Dealership czn't figure out what the heck is wrong with my Taco.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUS, Apr 18, 2010.
  1. Apr 18, 2010 at 1:35 PM
    JUS
    JUS [OP] Member
    Justin
    Jax, Fl
    06 Prerunner, 08 4Runner
    I have a 2006 Tacoma 5 speed auto that I bought brand new with a 60k mile power train warranty. At ~48000 miles, I began to experience a shudder at lower RPM gear changes. I thought it was an ignition problem the torque converter was putting extra load on the motor and making some ignition flaw evident. I replaced the plugs with top-of-the-line iridiums to no avail. After another thousand miles or so, I began feeling a sensation like I was driving over rumble strip before gear changes. After some research, I found there to be a TSB stating that a bad transmission mount was the cause. I was skeptical, but took the truck to the dealer. The dealer replaced the mount, and obviously did not road test, because the problem was still as evident as ever. I live a pretty busy life, I took the truck home and drove it another thousand miles or so. The problem(s) were getting more severe each day. I took the truck back to the dealer, and they found a bulletin stating contaminants in the tranny fluid are causing bad shifts. They flushed the tranny 3 times, and filled it back up. They said the magnets in the trany pan were clean. This actually seemed to fix the problem for about 500 miles or so, then the issues gradually came back to their former glory. A new issue arose. The truck would herk and jerk at the 2-3 and 3-4 gear changes at slower speeds. At my earliest convenience (which took weeks), I got the truck back to the dealer. The service manager told the the tranny was toast, and he would put a new tranny and tq converter in. He said the issue was that improperly meshed gears created particulates in the fluid, which clogged to the solenoids, creating poor shifts. They gave me a rental car and kept my truck for nine days. When I got my truck back, all was well. ~800 miles later, the shuddering and rumble strip issues come back. I took the truck in two days ago and let one mechanic drive it. He thought the shudder was either the U-joints or the driveshaft itself (this truck has a 2 piece shaft), and the rumble strip issue was something in the differential. He was talking like they would not try to fix it, but rather replace everything behind the tranny(!). I brought the truck back today and drop it off and let the service manager drive it. He thinks part of the problem is the tq converter 'fluttering' and is puzzled about the rest. He told me they will bring in a specialist from corporate to look at my truck and will probably have it for some time. What do you guys think the issue could be?
    -JUS-
    ChadsPride likes this.
  2. Apr 18, 2010 at 1:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Tallahassee FL
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    What dealer are you seeing?
    my truck would shake from 10-20mph, and all of my u joints where trashed.
  3. Apr 18, 2010 at 1:44 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    omg im having the same problems with mine. mount is fine. but that same shit is happening to my tranny. let me no what the result is. i have to take mine i n tomorrow
  4. Apr 18, 2010 at 1:51 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    just got my u joints replaced as well. i was having a vibration or shuttering while driving and taking off and it was noticeable at all speeds but very prominant at just under 60km/h and highway speeds.. ONLY when there was a load on the drivetrain, even very subtle ammounts of pressure would casue this shake. they replaced the u joint and it rides like new.
  5. Apr 18, 2010 at 2:05 PM
    JUS
    JUS [OP] Member
    Justin
    Jax, Fl
    Ernie Palmer
  6. Apr 18, 2010 at 3:11 PM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    I couldn't tell you but it sounds like the dealership is definitely working with you on it. Be thankful about that. I'd hate for you to be one of those people that complain and get no where with growing frustrations. Good luck though. Let us know what they say. I hope your rental is another Tacoma. :D
  7. Apr 23, 2010 at 2:44 PM
    JUS
    JUS [OP] Member
    Justin
    Jax, Fl
    The dealership called this afternoon to tell me they had put a new transmission in it again. The service manager said it was contaminates in the fluid, which caused an issue with a solenoid controlling the tq converter, which caused "tq converter flex". The contaminates were supposedly left over from the first transmission, because they failed to flush out the cooler and lines when they put in the second transmission. I do not see how there could be enough contaminates in a cooler to get past the filter and ruin a solenoid so quickly...but what do I know? I asked about a break in period on the new unit, and he told me there is none, because Toyota broke it when it was REMANUFACTURED.
