DashHawk Performance Tests
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hotdog, Oct 22, 2007.
  1. Oct 22, 2007 at 7:06 AM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    So I picked up the DashHawk and I have been testing out the performance tests on it. The available tests are 0-60 and 1/4 mile. There is also a function to estimate the HP.
    Here's the specifics...2007 Tacoma Double Cab, Prerunner, 4.0, Automatic, LSD with premium gas. It is stock.
    I go to the track where I can pretty consistently pull in 0-60 time of 6.85 seconds. I was expecting times more along 7.6. Then I read that the Prerunner automatic is one of the faster accelerating of all the Tacomas.
    I plan on doing some more tests and getting some good mileage numbers. Because I will be installing the URD TCAI and MAF Calibrator. Although many people have done these performance mods, I have yet seen any real data on the performance/fuel efficiency gains.
  2. Oct 22, 2007 at 7:14 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    look forward to see what you come up with
  3. Nov 23, 2007 at 9:12 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    So, I don't drive my Tacoma often and I have not had many opportunities to check the mileage. Driving pretty much just in the city and with a fairly heavy foot, I was able to get a mileage of 14.75 mpg. I don't think that I can drive any less aggressively, so when I get my intake installed, I should get a fairly accurate comparative reading on the mpg. Tomorrow I might go ahead and install the intake.
  4. Nov 24, 2007 at 6:53 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    You will get better gas mileage as the engine "breaks in" , and with a little restrain of the heavy foot it's possible to increase up to 5 mpg, good luck with the install. :D
  5. Nov 24, 2007 at 2:02 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm not too worried about better mileage. I still only fill up every few weeks. My truck has about 7000 miles on it now.
  6. Nov 24, 2007 at 2:08 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    So I installed just the intake today and went to the track to test it out. On the way there, I could definitely feel a bit of extra power when it hit 3000 rpm. The noise was also there.
    I was able to get from 0-60 in 6.42 seconds. On run two I got the same numbers. This is without the MAF Calibrator. I ran out of patience and I decided I better not push my luck with the successful install.
  7. Nov 24, 2007 at 9:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Damn, that's almost as fast as my Altima was. Those G-Tech type devices can be inaccurate but the fact is you picked up a decent gain in acceleration, regardless.
  8. Nov 27, 2007 at 7:27 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It is not a G-Tech type device. I think that those were more based on accelerometers. The dashhawk plugs into the OBDII port. It displays your real time stats. That being said...I still don't trust my numbers. They seem too fast.
    I have now found that I drive slower with the intake. I feel like the truck makes too much noise when I floor it and I don't like making a scene. I think I should be getting better gas mileage pretty soon. This weekend I will be installing the MAF Calibrator.
  9. Nov 27, 2007 at 9:56 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Ah, I see. Yes, the Gtech is an accelerometer or g-force type device. I had one and didn't trust it a whole heck of a lot.
    I don't think your numbers are THAT far off. Our trucks are rated at under 7 seconds by a couple of different magazines, though I don't trust mag times much either. If there's any way that you could get to a track at some point, that would give you a better idea.
  10. Nov 27, 2007 at 10:56 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    Don't forget... those numbers are based on the mph readings that may not be 100% accurate. Take even a 1% +- difference on such a quick (small data set) calculation and you'll notice it very clearly. If your speedo is off by the semi-standard 5% you've actually got 0-57mph times. The extra 3mph might take an additional .3 seconds or so.
    I agree that you have a good comparison with your individual vehicle, but even something like tire wear over time will change your results. Good to see a clear gain though.
  11. Dec 24, 2007 at 8:20 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    So do you have the calibrator installed yet? I'm curious to see how that affects things.
  12. Dec 24, 2007 at 12:12 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Not yet. I was going to do it yesterday but I ended up hungover instead. I just filled up since I installed the intake and so far my mpg really took a hurting. 13.5 mpg and that's almost completely stop and go traffic.
  13. Dec 24, 2007 at 12:26 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Damn... That sucks! I only get in the 14mpg range when I go off roading for the weekend and spend some time in 4LO.
  14. Jan 5, 2008 at 10:23 AM
    PNWIW
    PNWIW Member
    western, WA
    07 TRD Off Road
    1" lift in rear, All pro coil overs in front.
    Are you able to read all of your trucks engine parameters with the Dashhawk?
  15. Jan 5, 2008 at 11:25 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Pretty much. The truck doesn't output all the engine parameters. If you have a specific statistic that you're looking for, I can take a look for you.
  16. Jan 6, 2008 at 10:38 AM
    PNWIW
    PNWIW Member
    western, WA
    07 TRD Off Road
    Thanks
    I have been looking into the buying a digital gauge, but I was unable to determine compatibility of the Dashhawk. The MSD site refers to checking the OBD port to see if the 6th and 14th pins are populated. Mine are not. If yours works, it should on mine.
  17. Feb 23, 2008 at 9:17 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I finally installed the MAF Calibrator. I'm still retraining the ECU, and then I'll do some acceleration tests.
  18. Mar 10, 2008 at 9:52 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Got any new info yet?
    BTW, does the DashHawk give MPG info, too?
  19. Mar 10, 2008 at 9:56 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    nope.
  20. Mar 10, 2008 at 9:57 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^LOL! Good enough for me.
