Dealership wants $750 to replace idler pulleys and belt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colbya48, May 10, 2023.
  1. May 10, 2023 at 9:11 PM
    Colbya48
    Colbya48 [OP] Member
    Colby
    2019 Voodoo Blue TRD Pro
    I’ve started getting a chirp when I drive so I took it in to the dealership. They told me the belt is glazed and the pulleys are going out at only 22k miles. They want $750 to replace all of the idler pulleys and belt, which seems to only cost around $350 in parts. Am I being scammed here? I don’t have a way to install the parts myself so i would have to pay someone to do it but $750 seems really steep
  2. May 10, 2023 at 9:24 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Ask for what the book time is on the job.
    At $350 in parts, and $120 and hour, I can see the job being 3 hours, but I don’t know.
    EDIT: I just reread, yeah, at 22k I highly doubt either are bad.
    HondaGM and stealthmode like this.
  3. May 10, 2023 at 9:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's silly.
    HondaGM likes this.
  4. May 10, 2023 at 9:30 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    1...spray wd 40 on the belt with eng off , better on the part that touches the pulleys, then close hood before you start it so it wont sling,
    2...but yours is almost 5 so could be dried out belt but try a new belt before replacing pulleys
    HondaGM and atc250r like this.
  5. May 10, 2023 at 9:30 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Mine was doing the chirp when I started it up, told the service advisor when I was getting my oil changed. So I had him replace my belt and all is good and I have a little over 83xxx on my 17.
    HondaGM likes this.
  6. May 10, 2023 at 9:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did this include the belt tensioner?
    HondaGM likes this.
  7. May 10, 2023 at 9:42 PM
    MGMDesertTaco
    Serpentine belt part number 90916-A2037 ; about $56 online.
    Plenty of YouTube videos showing how to replace. Pulley's are probably fine. :notsure:
  8. May 10, 2023 at 9:45 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
  9. May 10, 2023 at 9:58 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Replace the belt. No way pulley/tensioner bearings should be going out this early.
  10. May 10, 2023 at 10:15 PM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Here to put in another "inspect and replace the belt, preferably yourself" comment like everyone else in the thread. :thumbsup:
    thomasburk and HondaGM like this.
  11. May 10, 2023 at 10:18 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can they show you how the belt is "glazed"? Never heard of a belt failing that way.
    Lower idler replacement requires unbolting the oil cooler from the engine. If you go through deep water or mud, that'll be the first to go.
    HondaGM and Otterstuff like this.
  12. May 10, 2023 at 10:30 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    My truck had around 30-40k miles on it when same thing happen to me after a trip out to Death Valley. Dealership wanted to charge around the same because you had to buy everything as a kit. Not individual parts. Went to the parts department and salesman was shocked to hear what happen. Ended up pressure washing and just cleaning everything up real good. 60k miles later no issues.
    auskip07 and HondaGM like this.
  13. May 10, 2023 at 10:33 PM
    Colbya48
    Colby
    They never showed me anything. Just made me wait for almost 2 hours and told me that the pulleys and belt were making noise and that it needs replacement.
    Deepest water I’ve been through probably a foot, been through like 2 feet of snow so neither should have reached the pulley. Regardless I agree with everyone else, the pulleys should be fine. There’s no way all 3 went out at once
    HondaGM and henryp like this.
  14. May 10, 2023 at 10:34 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Please don't do this.
  15. May 10, 2023 at 10:45 PM
    RIX TUX
    its all the same
    asuchemist, HondaGM and Colbya48[OP] like this.
  16. May 10, 2023 at 11:37 PM
    dr4g1116
    If you try to squeak life out of a dying belt by spraying WD-40 on it (the can costs as much as the belt) then just step away from the tools.
    Why would you want to lubricate a slipping belt?
  17. May 11, 2023 at 3:38 AM
    andthen
    andthen Well-Known Member
    Fred
    22DCLB Lunar Rock
    Just in case the pulley is seized and you need the belt to slide over it, obviously.
    I kid, I kid.....take the belt off, inspect the belt, spin the tensioners and accessory pullies, eyeball everything else, replace or come up with a plan for whatever's needed.
    $750 for a belt at 22k, find a better mechanic.
  18. May 11, 2023 at 3:53 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    A noisy belt I can believe, "all" the idlers being bad at 22K I can't.
    Any reputable independent shop can change the belt for you in less than a 1/2 hour.
    A Gates or Dayco brand belt is around $40 at any parts house if you want to try it yourself.
    Personally I don't believe spraying anything on the belt is the correct way to proceed. Good belts are quiet and bad ones are noisy.
    Even if you make a bad one quiet you don't make it good.
  19. May 11, 2023 at 4:27 AM
    Unorgnl-V
    Unorgnl-V Well-Known Member
    2017 superwhite TRD OR
    F that. Seems weird that the idler pulleys would go that soon. Like others mentioned i would just replace the belt itself first. Its a cheap enough part and easy enough job to do yourself with little knowledge.
    i went by this video and swapped mine out in about 15 mins with a breaker bar and 14mm, or and independent shop can do the same.
    https://youtu.be/ewr-bdAOxh8
  20. May 11, 2023 at 4:32 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I'd start with a new belt first and go from there.