    Lets hope transmission #3 is the best of the bunch.
  8. Apr 23, 2010 at 3:07 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    woah 3rd tranny?
    wow
  9. Apr 23, 2010 at 3:15 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did they replaced your U-joints ?
  10. Apr 23, 2010 at 3:25 PM
    JUS
    JUS [OP] Member
    Justin
    Jax, Fl
    Nope.
  11. Apr 23, 2010 at 3:35 PM
    BlueT
    NorthEast
    Ok you have prerrunner right, with 60 k miles on original u-joints. I am going to site with your last mechanic saying your u-joints are crap.
    Dont be upset you are not first prerruner like that:D
    get them replaced and report back.
  12. Apr 23, 2010 at 3:37 PM
    BlueT
    NorthEast
    On the side note, they probably replaced the first tranny for nothing which sucks because who knows what tranny they gave you afterwords
  13. Apr 25, 2010 at 9:09 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    The trans. could create that shudder if the trans. started gear hunting while in lock up.
  14. Dec 10, 2016 at 6:36 PM
    JUS
    JUS [OP] Member
    Justin
    Jax, Fl
    ***ZOMBIE THREAD UPDATE***
    To finish the story from 2010, the third transmission they put in my truck was trouble free for 60k miles. Last week, the exact same issues arose! Clunky shifts at 2-3 and 3-4, with a "rumble strip" hard shift into 5th.
    I took it to the dealership and they said replace the transmission (imagine my surprise). Instead of plopping down $4400 for a FIFTH transmission, I opted to see a specialist. I took the truck to a very well respected transmission shop in town. He pulled the pan and told me the fluid was "clean as a whistle." He did say the EPS could be bad, causing abnormal fluid pressure. We replaced the solenoid and serviced the unit, but nothing changed. He said he was baffled, but was convinced that nothing was mechanically wrong with the transmission. He thought it was actually a computer problem, and the tranny was just trying to do what the computer told it to.
    Tonight I made a discovery. In trying to avoid the awful 5tg gear shift, I dropped the shifter into 4. The truck ran beautifully with very smooth shifts into 3rd and 4th. When I shifted back to D, those same gears clunk. What could be causing this?! I think it IS the PCM, and perhaps there was never anything wrong with the previous transmissions.
    Ideas?
    -JUS-
    TacomaMike37 likes this.
  15. Dec 10, 2016 at 7:33 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    06 TRDORAC Prerunner
    5/3 lift on 33s. trd intake, tbs, headers, and mbrp cat back. 13 steering wheel and headlight/turn signal switch swap. l.e.d bed light. maxtracs, ADS extended travel coilovers, camburg uca, dakar leaf packs, fox 2.0
    sounds like the tcm might have a short in it. could also be a shifter cables being short or kinked to make the tcm think it in between two gears. possibly a bad ground even.
  16. Dec 10, 2016 at 8:51 PM
    jsnm23
    jsnm23 There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    I had what sounds like the same problem when tranny would shift from 4th to 5th under load. Turned out to be a cracked spark plug. I know you said you replaced em but it might be worth it to pull em and inspect them for hairline cracks.
    JUS likes this.
  17. Dec 11, 2016 at 6:28 AM
    2.7taco
    Texas
    If you can manually shift the transmission into 4th and everything go back to normal I would pull the valve body to verify that it is in good condition. If it is in good condition I would end up going through the wiring and looking for shorts. After going through 3 transmissions I'd say you probably have some type of electrical problem. Check your grounds as this commonly is what is often neglected and a culprit to alot of problems.
    jsnm23 and JUS like this.
  18. Dec 11, 2016 at 11:21 AM
    jsnm23
    2011 mgm TRD OR 4x4
    I agree with 2.7 taco. I think you have an electrical problem somewhere
  19. Dec 11, 2016 at 12:56 PM
    VolkswagenTaco
    VolkswagenTaco Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    Sounds like it's a ford...
    07 sport 4x4 and Justinlhc like this.
  20. Dec 11, 2016 at 1:14 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Optional
    Brabus
    I has truck it has things and stuff derrrrrr
    Cut your losses.
    frejil and airrage like this.
