Dead in the driveway
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacodumbass, Apr 1, 2012.
  1. Apr 1, 2012 at 8:42 AM
    tacodumbass
    tacodumbass [OP] 2007 tacoma 4x4
    Boston
    '02 Tacoma 2WD
    I got home from a long trip last night and the truck was fine, and this morning when I went to start it up, it was dead, as in battery dead. I got someone to help me jump it and I drove around for a bit to recharge the battery, and very fortunately drove back into the driveway and turned it off and wasn't able to start it up again, so my first thought is that the battery isn't charging which makes me think that either the alt or the gen isn't working.
    Before I set myself up for an expensive repair, is there a way I could diagnose, basically, what the problem really is?
    Any ideas?
  2. Apr 1, 2012 at 8:48 AM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    Try replacing the battery with a new one.
  3. Apr 1, 2012 at 8:50 AM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    Take the battery out and to autozone and they will test it.
  4. Apr 1, 2012 at 8:54 AM
    tacotrd647
    tacotrd647 Resident "dude"
    Caleb
    Ridgeway, Iowa
    02 Prerunner SR5 TRD
    KMC Enduro Wheels, 265/75/16 toyo open country at2
    Jump it...while running take a voltmeter and see if the alt is charging the battery.
  5. Apr 1, 2012 at 8:56 AM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    This ^
  6. Apr 1, 2012 at 8:56 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    When modern batteries go, they go without warning.
    I've had three incidents over the last 20 years where everything was fine, then one day, no crank.
    Figured I had left a light on, got a jump, started fine, drove for an hour or more (lights off), stopped, and completely dead when I tried to start.
    New battery, problem solved.
    Now, if it won't start, I double check that everything is shut off. If nothing was left on, I skip the jump and go straight to a new battery.
  7. Apr 1, 2012 at 9:08 AM
    tacodumbass
    Boston
    '02 Tacoma 2WD
    Thanks everyone for your feedback. I don't have a voltmeter, but will buy one now. The plan now is to take the battery to autozone and hopefully they'll diagnose that it has gone bad.
  8. Apr 1, 2012 at 9:10 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This. Start with the most common cause, go to Auto Zone and have them test the battery. If your battery is good, then move on to the next problem. If not, buy a replacement. Done.
  9. Apr 1, 2012 at 9:12 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Hopefully... but any time I've done that, they've wanted to put it on their charger for 12 hours before doing a load test.
    It's usually pretty obvious... it'll read 12.5v, then when you hit the load test it'll dump to 8 or less, and unless you're trying to get a Die Hard replaced under warranty at Sears, they'll usually accept that it's bad.
    The problem is if you bring it in below 12v, they'll want to charge it before loading.
  10. Apr 1, 2012 at 9:29 AM
    52motorhead
    52motorhead Well-Known Member
    You cannot load test a dead or 1/2 charged battery.
    In your sig it shows you have a 2002, if that is the original battery then change it. Battery life now a days is 5-7 years.
  11. Apr 1, 2012 at 9:40 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Was gonna ask, what's the age of the battery? It should be indicated on the battery somewhere.
  12. Apr 1, 2012 at 10:32 AM
    Madjik_Man
    Colorado Front Range
    I've had the same battery in my truck for 14 years
  13. Apr 1, 2012 at 10:38 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Usually this is true. Although the quick chargers are only an hour or two. I've worked in auto parts stores, they all use the same smart chargers/testers. Sometimes the tester will immediately say a low voltage battery is bad, sometimes it wants to charge it.
    If it's over five years old already, and it's more about your time than your expenses, just buy a new one. That's probably the whole issue, and you can then drive the truck a few miles to have the whole system checked at NAPA or whatever store you have in the area. Or pickup a meter and check the running voltage yourself.
  14. Apr 1, 2012 at 10:42 AM
    joes06tacoma
    Joe
    Central Coast, CA
    So it drives perfect when jumped? I'd say that's a pretty good indicator the alternator is working. I'd say bad battery. If it was a charging issue and the battery is already dead, the truck probably wouldn't run.
  15. Apr 1, 2012 at 10:53 AM
    tacodumbass
    Boston
    '02 Tacoma 2WD
    Well you guys are going to get a good laugh out of this.
    Took the battery out, schlepped it all the way to Autoparts and they tested it (and found it was only 2 years old) and it came in at 444 of 490 CCA (90% full). I then hauled it back home thinking the worse, and happenstance decided to just put it back in the truck and noticed that the inside of the battery clamps was completely coated in battery corrosion, so I took some steel wool and scraped them out, put the battery back in and the truck started just fine! :facepalm:
    Good april fool's day joke, and I get to live up to my username.
    At least I now have a voltmeter which I bought at autozone while I was there, so the day wasn't a total waste.
  16. Apr 1, 2012 at 12:24 PM
    Yamaha Dave
    Lol well you were right I did get a good laugh out of it... hey it's all good fun, what are you gonna do. Lesson learned, at least you are wiser than you were yesterday.
    :D
