DC LB 4x4 AT-to-MT Conversion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mach375, Oct 24, 2011.
  1. Oct 24, 2011 at 12:13 AM
    Mach375
    Mach375 [OP] Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Looking to buy my first Taco soon(ish). Want a DC LB 4x4, but with a MT......which appears not to exist. Of course, anything can be had with enough work, right?
    Done a little snooping around TW, found some helpful info. But, couldn't quite get my question(s) answered:
    What all is involved with swapping out the AT for an MT in a DC LB 4x4? Rough estimate in total price? Parts list? Things to be wary of? Impossibilities I need to find a work-around for? Anyone here actually done one?
    I 'spose I should mention: I'm looking at a new Taco (2012, if all goes well) with a V6. But I think that might have been implicit already......
    Fwiw- I'm not at all intimidated by the work--I've done a similar conversion, putting a Mustang 5-spd into a FrankenVolvo with an AT.
  2. Oct 24, 2011 at 1:24 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Yah agreed with whipper, From what ive read and what ive actually felt first hand, The six speeds aren't worth it. Honestly if i had a choice id stick with auto all the way. Six speeds are fun in sports cars, In a Tacoma they just dog and aren't very practical.
  3. Oct 24, 2011 at 9:20 AM
    Mach375
    Yeah, well, I just cannot stand ATs. I like having a stick to play with :) .
    Is the AT able to driven almost like a full MT? Like, full control over every gear? If not, is there a mod to make it so? (If not, I can talk to my neighbor about where he got his Isuzu AT custom tweaked to all hell).
    Still interested in what all is involved with putting a MT in. (Y'all haven't quite convinced me yet that an AT is superior......yet......).
  4. Oct 24, 2011 at 9:23 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    :eek: :laugh:
    It won't be worth it in the end.
    Fink
  5. Oct 24, 2011 at 9:28 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I love my 6 speed, had auto and hated it.
  6. Oct 24, 2011 at 9:32 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I love my MT, but I don't know that I love it enough to do what you're suggesting.
    I am absolutely certain it is possible, and probably pretty easy as these things go. I just don't think it's worth it.
  7. Oct 24, 2011 at 9:33 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
  8. Oct 24, 2011 at 9:46 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Certainly doable if you have all the MT parts. (Transmission, shifter, clutch, parking brake handle relocation.) Not sure if the ECU needs to be replaced or reflashed.
    Other quirks of the 6-spd:
    • 6th gear is shorter than the 5th gear in the auto, resulting in worse highway milage.
    • AT is faster 0-60 mph and in the 1/4 mi according to Car and Driver, potentially due to 1 fewer shift with the AT.
    • Clutch throwout bearing shaft was known to wear prematurely, due to inadequate fork support. This was fixed via TSB, so 2012 models are probably not affected.
  9. Oct 24, 2011 at 9:54 AM
    Kayak Taco
    Kayak Taco Active Member
    Signal Mountain, TN
    07 4x4 AC TRD OR 6MT
    Well, let's see..
    You'd definitely need the following
    Transmission
    Shifter Assembly, knob, etc
    Shifter Boot (If not the whole center console out of a MT)
    Clutch Pedal Assembly
    Clutch Master/Slave Cylinder/reservior/Line
    Bellhousing
    Clutch
    Flywheel
    Probably the ECU from a MT Taco
    Possibly Driveline Mods, not sure if the MT and AT are the same length
    Misc Bolts, fittings, etc to make it all work
    I am sure it is doable, and likely not that difficult (once you have all of the parts). I am sure that all of the mounting holes, etc are there on an Auto, Toyota wouldn't make the two any more different than absolutely necessary. But, If I were to try and do this on a Brand new truck, I'd want to use brand new parts. I sure can't see swapping in junkyard parts into a truck with 0 miles. So you'd probably drop ~$5k (and probably more) on new parts from Toyota. Not worth it IMHO. And I love my 6 Speed Taco...
    I bought an Access Cab OR 6speed because the things I would not compromise on were OR, Long Bed, and 6 Speed.
    If you do it to a new truck with new parts, make good friends with a GOOD toyota parts guy. The exploded diagrams and parts lists that they have access to would be worth their weight in gold...
    Good Luck
  10. Oct 24, 2011 at 9:59 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    And our autos are electronic based shifting...meaning the tranny isn't connected to the actually shifter at the top inside the truck...So for the conversion your going to have to cut thru the truck (regardless your going to have to do it for the manual tranny...)
  11. Oct 24, 2011 at 10:14 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    It would probably be cheaper to order a shortbed with the six speed, then get a longbed and have someone fab the frame to handle it and get a driveshaft. Doing that you would have voided every warranty known to man, so good luck if you want to try it!
  12. Oct 24, 2011 at 10:21 AM
    KenLyns
    Belly of the Beast
    Don't forget the parking brake relocation from the footpedal to the T-handle.
  13. Oct 24, 2011 at 10:30 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
  14. Oct 24, 2011 at 10:38 AM
    Ipunchwalls
    Ipunchwalls Well-Known Member
    Brian
    Colorado
  15. Oct 24, 2011 at 10:41 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Ah, didn't realize. Oh well. Op, get a SB or an auto...
  16. Oct 28, 2011 at 1:24 PM
    Mach375
    Thanks for all the info.
    How sure is anyone of ECU swaps? I was thinking parts would consist solely of mechanicals...?...
    I'm not sure how enamored I am with the idea of converting a DC SB MT to a LB--that gets into frame mods, and I've never been comfortable with tweaking with a frame. Plus, wouldn't the cost between a frame mod and swapping trannys be negligible?
    Is anyone familiar with how open Toyota would be to custom ordering one?
    Btw- I was originally thinking getting what I want with the Access Cab. But thinking further into the future (I tend to keep my vehicles 'til about 200K miles), I'm not so sure a family of four would be particularly thrilled with having to ride in the cramped quarters of the back of an AC.
    I'll probably go my original route if the MT conversion is just too much to do.
