dealer screw up BEWARE!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sellvjack, Jun 10, 2012.
  1. Jun 10, 2012 at 1:54 PM
    sellvjack
    sellvjack [OP] New Member
    jack
    corpus christi, tx.
    4x4 2011 tacoma 4.0
    leveling kit,alloy rims ,bfg all terrain
    my dealer put my serpentine belt on backwards (one direction belt). Has anyone heard of this happening? It destroyed the water pump after 10000 miles.
  2. Jun 10, 2012 at 2:06 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Yikes!
  3. Jun 10, 2012 at 2:07 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Serpentine belt on backwards! Hahaha! I gotta hand it to you, that's pretty original. Did the water pump impeller fail because of this?
  4. Jun 10, 2012 at 2:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont think the belts are directional.
  5. Jun 10, 2012 at 2:34 PM
    06ryan27
    06ryan27 Well-Known Member
    Aiken, SC
    12 DBL 4x4 SPORT
    3" RBP lift, anytime fogs
    Im sure he means routed backwards, but I would think it would overheat off the bat??
  6. Jun 10, 2012 at 2:34 PM
    ee1284
    ee1284 Well-Known Member
    Louisiana
    05 Prerunner Sport
    This doesn't make sense to me. How is a belt put on backwards?
  7. Jun 10, 2012 at 2:35 PM
    oldsman71442
    oldsman71442 Well-Known Member
    Jeff
    oahu HI/ Redding CA
    10 DC 4x4 TRD Sport
    I believe what he is saying is the routed the belt on the wrong side of the pulley which caused it to spin in the wrong direction?
  8. Jun 10, 2012 at 2:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Never heard of a serp belt being directional. Pretty sure that's not right. Did they put it on inside out? Like the smooth side of the belt running on the ridged pullies? That would be hard to do, but suppose it's possible.
    Did the truck overheat? The water pump spinning backwards from a mis routed belt would cause the truck to heat I am pretty sure. It would be really hard to mis route the belt and still have the tensioner work right.
  9. Jun 10, 2012 at 2:59 PM
    cc350
    cc350 Retired Member
    Note to self: Avoid Texas Toyota Service Shops.
  10. Jun 10, 2012 at 3:06 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    You smell something? I smell fishy story.
  11. Jun 10, 2012 at 3:10 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I don't even think it's possible to route the belt incorrectly, if you went to the different side of any of the pulleys it'd be either way to tight or way too long.
  12. Jun 10, 2012 at 3:15 PM
    Night
    Canada
    Plus I'm sure someone isn't going to ignore all logic because its nearly impossible to run a waterpump the wrong way unless aftermarket.
  13. Jun 10, 2012 at 3:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Well, it's his third post. The other two are about the same problem. I believe he's got a problem with his truck, sounds like he took it in for warranty service while on a trip, and the dealer he took it to said the belt was on backwards. He may not have any way of knowing other than to take the dealer's word on it.
    I'm in the trades too, there's some smart guys out there, and there are some knuckle draggers too. Some of them are dishonest, some like to make up crazy stories and point fingers at the last guy who did work on the machine.
    Hope you get it fixed OP. If you have any other details on how they put the belt on "backwards", I would really be interested.
  14. Jun 10, 2012 at 3:22 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I wish I could say I've never seen it done professionally before but..
    And not on a vehicle, they were stand alone pumps. and the noise they make would instantly alert you to a problem
  15. Jun 10, 2012 at 3:48 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    they might have routed the sep belt wrong. it's very easy to do. That is why you should always draw a pic and diagram of how the belt is routed. The thermostat doesn't open till over 180* degrees even if the water pump is running. I changed mine out since it went out, not to hard but just a lot of removal of stuff. Luckily i was also changing out my fan to an e-fan so i had a lot of room to work.
  16. Jun 10, 2012 at 3:50 PM
    05sctaco
    Ken
    Santa Cruz
    Of and your belt really isn't directional. they might have also flipped the belt upside down. where the ribbed part was on the smooth part. Regardless if it's only been 10k miles you should be under warranty? If not look up my water pump write up.
  17. Jun 10, 2012 at 6:39 PM
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    Add to list of things to do tomorrow: Open hood and see how it is possible to put belt on backwards
  18. Jun 10, 2012 at 6:40 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    WHAT :eek: they put blinker fluid in the headlight reservoir?
    Keep an eye on them.
    Don't ever let them use a standard crescent wrench on metric bolts.
  19. Jun 12, 2012 at 2:06 PM
    sellvjack
    jack
    corpus christi, tx.
    4x4 2011 tacoma 4.0
    Thank's for all the response! This sounds like two dealers having a squabble. As far as I can tell, there is no such thing as a directional belt. Possibly the dealer that told me the belt was backward wanted some warranty work. Got the truck home and still had a drip. Back to the dealer! The bypass hose was slit from a strand of wire from the seperated belt. Probably did'nt even need a new water pump!
  20. Jun 12, 2012 at 4:58 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Some belts are directional snow mobiles for example but not a flat belt no matter what way you put it on it's only going to turn the same way the engine does. Some things can be driven from the back side of the belt that will make a pulley turn the other way but I can't see how it can be miss installed it won't fit either too much left over or too little. If your water pump was turning the wrong way it would have overheated a long time ago.
