Dealer said can't diagnose heavy cabin vibration because I have aftermarket wheels and tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17trdoffroadbel, Jul 1, 2019.
  1. Jul 10, 2019 at 11:54 AM
    #161
    17trdoffroadbel
    17trdoffroadbel [OP] Well-Known Member
    Turd Gen
    I'll definitely keep you guys posted. WA has VERY stringent lemon law policies, so they will surely move it to another state to wash the title, and resell it to some poor sucker, with like 5k powertrain warranty left on it.
    kakwvu likes this.
  2. Jul 11, 2019 at 12:58 PM
    #162
    Sungod
    Sungod Well-Known Member
    St Augustine
    They did set the toe which was horrible and needed to be adjusted or your tires would have been destroyed. However, as mentioned 1000 times, the problem is not your alignment. You did badly need one and they didn't take your money because they did fix something that was wrong. Looking at those numbers it is possible your tires are in bad shape and that could be the source of your problem. Any chance you can get some pictures of the tread on the fronts? If you have scalloping or wear patterns from the poor alignment, that could be the problem and if that is the case, there is nothing you can do. Basically if they look anything like this - https://i.ytimg.com/vi/ANeCJhNwOn4/maxresdefault.jpg that is the source of your problem.
    Now my fans will call foul when I suggest this, but this is the one and only condition that I suggest the "chalk test". In this case, you are not looking to find air pressure, but you should do this to see how flat your tread is. If you do the chalk test and you see high and low spots, look no further, you found your problem.
    Boghog1 likes this.
  3. Jul 11, 2019 at 10:51 PM
    #163
    17trdoffroadbel
    Turd Gen
    My tires do look fine (tonered said same thing), but I picked up some chalk and I'll do the test tomorrow and post the results for you guys.
    kakwvu and tonered like this.
  4. Jul 12, 2019 at 6:52 AM
    #164
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    turn the inside of your tires and check for visual out of round.
    I bought used truck once that would vibrate at 40mph really bad. I checked the tires pretty good but didnt see anything. At the tire shop\alignment they turned the steering wheel all the way
    and sure enough it was visibly out of round big time. Bought a new set of tires and truck was trouble free.
    Vibrations only come from a few places, tires -> shocks -> drivetrain.
    You would have a hard time convincing me its the drivetrain.
    Dryfly24 likes this.
  5. Jul 12, 2019 at 8:00 AM
    #165
    17trdoffroadbel
    Turd Gen
    I get it, but the fact that it started doing it recently on two entirely different sets of tires & wheels does point to the drivetrain. Since it's going to the dealer this morning, I'm going to do as tonered suggested and ask them to throw another set of wheels & tires on there temporarily to test it.
    When I get it back, assuming I still have no answers, I'll start diving into everyone's suggestions.
    Btw, one of the sets of wheels and tires had essentially brand new tires on there, less than 3000 miles on them.
    tonered and fiftyxp like this.
  6. Jul 12, 2019 at 8:25 AM
    #166
    fiftyxp
    brand new doesnt necessarily mean anything if they are out of spec from the factory.
    do you have wildpeaks by chance?
    interested to see what they say / find to say they least.
  7. Jul 12, 2019 at 8:26 AM
    #167
    17trdoffroadbel
    Turd Gen
    Nope, it was between Kumho Crugen HT51's and now blizzaks. Both ran great before the truck started vibrating like crazy. The Kumho's in particular had fabulous ride quality.
    fiftyxp likes this.
  8. Jul 13, 2019 at 12:06 AM
    #168
    17trdoffroadbel
    Turd Gen
    Ok update guys. I didn't have time to do the chalk test or anything like that, but it doesn't matter anyway. I took the truck to Rodland Toyota in Everett as recommended by tonered (thanks btw man!). Was pleasantly surprised for a change. Sure, I had to pay for a loaner, but on the other hand, they had skilled techs there who quickly spotted what the turds at Kirkland were apparently incapable of:
    The wheels and tires were all severely unbalanced, requiring at least 2oz of weight a piece. In fact, some of them had missing weights (stick on's). Apparently, according to the tech, he suspects the place that did the balancing (discount tire, of course) does not calibrate their machine, which the tech says they do every morning at Rodland. And they probably didn't clean the wheels before applying the weights, which is why they fell off. Rodland says they use a cleaning solution on the mounting area.
    Oddly enough, Kirkland was kind enough to tell me that there was dirt on the inside of my wheels that might be causing my vibration, but they were apparently unable to spot the missing weights.
    So yeah, problem is now finally solved and I'm a happy camper in that regard. Very grateful for tonered's Rodland recommendation. Drop by any time you're in the area and I'll buy you a beer at the local pub (my fridge is mostly stocked with light lager's).
    Also I guess the guys criticizing Discount Tire were right after all.
  9. Jul 13, 2019 at 12:13 AM
    #169
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    Glad you were able to get it fixed and your confidence in Toyota restored.
    Spare Parts likes this.
