Day Time Running light problem
Discussion in 'Lighting' started by airfce250, Apr 13, 2010.
  1. Apr 13, 2010 at 6:50 AM
    airfce250
    airfce250 [OP] Active Member
    Cory
    2013 Tacoma TRD Sport
    My DTRL are not currently working, I have check the fuses and the bulbs but i havent found anything... also when i turn my lights on to the first one all i get is my tail lights... my front turn signals work and headlights are fine just not DTRL
  2. Apr 13, 2010 at 7:18 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There's an outside chance it has something to do with your parking brake switch. The DTRL's aren't supposed to activate until / unless the Body ECU receives an 'OFF' signal from the switch.
  3. Apr 13, 2010 at 7:39 AM
    airfce250
    Cory
    ok i will check it out and see if i can come up with anything.
  4. Apr 16, 2010 at 6:36 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Did you ever fix your issue? Was it the parking brake?
  5. May 3, 2010 at 2:39 PM
    Waikoloa Tacoma
    Waikoloa Tacoma Well-Known Member
    At the beach, Hawaii
    2007 PreRunner DC TRD OR
    OK I will continue this thread. My DTRL does not work either.
    1st - I have an 07 Prerunner DC Auto trans - Is DTRL standard or optional?
    2nd - I have made sure all the conditions are met for the DTRL to work.
    3rd - My parking brake dash light turns off when I release the break - How else would you check the parking break switch?
  6. May 3, 2010 at 2:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. I installed my DTRL's because it did not come with it when I bought it. I know if my emergency brake is engaged when I start my truck, they wont turn on until I release the emergency brake. But other then that, I havent had any issues with them (knock on wood).
  7. May 3, 2010 at 3:17 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    The DTRL's run through a relay, did you check it?
  8. May 3, 2010 at 3:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Its under the steering wheel in the back somewhere. I had to install the relay as part of my DTRL's.
  9. May 4, 2010 at 6:29 AM
    Waikoloa Tacoma
    Any specifics about where or what the relay looks like?
  10. May 4, 2010 at 9:43 AM
    Crom
    Nick
    San Diego, CA
    Millions
  11. May 4, 2010 at 9:56 AM
    Waikoloa Tacoma
    Thanks. I will look for those wires and connections.
  12. Mar 1, 2011 at 4:35 AM
    chozomo
    chozomo Active Member
    Adam
    Vermillion, Alberta
    10 DC TRD White, 92 SR5 pickup
    Extra fuel tank, fire ext, light force driving lights , TRD exhaust, ARB and Warn winch, Bushwhacker, toytec ultimate lift, dakar leaf springs, 18' ATX thugs
    I have a similar problem but my DTRL's just have a mind of there own. One moment the left light will go out then if the moment feels right the right one will go then the left will go back on again or they will just both go out. I checked connections and replaced the flasher relay is there any thing in the circuit that i might be missing?
  13. Feb 7, 2012 at 2:22 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Old thread...mine are doing a similar thing after ARB light splice??? Ever fix this?
  14. Feb 8, 2012 at 5:14 AM
    chozomo
    Adam
    Vermillion, Alberta
    the only thing that i found is that with two lights on the one circuit it overloads the computer sensor or what ever it is and shuts the circuit down. one thing i was going to try was put one of those LED lights in the bumper as they have low amp draw
  15. Nov 21, 2013 at 5:43 PM
    Doublee
    Doublee Well-Known Member
    Tennessee
    2017 TRD Sport- White
    I know this is old post but I have same issue anyone ever find a fix for this problem?
