Dead truck after 1600 miles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MSOEME2009, Oct 2, 2016.
  1. Oct 3, 2016 at 5:34 PM
    #201
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    7GR likes this.
  2. Oct 3, 2016 at 5:38 PM
    #202
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Just curious, how did you know he had aftermarket lights? I didn't see it posted previously in the thread.
  3. Oct 3, 2016 at 5:38 PM
    #203
    bobrown14
    Bob
    Philadelphia
    Gen 3
    melikeymy beer likes this.
  4. Oct 3, 2016 at 5:38 PM
    #204
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    The OP never said he used pressure washer, it was the guy with the huge repair bill
  5. Oct 3, 2016 at 5:39 PM
    #205
    Spare Parts
    Southern Maine
    In his avatar
    itzyoboipaul likes this.
  6. Oct 3, 2016 at 5:40 PM
    #206
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Do what I do.. hang out at home with all my homies right here... and beer! :canada:
    Pfffft.. dispensaries are for police ... just sayin.
  7. Oct 3, 2016 at 5:42 PM
    #207
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Guess I need to pull it up on a larger display because I still don't see them.
  8. Oct 3, 2016 at 5:44 PM
    #208
    Spare Parts
    Southern Maine
    Sorry it's in his little write up on the left of his posts.
    Edit-under his vehicle description
  9. Oct 3, 2016 at 5:57 PM
    #209
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Ah, that's not displayed in the mobile version of TW.
  10. Oct 3, 2016 at 6:09 PM
    #210
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Yeah ... are we SURE??
  11. Oct 3, 2016 at 6:10 PM
    #211
    MSOEME2009
    MSOEME2009 [OP] Well-Known Member
    Knoxville TN
    2016 White Tacoma TRD Sport Double Cab 4x4
    Custom Grill; XB Fogs; Katzkin Custom Leather Interior (the way it should have came)!
    No ya'll just creepin'
  12. Oct 3, 2016 at 7:58 PM
    #212
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Thanks. Conducted emissions from the HID power supply putting noise on those busses is an option, and that will cause bizare and interesting failure modes.
    My bet is: HID power supply gets wet, puts noise on the ground plane for the ECU, one of the processors which actually runs the truck shits itself, and the truck dies.
    Good luck OP, sounds like new bulbs is the answer.
    3dBdown likes this.
  13. Oct 3, 2016 at 8:12 PM
    #213
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    You have no sense of humor do you? You must be an engineer.
    ne_dan and Arcticelf like this.
  14. Oct 3, 2016 at 9:20 PM
    #214
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I know a LED is a light emitting diode. I should of been more clear and I misspoke a bit. I didn't mean to say LEDs themselves. They don't produce any detectable noise. However the devices to control and operate The LEDs can emit EMI noise. This noise can cause interference. So while the LED itself doesn't a LED light or some other device that uses LEDs can. Not all devices have it use filtering devices.
    A prime example is in our shops we have LED lights in the ceiling and they effect our door opener range. The overhead door guys said they run into this issue a lot.
    Arcticelf likes this.
  15. Oct 3, 2016 at 9:29 PM
    #215
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    That diagram isn't showing anything really pertaining to the head lights. Just showing the BUS lines and how they run on the network. The headlights run from the switch, yellow wire to the ECU. As do the parking lights and there is a auto light wire. All those are analog. The switch itself isn't a CAN module or run on a LIN bus or any other type of network. I'm pretty sure the ECU just uses internal relays to control the headlights after that. I highly doubt anything is back feeding into the circuit and causing the ECU to freak out.
  16. Oct 3, 2016 at 9:29 PM
    #216
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Normal for the vehicle
  17. Oct 3, 2016 at 11:12 PM
    #217
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    It was noted in his user bio bar next to the post under "vehicle:"
  18. Oct 4, 2016 at 3:35 AM
    #218
    Arcticelf
    Gladiator
    Engineers have a sense of humor, it's an optional extra though.
    Tunngavik[QUOTED] likes this.
  19. Oct 4, 2016 at 3:47 AM
    #219
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Your joke didn't meet specifications.
  20. Oct 4, 2016 at 9:13 AM
    #220
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    As I had said, it was only the piece of the puzzle that pertained to the ECU without uploading the whole schematic.
    There are no "internal relays" in the body ECU. The body ECU is run on the network, what it does is it switches ground signals to external headlamp relays under the hood. This body ECU is how it does all the fancy stuff like turning the headlights off automatically if you park & leave the lights on, and cutting the fog lights off when you put on the high beams. Again, see the top most blue box is labeled M6(A), which is the main body ECU.
    Anyways I guess I should upload the whole thing. See attached PDF for the full layout.
