Dealership can't figure out what the heck is wrong with my Taco.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUS, Apr 18, 2010.
  1. Dec 12, 2016 at 10:29 AM
    BahiaTaco
    BahiaTaco Active Member
    Timo
    Los Angeles
    15 Prerunner SR5
    SnugTop Topper Ride Rite Bags Air Lift Compressor Yakima Roof Rack Skidplate Ultra Gauge Side steps TRD off-road wheels
    Hah. Interesting. My 2015 does a similar thing. Started at around 5k miles, now at 12k. Basically all gear changes at low throttle result in a slightly clunky shift with a subtle shudder. Not enough to bother me too much but it's not consistent. It sometimes shifts very smoothly, especially right after cold starts. Put it in "4" and it's a lot smoother. Could the calibration be that different between"4" and "D"? Different line pressure perhaps? I asked at the dealer but because it's subtle they are quick to conclude it's "normal".
    Old School likes this.
  2. Dec 12, 2016 at 5:05 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Cape Breton Island Nova Scotia
    09 Tacoma 4x4 TRD Off Road
    We had a 2007 FJ Cruiser that had the same problem. The only solution the dealership had was replace the tranny (6K but we were under warranty).
    We traded the FJ within a month of the new tranny being installed.
  3. Dec 12, 2016 at 5:10 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    Not that I feel it's related or anything, but the v6 engines aren't supposed to run iridium plugs. Figured I'd mention it.
    ElementalJ, JUS[OP] and 2.7taco like this.
  4. Dec 12, 2016 at 5:28 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    If the OP's truck is a 4.0 and the plugs are original the OP is probably over due.
  5. Dec 12, 2016 at 5:34 PM
    2.7taco
    Texas
    The dealer may have swapped the transmission but I'm wondering if they swapped the torque converter.
  6. Dec 12, 2016 at 5:52 PM
    JUS
    JUS [OP] Active Member
    Justin
    Jax, Fl
    19 TRD OR, 08 4Runner
    Yes. Twice.
    2.7taco[QUOTED] likes this.
  7. Dec 12, 2016 at 6:13 PM
    2.7taco
    Texas
    Do you know if they reused any sensors?
    Saras likes this.
  8. Dec 12, 2016 at 6:33 PM
    JUS
    Justin
    Jax, Fl
    I have no idea.
  9. Dec 12, 2016 at 9:25 PM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    OP mentioned that he switched the plugs for iridiums. The plugs aren't old/due for change, but they are the "wrong" ones.
  10. Dec 15, 2016 at 3:50 PM
    JUS
    Justin
    Jax, Fl
    I changed the plugs and cleaned the throttle body. The plugs were toast, with gaps as wide as .0060 and burnt off electrodes. The issue has definitely reduced in frequency and severity, yet still persists. This leads me to believe it has to be an ignition fault of some variety. I have ordered a Bluetooth OBD2 scanner, and plan to use the Torque app to hopefully identify the source of the fault. I suspect a bad coil pack.
  11. Dec 15, 2016 at 4:01 PM
    Old School
    Old School You are ignoring covfefe by this member.
    This sounds familiar to what I've been dealing with...:annoyed:
  12. Dec 15, 2016 at 4:17 PM
    Marcus Israd
    Marcus Israd Well-Known Member
    Concord, CA
    09 TRD Sport SR5 4x4
    2009 Tacoma 4.0L Double Cab 4x4 Pyrite Mica Front: Yukon 4.88's ARB Locker Bilstein 5100's/Eibach Springs Camburg Uni-Ball UCA's Solo Motorsports Steering Rack Marlin Crawler LCA & Frame Braces Wheel bearings/Hubs by "05taco4x4" Crown Extended SS Brake Lines Stoptech Cryo Slotted Rotors/TRD Pads Wheeler's Super Bump Stops Rear: Yukon 4.88's ARB Locker Bilstein 5125's/All-Pro Expo Leaf Springs Ruff Stuff U-bolt Flip Crown Extended SS Brake Lines Timbren Bump Stops Intake/Exhaust: TRD CAI w/ AFE Dry-Flow Filter & TRD Exhaust (cut at axle) Lighting: Ultimate Headlight Upgrade by "crashnburn80" Fog light anytime mod Baja Designs S8 20" Light Bar Baja Designs Squadron Pro Fogs Armor: Pelfrybilt Steel Front Bumper BAMF Steel Skid Plates BAMF Weld-on Rock Sliders BAMF Front Bumper Supports Wheel/Tires: Pro Comp 17"x9" Wheels (x5) BFG KM3's - 35/12.5/17 Recovery: Warn M8000s Winch w/ Synthetic line Misc.: SoftTopper Ultra-Gauge Hurst T-handle Shift Knob Energy Suspension Urethane Radiator Support Bushings Pro Eagle Jack Midland CB Pine Tree Air Freshener Fluids: Amsoil
    I had very similar issues. Spark plugs fixed it. NGK-R's..
  13. Mar 28, 2017 at 5:53 PM
    JUS
    Justin
    Jax, Fl
    Spark plugs did not fix the issue.
    This passed weekend my tranny cooler ruptured, contaminating the coolant with tranny fluid and vice versa. Google: Dreaded Pink Milkshake. After a new radiator and a very expensive engine and transmission flush, the taco is up and running again. Poorly.
    My theory and concern is this: the poor shifts may be caused by an elevated fluid pressure within the transmission (from any cause). This elevated fluid pressure also caused the tranny cooler to fail, and may again.
    Thoughts?
  14. Mar 28, 2017 at 6:13 PM
    2.7taco
    Texas
    Okay now I hate to be the one to tell you this but you have officially lost your friction discs in the transmission. The glue holding the friction material will begin delaminating after being exposed to coolant. The transmission my need rebuild soon to correct. Personally if I were you in would take the truck to a reputatable transmission shop and have it gone through.
    The SLU valve controls line pressure if I remember correctly. Line pressure would have to go absolutely wild to burst the cooler tube in the radiator.
    I'd bet it was plugged with debris causing the burst. Bad fuel injectors will cause an engine to run rough. Smell your oil for gasoline.
    JUS[QUOTED][OP] likes this.
  15. Mar 28, 2017 at 6:14 PM
    #35
    JUS
    Justin
    Jax, Fl
    Because everything is better with pics:
    07 sport 4x4 and 2.7taco like this.
  16. Mar 28, 2017 at 6:44 PM
    #36
    2.7taco
    Texas
    Man that's bad.
    I'd make the dealer pay but of course it's never their fault.
  17. Mar 29, 2017 at 3:37 AM
    #37
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    With all these problems, you would've thought the dealer would've given you a new truck
  18. Mar 29, 2017 at 6:14 AM
    #38
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    Low on ATF Fluid,Drain at Pan Drain Plug, Refill cold with 3.2 Quarts ATF WS and Replug, Operate in all gears shift back and forth, and drive for a few miles and 30 minutes or more,should be good after that,and recheck for leaks ! DONE!
  19. Mar 29, 2017 at 7:12 AM
    #39
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If the truck is by some miracle still under the original warranty it would likely qualify under Lemon Law. It would have back in '10 more than likely.
    If not I would probably sell it for salvage and walk away from it.
  20. Mar 29, 2017 at 5:07 PM
    #40
    Mac4Willy
    Mac4Willy Member
    Bill
    Boardman,Ohio
    2012 tacoma
    none yet, but looking!
    Sad. Terrible things have happened to you. Hope all will eventually work out. Sorry bro.
