DDM HID bulb & dust/water cover problem
Discussion in 'Lighting' started by stevencand0, Nov 22, 2012.
  1. Nov 22, 2012 at 5:06 PM
    stevencand0
    stevencand0 [OP] New Member
    The base of the DDM HID bulbs do not have a base similar to that of the stock bulb bases so that the dust/water covers fit tightly.
    I taped up the gap between the bulb wires and the dust/water cover with electrical tape but it seems to only be a short term solution to prevent water from entering the headlight housing.
    If you have the DDM HIDs, how did you seal the gap between the dust/water cover and the bulb wires? I'm thinking about using some silicone.... Thanks in advance.
  2. Nov 22, 2012 at 5:10 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Can't you modify the OEM dust covers?
  3. Nov 22, 2012 at 5:42 PM
    stevencand0
    How would you modify them so that there aren't any openings so water could get in?
