Dash warning lights . They all keep coming on , speedometer will drop to 0 doing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stone2coma13, May 16, 2025 at 9:30 PM.
  1. May 16, 2025 at 9:30 PM
    Stone2coma13
    Stone2coma13 [OP] Member
    Stone
    2013 smoke grey 4x4 TRD. Double cab
    2013 v 6 4x4, every light in dash will light up power will surge. AC fan will blast high then low.. hooked up a code reader while this was going on . Shows no codes. Went to AutoZone let them run a code reader . Nothing. The headlight have never been bright . I have to run with fog lamps on . Recently I have noticed my horn has a short . I checked all the small fuses . Per one time this same thing happened it turned out to be a backup light fuse. I purchased new battery in December from Rural King. Possible issue? Can anyone help please
  2. May 16, 2025 at 10:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you have an charging system or main power/ground issue, I'd want to monitor battery voltage when the issue occurs as a first step and see what that does.
  3. May 16, 2025 at 10:24 PM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts
    My 1st Gen did this on vacation. The alternator was dying. Replaced it in the Autozone parking lot and drove home. Problem solved!
    TomHGZ and Stone2coma13[OP] like this.
  4. May 17, 2025 at 1:01 AM
    Stone2coma13
    Stone
    Hey denimdan 73, Thanks for the input. My alternator was going out last year around the first week of January.i had it tested and confirmed . Problem was my cash was low so I did a little thing my grandpa showed me years ago. Sounds crazy to some folks . But I sprayed half a big can of WD-40 into it while running. People at AutoZone thought I was nutz but after 10 minutes my battery was charging.. i went through 3 cans over the course of 11 months. Before Thanksgiving I changed it out then month later replaced the battery. Cheap battery only $60 . So I'm hoping its the battery.when all that happened AutoZone code reader told me the battery was to low to test. So I unhooked the battery cable truck died . I went inside go the WD -40
  5. May 17, 2025 at 1:09 AM
    Stone2coma13
    Stone
    Dm93 thanks so much for response. I hope it is the battery. It was cheap. I figured the reader at AutoZone would have told us of a bad battery. I will let ya know the outcome.
  6. May 17, 2025 at 1:32 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4
    Overbuilt daily driver
    @Stone2coma13, did you have an OBD reader hooked up to your truck when you disconnected and reconnected your battery? I had an issue with some of my gauges that turned out to be the fault of my OBD reader doing some weird feedback into the system. Details:
    Stone2coma13[OP] likes this.
