Dashcam - definitely need one after reading this
Discussion in 'General Automotive' started by chuam, Feb 10, 2021.
  1. Feb 10, 2021 at 1:28 PM
    chuam
    chuam [OP] Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    FreshPots and PennSilverTaco like this.
  2. Feb 10, 2021 at 1:31 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Feb 10, 2021 at 1:39 PM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Subbed for answers. Definitely need a dashcam
  4. Feb 10, 2021 at 1:46 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I've got this unit; very happy with it. Mounted up near the GoPro mount, out of sight from the driver's seat, but provides excellent visibility and good quality video fore and aft. The rear-facing camera is an IR unit, and works well even on the darkest nights; would have no problem seeing someone breaking into the truck in the dark.
  5. Feb 10, 2021 at 1:54 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There was a thread on here that did detailed dashcam reviews. I have a Rexing that I bought for 100 bucks or something. There is a lot I like about it, and a lot that I don't. It produces a great image, and has a parking mode. But the thing that burns me is that when its in parking mode it wont start recording until it senses an impact.
    If I had to do it again, I would buy this unit.
    https://www.amazon.com/dp/B07RZQJYD...colid=R4LK2ZS4QKX1&psc=1&ref_=lv_ov_lig_dp_it
    Looks and functions exactly like mine, except that the sensor is slightly better and that it has a 20 second buffer in parking mode so it will start recording before it senses impact. Plus I found some etsy shop that makes a gopro adapter for it.
    Bastek and shakerhood like this.
  6. Feb 10, 2021 at 2:19 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I bought the least expensive unit first to see if it is something I would use.....I bought this and decided to keep it Its great for frontal/
    I don't need the rear because the front will indicate if I am hit in the back...Inexpensive insurance
  7. Feb 10, 2021 at 2:21 PM
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
  8. Mar 1, 2021 at 3:40 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Can you hardwire the Apeman C450 or is it like a cigarette lighter type connection?
  9. Mar 1, 2021 at 3:49 PM
    ReelAddict
    ReelAddict Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    I have the Nexar NEXS1. Great dashcam and they give you unlimited cloud storage and include an SD card. You can view your drives right on your smartphone from their app. They also have great customer service. All their dashcam's are currently on sale. I added the link for you to check out.
    https://shop.getnexar.com/products/...SqZoTd163uVpTATw2IMm_kZ8isRdvKygaAp5JEALw_wcB
    chuam[QUOTED][OP] likes this.
  10. Mar 1, 2021 at 5:33 PM
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
  11. Mar 1, 2021 at 5:35 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  12. Mar 1, 2021 at 5:40 PM
    Shellshock
    Iowa
    rexing v1 or v3 is what I had
    currently have a kenwood that integrates with my headunit
  13. Mar 1, 2021 at 5:43 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
  14. Mar 1, 2021 at 6:57 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I installed a couple of Apeman dash cams (two different models) in the wife's RAV4 and my Tacoma. Both work well so far. Cost was about $36 and $60.
  15. Mar 3, 2021 at 10:54 AM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
  16. Mar 21, 2021 at 10:45 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I bought a Garmin mini. It has no screen, so you have to download an app to control it, view video, and so on. I mounted it behind the rear view mirror and used a Dongar https://www.dongartechnologies.com/ Simple USB adapter to power it.
  17. Apr 7, 2021 at 8:43 PM
    martintaco83
    martintaco83 Member
    CA
    2020 Tacoma
    Akkording[QUOTED] likes this.
  18. Apr 7, 2021 at 8:56 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Another vote for the Blackvue 2 channel camera setup; I have the DR900S, and it works exceptionally well. As I have a canopy, I routed the rear camera the rear window of the canopy, so that I'm always recording front & rear.