  10. Jul 13, 2019 at 12:14 AM
    #170
    17trdoffroadbel
    Turd Gen
    That must be sarcasm. I was happy with Rodland as they fixed that particular problem in a professional manner, but Toyota itself is never regaining my confidence after their behavior about the other issues the truck had and has..
    BillsSR5 likes this.
  11. Jul 13, 2019 at 7:37 AM
    #171
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    You're welcome! I am glad that they helped you out. That work order will be very helpful for you.
    :cheers:
  12. Jul 13, 2019 at 7:47 AM
    #172
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Now you got it, tool bad you put yourself through all the anguish, before coming to that conclusion.
  13. Jul 13, 2019 at 7:55 AM
    #173
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Hey OP,
    I was at a local dealer here in TX and we were trying to find out what t force wheels I had and in this process I mentioned your issues.
    The dealer told me that Kirkland is/was going about it in the wrong way, even with a law suit they should be bending over backwards to get you the best service....it helps them seem like angels in court. And even with mods they should still be able to do the basic diagnostic checks like ball joints, balance, bearing checks, etc.
    My mother just told me she never takes her car to Kirkland, she goes to Bellevue and does not even like them much.
    Just thought you should know that it is that Franchise not the rest.
    17trdoffroadbel[OP] and tonered like this.
  14. Jul 13, 2019 at 8:24 AM
    #174
    fiftyxp
    nice update. I had a feeling it had to be the tires or wheels. good to hear
    about time 3rd gen forum gets a happy ending
  15. Jul 13, 2019 at 9:47 AM
    #175
    17trdoffroadbel
    Turd Gen
    I get that. Why create customer resentment for yourself on an issue you're not even legally involved in? Kirkland wasn't getting blamed for a damn thing, yet there they are being Toyota's loyal little foot soldier and being nasty to me over BS. Now Kirkland has gotten the review they deserve, and Rodland is getting a really nice review on the site of their choice.
    tonered likes this.
  16. Jul 13, 2019 at 9:48 AM
    #176
    17trdoffroadbel
    Turd Gen
    It's really that bad around here?
    Honestly, joke's on me for not listening to the people here telling me that it's totally possible the tires and wheels were still unbalanced. But the irony is that had I taken them back to Discount for re-balancing, they'd still come out bad since they don't maintain their machine. So a good dealer or shop was really the only way to a happy ending here.
    tonered and fiftyxp[QUOTED] like this.
  17. Jul 13, 2019 at 1:46 PM
    #177
    Gixerkiller
    Dennis
    Taylor, TX
    From what I have been told by some folks when I was up there last year is Kirkland is happy to take your money, but, they will not stand behind anything they do.
    And if you ask about a known problem that is public knowledge, they get totally Saturn 5 rocket in the pooper butthurt.
    Just keep all the conversations, emails and all that, just in case, could be the point needed to ensure a buy back goes through.
  18. Jul 13, 2019 at 1:58 PM
    #178
    17trdoffroadbel
    Turd Gen
    They sure are. I spent almost 2 grand out of pocket there, and yet slowly the relationship deteriorated as I asked for the warranty service I'm entitled to.
  19. Jul 13, 2019 at 2:08 PM
    #179
    Gixerkiller
    Dennis
    Taylor, TX
    I know the feeling, I refuse to use Round Rock Toyota, Cedar Park, or Charles Maude Toyota
    Here in Texas due to the lack of interest in helping locate parts or answer questions.
    I now go 1hr south to a Toyota dealer in Bastrop just to ask about parts.... same dealer that told me Kirkland was wrong in the handling of you and your truck...
    Sucks, but, sometimes a 300 mile trip is needed just to get the right deal...
  20. Jul 21, 2019 at 8:56 AM
    #180
    17trdoffroadbel
    Turd Gen
    Hilarious little update regarding the wheels & tires. So I traded the MB racing wheels that I had on the truck for stock TRD Off Road wheels with another TW member who was kind enough to drive up from southern Oregon (!) for this. Had an appointment at discount tire. It took them five minutes to find me in the system, and then five minutes of explaining what we wanted (to switch the WHEELS only and keep everything else on the original vehicles).
    They got to work and in about 15min, a guy came out and asked if I had the allen key for the hub caps on my MB wheels. I said no, I bought these here new, I didn't get any allen key for them, you guys should have them. He said we were just asking, we'll keep looking. Then he asked where I had the wheels balanced, and not to go there again. I asked why not, he said because they put too much weight on the wheels. I told them that it was required in order to get them properly balanced, and he had a blank look on his face.
    Next, while the other TW member and I were chatting, his wife noticed they were putting my blizzaks on his truck, and his tires on my truck. We had to run over there and get some more blank stares until they understood that we only wanted to SWITCH THE WHEELS, NOTHING ELSE.
    Last but not least, they completely forgot about the slotted security lug nut socket that's required to get the lug nuts on and off for the MB racing wheels. I asked about it when they said they were done, and more blank looks. They started looking for it and turns out the guy driving the truck to us had it under his ass on the seat, where I had put it in the first place so they could see it.
    It finally all got done, but yeah. People are right, discount tire has gone to total shit. I've been going to their shops for years and it didn't used to be like this.
    tonered and kakwvu like this.
