dealer oil change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mullica woods'er, Aug 31, 2009.
  1. Aug 31, 2009 at 3:05 PM
    mullica woods'er
    mullica woods'er [OP] Well-Known Member
    south jersey pinebarrons
    06 trd 4x4
    rear leaf tsb,billies all around.front set at 1.75. 265 duratracs.cbi front hitch.rough contry 9.5 winch/syn.rope.
    hey everybody,
    i had my one and only free oil change today at the dealership.(i bought used thats what they gave me.)On my receipt it says:eek:il syn/blend motor oil.I just wan't to know what they put in it.Is it synthetic,reg.,or some type of blend they use?If it is a blend,never heard of that.ok,thanks.
  2. Aug 31, 2009 at 3:21 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    It depends on the dealership. They probably put 5W-30W. I know Toyota of San Diego participates in the Mobil-1 program, so that's what they used. The director of the service department said that it really doesn't matter which oil as long as its a high quality oil and the proper weight. (5W-30W for Tacoma).
  3. Aug 31, 2009 at 3:48 PM
    Jrez920
    Jrez920 Member
    New Bedford, Massachusetts
    TRD Sport long bed, Double Cab
    Nokya 8000k blue headlights and fogs, TRD 3rd brake light, 63 series k&n intake, and more small mods
    well i work at a toyota dealership in Dartmouth, Ma and that means a synthetic blend which is synthetic and regular motor oil mixed so that way you can switch back and forth from regular oil to synthetic just so u know
  4. Aug 31, 2009 at 3:55 PM
    tacobale
    tacobale Well-Known Member
    You work for a dealer? You are kidding about the back and forth thing, right?
  5. Aug 31, 2009 at 4:56 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    You work at Dartmouth Toyota? That's where I bought my truck ... traded my Mazdaspeed 6 in for it.
  6. Aug 31, 2009 at 5:00 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    The local dealership (Precision Toyota) called it "semi-synthetic". I asked what brand it was and the rep I was speaking with did not know. Since then, I have been doing my oil changes.
  7. Sep 5, 2009 at 7:09 PM
    Jrez920
    Jrez920 Member
    NOOOO SHITT lol i remember that thing i worked on that mazda pretty nice how you like the tacoma
  8. Sep 5, 2009 at 7:14 PM
    Jrez920
    Jrez920 Member
    the reason i said back and forth is because with a full synthetic its not good to switch from full synthetic to regular oil so we use synthetic blend so if u want u can always switch back
  9. Sep 5, 2009 at 8:41 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    synthetic motor oils are 100% compatible with non-synthetic motor oil (mineral based). Plus to add to the safety factor the API has mandated that all motor oils be compatible from both the oil standpoint and the additive package standpoint.
    With oils used in motors -- PAO (IV), group III and any other group are totally compatible. The additive packages are the wild card and if not carefully designed can cause problems with other additives. This however is where the API kicks in.
    I have heard many different stories that a synthetic oil when used after a mineral oil has been used causes problems. The only problem I have seen is leaking. PAOs have inherent cleaning characteristics which will clean sludge and any other deposits found in older engines that have used mineral oil. Best i can tell and from what I have heard from people in the know is that the PAOs come in and clean all the buildup and in doing so find their way through the gaskets which have probably been affected by the deposits.
    Also -- on a side note thanks to castrol Group III oils can be sold as synthetic oils which are damn good oils (very clean) but they are not PAOs. So when you pick up that quart of synthetic it may be group III and not a PAO.
