. we'll see for how long. nice to know the true culprit though. if i get time next spring i'll tear it apart.
  11. Dec 2, 2010 at 1:43 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Isnt there a recall on this?
  12. Dec 2, 2010 at 6:20 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I like radios...
  13. Dec 29, 2010 at 12:11 PM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    thanks!
    nice to know I'm not the only one with the rattle! I had the exact same issue and when it's cold it's worse...after I run the defrost, it quiets down. Now I know that it's a fixable problem.
  14. Dec 29, 2010 at 1:34 PM
    thatcarolinaboy
    thatcarolinaboy Well-Known Member
    Toby
    North Carolina
    19 TRD PRO
    i too have the rattle in my 02, my 01 did the same thing.
  15. Dec 31, 2010 at 8:23 PM
    pulpwood
    pulpwood Member
    pulpwood
    Arkansas
    02 V6 auto
    my 02 rattles too. thought it was a crack in the dash
  16. Dec 31, 2010 at 11:18 PM
    YouNext
    YouNext General Calamari
    San Diego
    K&N FIPK, Gibson Exhaust, Doug Thorley Headers, URD pulley, Stoptech Cryo-treated Slotted Rotors, Deaver J59, Bilstein 5150s, Total Chaos LT (w/Spindle & Tower Gussets), Icon LT C/Os.
    Yes, if you wanted to take the dealer option, altho i'm pretty sure their procedure involves taking apart the dash.
    ^^this seems like a more logical option. Especially since most on the forums look for DIYs. :)
  17. Nov 7, 2012 at 6:55 PM
    PhoenixTaco
    PhoenixTaco Well-Known Member
    Thomas
    Phoenix
    02 PreRunner
    Toytec 3" Ulitmate Lift, Led lights, Tinted Tail Lights, 3rd Brake lights tinted, Clear Corners. Two 8" Kicker Cvt's, Alpine Amp 800 watts, Kenwood Deck, 4 Kicker DS68 door speakers, Flowmaster 40 series American Thunder muffler, AEM Brute Force Air Intake.
    Can you post a picture of what it looks like? I can't picture this..
  18. Nov 29, 2012 at 2:54 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    im attempting to do this today.
    i got the glove box out
    the roof comparement doesn't come out fully, but enough to work.
    (a cord seems to be attached somewhere i cant find)
    now just trying to figure out where to stuff the weather stripping ???
  19. Nov 29, 2012 at 4:49 PM
    Madjik_Man
    Colorado Front Range
    If you wiggle your fingers up there (that's what she said) can you feel where the back of the plastic dash panel touches the assembly?
  20. Nov 30, 2012 at 11:36 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Does it rattle all the time? I know the dash's are notorious for rattling when it's cold. Mine does but it's fine when warm. Otherwise I just wedge a piece of paper or something in mine.
