ddm hid help?????
Discussion in 'Lighting' started by brutalguyracing, Apr 1, 2010.
  1. Apr 1, 2010 at 4:35 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    just got my new 35w raptor hid kit from ddm
    just went to install them and idk what the hell is going on
    where do you guys mount the ballasts???
    the instructions they give me suck ....on the bulb with the rubber gromet i have a red and a black with copper leads wth do they go???
    i need some help
  2. Apr 1, 2010 at 5:27 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Just follow my diagram in my photo bellow...
    On the factory fog plug (This is the plug you will disconnect from your factory fog bulbs)
    Solid Green Wire side is + Positive ~ The red copper lead slides into the Green wire contact on factory fog plug
    White/Black Wire side is - Negative ~ The black copper lead slides into the White/Black wire contact on the factor fog plug
    Oh and you don't need those black rubber grommets...Just carefully cut them away from the wires and pull them off
  3. Apr 1, 2010 at 5:45 PM
    blazze2005
    South Jersey
  4. Apr 1, 2010 at 7:58 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    dam that was the best.......now tomm. i can install them...and that was gonna be my next question...about the black rubber thing
    they could send you better inst. with these things.....
    how do you like yours>
  5. Apr 1, 2010 at 8:14 PM
    blazze2005
    South Jersey
    I love my HIDS!
    I also just did the fog lights anytime mod on my truck
    Now I can run just my HID fog lights without having my headlights on:D
  6. Apr 2, 2010 at 3:19 PM
    SoCalR
    SoCalR Well-Known Member
    Rand
    San Diego, CA
    05 TRD Sport PreRunner
    I don't know if you have already done the install, but I've got DDM HIDs in my fogs and, as far as wiring them up, its real easy to do.
    Unplug your factory fogs and unplug and pull out the wires without a connector off the DDM ballast (the plug/wires on the left side of blazze2005 pic) you will not be needing these anymore. The factory plug should plug directly into the ballast. Test them out, and it should work.
    Hopefully this makes some sense. If not, I'll try and get a picture of my setup sometime.
  7. Apr 2, 2010 at 6:02 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i tried to install them again today what a bitch i have no idea... what a shitty system this is... im ready to forget this whole thing
  8. Apr 2, 2010 at 6:04 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    If your going wheeling with us tomorrow i will take a look at it. I put HIDs in my 08 when i had it.
  9. Apr 2, 2010 at 6:04 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    wtf are with the wires "red & black" spade terminal wires????
    this is crap
  10. Apr 4, 2010 at 9:57 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks for the offers and help guys..
    well i just installed the bulbs......really had to push hard to get them in but they are in...
    then i cut out the red and black spaded terminal wires and rubber gromet... then checked them they worked...
    now i was thinking about mounting the one ballast on the battery is that a good idea or no??? to hot?>/?
    update finished...works great and looks even better.....
    they should tell you that you do not need the red and black wires......would have made life much easier....
    thanks guys.....
    now i will order the headlight hids soon
