Dealership rust prevention
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bando, Mar 10, 2020.
  1. Mar 11, 2020 at 5:18 AM
    #61
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Looks nothing like KROWN, which is black and oily. KROWN is the best, been using it for decades, proof is in the pudding.
    There is only one way to beat rust. Read my signature....
    Rising Eagle[QUOTED] and Dagosa like this.
  2. Mar 11, 2020 at 5:22 AM
    #62
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    Correct. My 16 just got frame plugs.
  3. Mar 11, 2020 at 5:31 AM
    #63
    HeyWannaTaco
    HeyWannaTaco Well-Known Member
    Dan
    Ontario
    2019 Red DCLB SR5
    OVTuned, OKX Skids, AVS In-Channel, N-fab Predators
    Any older cars that our family had Ziebart done too... rusted after three years.
    P-Dawg likes this.
  4. Mar 11, 2020 at 5:48 AM
    #64
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    when i had my new front diff put in (per the tsb) they want me to come back in the next month to have my frame done. from what i saw- all the 2020s have it done, and it looks like it would actually work they way they did it this time. I have to take my sliders off before they do it, he said i could leave them on, but they could do a better job with them off. they need a post winter clean up anyways.
  5. Mar 11, 2020 at 5:58 AM
    #65
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    These are good points.
    But, if the material were petroleum based instead, then it may not harden and acts as an insulator and helps mitigate further rust. “ almost” nothing stops iron from its incessant jury to become iron oxide. But, we can slow it down significantly. This is why spaying oil based products, even on rusted areas, helps a lot. Will it wash away ? Eventually yes. That’s why rust mitigation is really a periodic endeavor.
    Anyone who was in the navy and stationed on a “ tin can”, knows fighting rust is a continual process.
    P-Dawg likes this.
  6. Mar 11, 2020 at 6:11 AM
    #66
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    If the motor home was driven over the same roads in the rust belt every day of every year like a truck through the entire winter, I would be surprised if it lasted any longer then a truck frame......well, at least something not a Taco.
    Silentshredr and TacoJova like this.
  7. Mar 11, 2020 at 6:22 AM
    #67
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    In the meantime, you could always slide under the truck and literally, paint the rusted exposed areas with red wheel bearing grease using a foam brush.
    GreyBaldTaco likes this.
  8. Mar 11, 2020 at 6:24 AM
    #68
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    It it is grease and a petro or biodegradable substitute based product, it’s well worth it.
    GreyBaldTaco[QUOTED] likes this.
  9. Mar 11, 2020 at 6:26 AM
    #69
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    You’re reading my mail. ;)
    Tocamo[QUOTED] likes this.
  10. Mar 11, 2020 at 6:57 AM
    #70
    KVTaco
    KVTaco Well-Known Member
    Anywhere to see this online? I dont see it on Toyota Owners nor through a Google search. 2019 Tacoma OR in Connecticut, one of the named states.
  11. Mar 11, 2020 at 7:01 AM
    #71
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    19s aren't part of this yet.
    KVTaco[QUOTED] likes this.
  12. Mar 11, 2020 at 7:01 AM
    #72
    Timetraveler66
    Timetraveler66 Well-Known Member
    But it will be!!
  13. Mar 11, 2020 at 7:02 AM
    #73
    GreyBaldTaco
    2019 F150 5.0
    I was going to ask to see your crystal ball, but you are a time traveler, so you'd know.
  14. Mar 11, 2020 at 7:21 AM
    #74
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    I use some stuff called “Corrosion Stop” from PB Blaster. It’s grease but is thin so it sprays well. $4-6 a can and I used 2 on my Tacoma. I sprayed the frame, axles, drive shaft, and everywhere I saw rust forming on used Tacoma’s. Yes, I crawled under used 3rd gen Tacoma’s to see where the rust starts. It isn’t permanent but is thicker than oil so it sticks well and lasts. I’ve had great luck using it on areas that already started rusting as well. Stuff like this is why you’re lucky if you buy a used car I used to own, I treat everything like a priceless Ferrari. Been using this stuff ever since I bought two new Wranglers, aka the 4wd Rust Buckets.
    FirstTimeTaco2020 and Dagosa like this.
  15. Mar 11, 2020 at 7:22 AM
    #75
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    2019 models have the lower portion seam sealed. I'd rather have them wax flooded.
  16. Mar 11, 2020 at 7:24 AM
    #76
    HeyWannaTaco
    Dan
    Ontario
    2019 Red DCLB SR5
    Krown for the win!
  17. Mar 11, 2020 at 7:43 AM
    #77
    GOLFISHUNTS
    GOLFISHUNTS Toyota Parts
    STEVE
    Michigan
    2017 TRD SPORT, INFERNO
    am Pro grille w/lights, black tailgate letters, black badging, 265-70-17 Duratrac "c", Rear seat platform,
    I'm getting ready to have our Toyota sister-store (I'm a Honda parts manager) do this to my '17 TRD Sport. Until two years ago I worked at our Toyota store for 13 years so I'm friends with the tech that does this job and the solution they use is actually a bees wax based formula. As terrible as it looks it is supposed to be oozing out everywhere or they didn't do a good job. Kinda like packing a wheel bearing until the clean grease oozes out the other side. I plan to wipe down the bulky areas of ooze with a rag and spread it on the outside of the frame wherever possible before it fully hardens.
    Evlkarl likes this.
  18. Mar 11, 2020 at 7:48 AM
    #78
    Timetraveler66
    If you are friends with them ask them to spray the entire frame while its up and clean. Slip the dude a $50
    Evlkarl likes this.
  19. Mar 11, 2020 at 12:20 PM
    #79
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    i just put a hitch on my new 2020 - I did not see any coatings??
  20. Mar 11, 2020 at 12:23 PM
    #80
    Canufixit
    New England
    IS this Wool wax ?? Kellsports products?? / Fluid film ? https://www.kellsportproducts.com/
