Dealer transmission service possibly not performed ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Apr 5, 2018.
  1. Apr 5, 2018 at 10:14 PM
    Bishop84
    Bishop84 Well-Known Member
    To clarify I mean hoses, instead of hardlines. Newer 4Runners use hardlines that you can't attach the fluid flush machines to. At least where I work. So we do standard drain and fills. We don't sell many 2WD taco's so I don't know how they are serviced.
  2. Apr 5, 2018 at 10:27 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    In regards to a taco, how do you check the level this way?
  3. Apr 5, 2018 at 10:45 PM
    BWilley
    BWilley Well-Known Member
    Brian
    Seattle
    2005 Tacoma DCLB Prerunner Desert Sand
    Skid plate, TRD Exhaust
    It's pretty hard for me to believe a dealer would say they've performed a service when they haven't. :crapstorm:
  4. Apr 6, 2018 at 1:40 AM
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    Shady, that’s theft man. Took your hard earned money and did nothing
    lynyrd3 likes this.
  5. Apr 6, 2018 at 1:57 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Better tip --------------- Keep the dealer out of it. Find a good independent and go from there. Easier said than done, I know.
    lynyrd3 and Coot83[QUOTED] like this.
  6. Apr 6, 2018 at 2:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    In the service manual and my experience says all the Tacoma's have hoses.
  7. Apr 6, 2018 at 3:00 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OP,
    I would have a friend call the dealer service dept to ficticiously schedule the same transmission service on a truck like yours. Then have the person ask questions regarding how the service is performed, thru the lines or whatever your concerns are, just to see what they say.
  8. Apr 6, 2018 at 5:55 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I’m going to take a closer look at the truck this morning and look for tool marks on the transmission cooler lines. Both off the transmission and the cooler in the front.
    If all else fails I’ll crack the overflow. For the paper towel test.
  9. Apr 6, 2018 at 6:18 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Stop taking your truck to the dealer. Take to a reputable transmission shop
    Demand a refund of the service they didnt do.
    lynyrd3 likes this.
  10. Apr 6, 2018 at 6:31 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    In order to set the ATF level, they would have pulled the overfill plug. The bottom of your pan is WAY too dry.
    lynyrd3, Radarninja and BillsSR5 like this.
  11. Apr 6, 2018 at 6:31 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    A lot of people don’t understand how the tech that is working on your truck gets paid. They hire the cheapest work money can buy and run off the high paid experienced guys. Out of that 120 bucks or however much you paid for the transmission flush, 6 bucks probably went into the techs pocket. Stop expecting the best work possible out of a guy that has a flag rate of 11 bucks a flag hour. Stop taking shit to the dealer you don’t trust. There are maybe 15 Toyota dealers in the greater Houston area and I trust 1 of them barely. The way our flush machine at my shop works is it will put in as much as it takes out of the vehicle. It hooks up through the cooler lines and there are attachments for about every single cooler line out there including hard fitted banjo style lines. Now being a tech, I don’t trust machinery, I always double check the level after the work is completed via a fill plug or a dipstick or whatever. That part is a little iffy to me personally. If you are that concerned go talk to the dealer calmly and explain that you believe the check plug wasn’t removed to verify fluid level and you are worried the service was performed improperly if not at all. A shop can get chaotic and a tech may have simply overlooked the service on the ticket if you had multiple things being serviced on the truck. Be calm and cool. If they start jerking you off then start all out war.
    tomwil and BassAckwards like this.
  12. Apr 6, 2018 at 6:37 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    when they use the flush machine isn't there a cleaning additive that is used in the process before re topping the off the fluid with the amount taken out.
    lynyrd3 likes this.
  13. Apr 6, 2018 at 6:40 AM
    AWilson013
    AWilson013 Almighty Dirt King
    Alex
    Seattle, WA
    2006 GX 470 Sport
    Matte Grey SCS F5s - 255/80R17 ST Maxx - Front Runner Slimline II - CVT Tent/Awning - 35w Morimoto HID Low Beams - LED High Beams - LED Fogs - AFE Dry Filter - BP-51s - Dirt King UCAs
    At my dealership this tech would get fired for not performing a service he had claimed to do. They keep a log of machine use, security footage, etc. to look into these claims. (I once called BS on a brake fluid flush after my fluid still appeared dirty after the service. Long story short- the adviser was very nice about it, but made me look like an asshole.)
    In this case, the service would have been done through the cooler lines. Depending on their machine it could either cycle new fluid in at the same rate as it comes out (most likely), or it could pump out the old stuff into a measuring device and then they can pump in the same amount.
    Let us know if they ACTUALLY didn't do it. Considering how the task is mostly automated, that would be a silly reason to lose your job.
    lynyrd3 likes this.
  14. Apr 6, 2018 at 6:45 AM
    Bebop
    Nick
    Some shops have this additive, some shops don’t use it.
    BillsSR5[QUOTED] likes this.
  15. Apr 6, 2018 at 6:52 AM
    #35
    ferntr33
    ferntr33 Well-Known Member
    first I thought those transfer systems are bad for the tranny. are new trannys made to do this? Also is there a dip stick? If its new ATF you should be able to smell it and see/feel it. I do it on my work trucks.
    Just saw this on the 3rd gen. Fluid exchange service. Probably explains why bolt is untouched. Might be different on 2nd.
    https://www.tacomaworld.com/threads/30k-service-quote.523937/
  16. Apr 6, 2018 at 6:56 AM
    #36
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Bebop likes this.
  17. Apr 6, 2018 at 7:07 AM
    #37
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    OP, did they do a flush or drain and fill?
    Look at how many quarts they charged you for.
    Pretty sure you only flush the tranny with the cooler lines up front.
    Having done a drain and fill on my taco six times or so, and how dry your pan is I would say they definitely did not touch the pan for a drain and fill. Area around drain plug is way too clean.
    For future reference, the drain and fill on these trucks is super easy to do. Quality torque wrench is required for the drain bolt. Every time I do it, 3.2qrts comes out and that’s what I put back in. Personally, I don’t even bother with the temp check overflow plug, shift sequence, and OBD jump like I used to, cause it’s always 3.2 qrts.
    Not advocating that method, it’s just worked for me for over 100k
    HandOfGod and lynyrd3 like this.
  18. Apr 6, 2018 at 7:15 AM
    #38
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    The other day I was doing an oil change on my truck and my neighbor asked why I dont just bring it to the dealer... reason #14 is because of shit like this. Either it isn't done, or it's done half ass, or a combination of the both. Finding a good tech or independent mechanic seems like hitting powerball now a days.
    HandOfGod, BillsSR5 and lynyrd3 like this.
  19. Apr 6, 2018 at 7:18 AM
    #39
    Bebop
    Nick
    You should’ve asked your neighbor if he hires somebody to do his wife. I’m not going to pay somebody for something I can do myself. And I can make sure it’s done right.
    lynyrd3 likes this.
  20. Apr 6, 2018 at 7:26 AM
    #40
    TacomaMike37
    13' DCLB MGM
    lol!
    lynyrd3 likes this.
