Dealer said can't diagnose heavy cabin vibration because I have aftermarket wheels and tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17trdoffroadbel, Jul 1, 2019.
  1. Jul 2, 2019 at 12:12 PM
    #101
    17trdoffroadbel
    17trdoffroadbel [OP] Well-Known Member
    Turd Gen
    Have you spoken to the Toyota Regional rep yet and explained that the dealership doesn't want to perform warranty work for an issue you have identified?
    That asshole is the one who has already illegally denied a warranty repair and it was a huge hassle to just have him come over. No thanks, not doing that again.
    What's an oil change got to do with my issues? My oil is current with over 3k left before the next change.
    asuchemist likes this.
  2. Jul 2, 2019 at 12:18 PM
    #102
    808veedub
    808veedub Well-Known Member
    Brent
    Hawaii
    2016 4x4 tundra crewmax 2016 trd sport tacoma
    I don’t think you understand lemon laws and what a dealer is “legally” obligated to do for you.
    Dryfly24 and hiPSI like this.
  3. Jul 2, 2019 at 12:21 PM
    #103
    17trdoffroadbel
    Turd Gen
    I understand that lemon law is completely separate from the dealer. They aren't a part of it. I just want the truck fixed.
    Sure, they're not "legally obligated" to look at my truck, but I'm sure they have a contract with Toyota that defines how they handle that sort of thing. After all, it is a Toyota franchise.
  4. Jul 2, 2019 at 12:32 PM
    #104
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is an out there suggestion, but is possible some funny guy decided to shove some stick on weights on your driveshaft? Got any enemies? That would create a massive rotational imbalance and cause what you are describing. Also, it would be wise to have your U-joints checked and the carrier bearing as well for excessive slop.
    You may want to have your wheel bearings checked as well. If you are 4X4 you may have an axle issue.
    17trdoffroadbel[OP] likes this.
  5. Jul 2, 2019 at 12:35 PM
    #105
    17trdoffroadbel
    Turd Gen
    I'm pretty low key, no enemies. Vandalism around here consists of cars getting keyed, nothing sophisticated like that. I think it's some driveline thing that's not related to the wheels too, but you can't reason with some people. I'm going to go to another dealer, and if that's a no go, Toyota can take it back like this. Screw it. Not going out of my way to fix this.
  6. Jul 2, 2019 at 12:39 PM
    #106
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If there is anything I have learned in all my years of wrenching it is that work on your vehicle is best left done to yourself in some instances sometimes. If you are novice then now would be a great time to start getting your hands dirty and experimenting. Not only will you learn a lot, but you will also become a little more in tune with the intricacies of your truck.
  7. Jul 2, 2019 at 12:43 PM
    #107
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dealers can handle the customers, especially difficult ones, at their own discretion. It sounds like you are having a problem differing between idealistic and realistic worlds.
    Dryfly24 and BillsSR5 like this.
  8. Jul 2, 2019 at 12:55 PM
    #108
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Take a deep breath.
    Put stock wheel and tire set up on. Have them diagnose the truck.
    What you are experiencing is not uncommon across all brands. I had a similar issue on our old JK due to aftermarket wheels and tires. Put the stockers on it and did not take it back in....as the problem disappeared once the stockers went back on. It was a tire balancing issue that was not addressed despite three trips to Discount Tire.
    Had the same issue on my 06 2500. Put the stockers on it and had a steering rack issue properly handled under warranty.
    Some dealers will look at it anyway, but remember that despite what you think, and despite how unfair you may feel it is, they can take the stand they're taking.
    So either return it to stock, diagnose it another way, or sell the truck. But getting upset about it and venting about it here is apt to end in frustration. It's a matter of time before some shitposter hops in here and makes it his goal to drive you batshit.
  9. Jul 2, 2019 at 12:57 PM
    #109
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    According to your posts, you have had nothing but issues with this truck, right? Man, I would have spent a few thousand and dumped the thing years ago, like a did my CR-V. Not worth the head aches & your time which is valuable, but too each there own.
    Chew likes this.
  10. Jul 2, 2019 at 12:58 PM
    #110
    Sungod
    Sungod Well-Known Member
    St Augustine
    It doesn't matter what wheels or tires you had on if they were not balanced or your tires were crap, that is what causes it. It is real simple to eliminate driveline if you have an auto. Get to 70 and put it in neutral. If your vibration goes way completely, it is drive line. Otherwise fix your wheels and tires first. It sounds like that is the only thing you have changed so that is usually where the problem is. Stop thinking it is something else and wasting your dealers time.
    To be perfectly honest with you, if you carry the same attitude into the shop that you have here when people have given you solid advice, I wouldn't be shocked if someone slapped and extra stick or two of weights on the inside just for fun.
  11. Jul 2, 2019 at 1:45 PM
    #111
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I have had issues with my local dealer too. I will not buy from them again. If the next one is the same, I will probably buy something else next time.
  12. Jul 2, 2019 at 5:58 PM
    #112
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Get down to Michael's Toyota in Bellevue. They modify, lift, level Tacoma's all day long. They can definitely help you.
  13. Jul 2, 2019 at 8:38 PM
    #113
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Can someone near OP swap stock wheels for the day so he can get his truck looked at?
    TeecoTaco likes this.
  14. Jul 2, 2019 at 8:41 PM
    #114
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Dryfly24, Paul631, BillsSR5 and 4 others like this.
  15. Jul 2, 2019 at 8:48 PM
    #115
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He can rent mine for $400.
    Dryfly24, asuchemist and stun gun like this.
  16. Jul 2, 2019 at 9:56 PM
    #116
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Yea, that should fix it right up
  17. Jul 3, 2019 at 5:51 AM
    #117
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Reading this thread is frustrating since the OP can’t quote properly.
    GreyBaldTaco and asuchemist like this.
  18. Jul 3, 2019 at 10:07 AM
    #118
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    If the truck is being lemon lawed, why are you surprised that they won't fix it. Isn't the whole point of the lemon law to help when vehicles can't be fixed?
  19. Jul 3, 2019 at 6:32 PM
    #119
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    I'll try again...carrier bearing...
  20. Jul 4, 2019 at 6:48 AM
    #120
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Cause he wants to keep taking it back to be a pain in the ass, to prove a point, to show them he's the big winner.
    Or just doesn't have anything better to do with spare time.
    hiPSI and GreyBaldTaco[QUOTED] like this.
