Dealer Can't Diagnose This Vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bman291317, Jul 11, 2023.
  1. Jul 11, 2023 at 12:32 PM
    #41
    bman291317
    bman291317 [OP] Active Member
    Man you would think so!
  2. Jul 11, 2023 at 12:34 PM
    #42
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The TSB doesn’t apply to 22 or 23 year model trucks.
    It’s up to your dealership whether or not they want to fight corporate on the diagnosis.
    My point is, it may be a process. Be patient. Hopefully the dealership will get it figured out.
    And be polite to the service writer and tech. Before it’s over, you and the dealership (writer /tech) will have put in a lot of time. Some of which, someone probably won’t be getting paid for.
  3. Jul 11, 2023 at 12:34 PM
    #43
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Based on past experience I've had, vibration at highway speed is usually a tire balance issue. Go somewhere else and get the re-balanced.
  4. Jul 11, 2023 at 12:39 PM
    #44
    bman291317
    Yeah we've been putting in some time lol. They've been polite to me so I have been polite back.
    wayupnort and TnShooter[QUOTED] like this.
  5. Jul 11, 2023 at 12:42 PM
    #45
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    Understood. I saw it here, I quoted post #122 where the user mentioned it included 2022 MY.
    https://www.tacomaworld.com/threads...n-automatic-trucks-stock-height.748639/page-7
    I’ll give it a go thank you again.
    TnShooter[QUOTED] likes this.
  6. Jul 11, 2023 at 1:44 PM
    #46
    Commocean
    Commocean Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    It also doesn't apply to 2WD versions, yet my '17 SR 2WD had the issue. It also vibrated above 75MPH to the point that the steering wheel and passenger seat would shake. They never diagnosed or corrected it, so hopefully my new '23 doesn't have the same issue.
  7. Jul 11, 2023 at 1:47 PM
    #47
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Could be an out of round tire also...those are super annoying
    bman291317[OP] likes this.
  8. Jul 11, 2023 at 2:39 PM
    #48
    RetGoalie
    RetGoalie Well-Known Member
    Tom
    2023 DCSB Sport
    2023 sport here with the TRD lift kit. I’ve had almost exact same issue. Told dealer day after i took delivery. They said yup it’s there and they have no idea and started a “case” with Toyota. That was Feb. it’s actually gotten slightly better to the point I don’t notice it as much. Could it be tires and as they wear ? Or is it because I just installed a hard tonneau cover. S the extra weight has helped ? IDK but I’ll just keep telling them every service
  9. Jul 11, 2023 at 2:44 PM
    #49
    amitchr
    amitchr Well-Known Member
    2023 Tacoma TRD Off Road
    I noticed after I added the diamondback bed cover it got less noticeable. Added weight?
  10. Jul 11, 2023 at 2:45 PM
    #50
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    yep
  11. Jul 11, 2023 at 4:20 PM
    #51
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    A couple of things to look into:
    In doing my own research today for my own tire needs, one recommendation I saw was getting the tires rebalanced every other rotation. Toyota will only do this if you request it. Found that out after 50k on my current tires. It did help.
    They also don't do a true rotation. Most dealerships are just required to move front to back and vise versa with no crossing. You probably probably won't notice issues with those two things if you've only done one rotation.
    But, what you may notice in that time relates to wear and inflation. Toyota tends to over inflate the tires. This becomes even more of an issue in hot weather and with higher speeds. I've heard they're supposed to set them at 35 psi. I've left my dealership with 40 psi readings on my dash while my door sticker says they should be at 30 PSI when cold. Excessive inflation can cause vibration issues in the tires. Not to mention that it'll cause the contact patch to be smaller than the full width of the tread. So, when you hit all those bumps and micro bumps in the pavement can cause those parts of the tread that are now raised off the ground, to come into contact with the pavement unequally or improperly which will cause friction improperly. This may cause vibrating and improper heat distribution in the tread block and lead to improper wear.
    Which leads me to my next point. If you truly had an alignment issue before and it wasn't, say, just caused by natural pavement slope, you could have some uneven wear that you're now feeling, especially since the rotation, since those tires are not contacting the pavement in the same way as before since they were moved.
    TL;DR:
    Check your tire pressures, tire wear, and don't underestimate the importance of getting your tires rebalanced periodically.
    GilbertOz and bman291317[OP] like this.
  12. Jul 12, 2023 at 2:42 AM
    #52
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    "Normal characteristic" of the Tacoma...
  13. Jul 12, 2023 at 4:31 AM
    #53
    Vmax540
    Chuck
    Clarion PA.
    Is there a steering wheel damper/stabilizer O.E.M. or aftermarket ?
  14. Jul 12, 2023 at 5:29 AM
    #54
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    My 2019 is my fourth Toyota truck, every one of them has had some type of vibration (drive line).
    Welcome to owning a Tacoma, it’s a Toyota thing…..embrace it or sell it because the dealer has only about a 5-10% chance of fixing it.
    My 2019 Limited has the 25-10 mph decell vibration. You get used to it.
    Sorry :anonymous:
    Vmax540 and clownkillerloaf like this.
  15. Jul 12, 2023 at 5:50 AM
    #55
    Soonr1
    Soonr1 Well-Known Member
    2022 Army Green TRD Off Road
    This is great info. I’ve been dealing with tire issues since 10k. Almost at 23k now. Dealer said I had excessive warping on the rotors and resurfaced them at 15k. Still have the issue but I only hear it on the front drivers side. At 20k they told me it was tire cupping. I have 255/85/16s. My main contention is I can’t see any evidence of cupping and even if that’s the case, when my tires are rotated I only hear the sounds in one spot. It doesn’t add up and it’s maddening. Not sure what it is but it comes and goes and it’s so loud.
    RedWings44[QUOTED] and wayupnort like this.
  16. Jul 13, 2023 at 5:29 AM
    #56
    bman291317
    This is good information and really what I think where the problem lies. They have tires around 35psi, they go up to about 37psi during commute. I do believe that the need for alignment prior to having them rotated has also caused some slight uneven wear. Im thinking of maybe just getting a new set of tires to see if this solves the issue.
    RedWings44[QUOTED] and LeakyAC like this.
  17. Jul 16, 2023 at 4:04 AM
    #57
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Look at a warped wheel or rotor due to dealer installing wheels with an impact.
    Aluminum wheels do not like to be installed with uneven and high torque.
    Vmax540 likes this.
  18. Jul 16, 2023 at 4:10 AM
    #58
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    mine literally does the same thing, youll need to get over or get used to it , or both
  19. Jul 16, 2023 at 4:51 AM
    #59
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    One of your shocks might be bad. I had a vibration on my Duramax around 12k miles. Two of the factory shocks were shot (Rancho 3000). I went through tires, alignments, balancing, etc.
    I put Bilstein 4600's on and the truck was smooth again. Truck is at 95k miles now and starting to do the same vibration again. Might be time for some smooth body King shocks.
  20. Jul 16, 2023 at 11:46 AM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like the vibration started after a rotation was done. Rotate the tires back to where they were and see if anything changes. The dealership is wasting your time
