Death Wobble With No Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColdWaterTaco, Mar 31, 2010.
  1. Apr 1, 2010 at 6:42 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I measure weight in 16ths, and distance in 10ths.
  2. Apr 1, 2010 at 6:44 PM
    nvdeserted
    Reno, NV
    Put the rear on jackstands, put it in gear and let the tires spin and see what wobbles.
    Disclaimer: YOU DID NOT HEAR THIS FORM ME.
  3. Apr 1, 2010 at 7:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ha ha :D
    OZ
  4. Apr 2, 2010 at 9:24 AM
    ColdWaterTaco
    ColdWaterTaco [OP] Member
    Oregon
    10 TRD 4.0 4WD
    Leaf Spring TSB Bilstein 5100s (all 4) No Lift PIAA Ion Fog CB Radio 275 65 R16 GY Silent Armors
    Update:
    1. Tires are balanced, wheels aligned, shocks and leafs checked over and torqued.
    2. Test drive with owner of dealership and wobble still apparent. He applied light brakes along with light gas this exaggerated the wobble to the point that the truck shuddered like crazy while barely moving - maybe 8 MPH. Maybe the transmission.
    3. Dealership contacting Toyota for direction on how to proceed with problem.
    So far, everybody is handling this in an upright and honorable way.
  5. Apr 2, 2010 at 10:13 AM
    OZ-T
    Peter North
    British Columbia
    Good luck , hope they figure this one out for you soon ,
    Let us know when you get some news ,
    OZ
  6. Apr 5, 2010 at 12:50 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    updates?
  7. Apr 6, 2010 at 2:01 PM
    ColdWaterTaco
    Oregon
    10 TRD 4.0 4WD
    No diagnosis yet. Hopefully sometime in the next few days.
  8. Apr 6, 2010 at 2:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  9. Apr 6, 2010 at 2:29 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    My '09 and '10 has had a minor shimmy since new. Not nearly as bad as you describe though. From 5mphish to 20ish. I just assumed it was typical U-Joint vibration. Any time the height of a vehicle is changed, the driveline alignment can become an issue. A standard trans is slightly more susceptible to this.
  10. Apr 6, 2010 at 2:44 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Almost sounds like a bent rim.
  11. Apr 19, 2010 at 10:11 AM
    ColdWaterTaco
    Oregon
    10 TRD 4.0 4WD
    Final Words for Now:
    Dealer tried TSB Auto Trans Mount: No Effect, other than less 1800-2100 RPM "buzz" (I also started using higher octane gas which helps in this regard).
    Carrier Bearing Shim: No Effect
    Put Stock 3 Leaf Pack Back on: Back to Normal.
    So, it was excessive axle wrap w/ the TSB Leafs which are actually less stiff with no weight in the back. I'll get some Deavers custom fitted to solve both problems, if possible. Great truck otherwise.
  12. Apr 19, 2010 at 10:28 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Thanks for the update! Interesting stuff. First I have heard of a problem with the spring TSB. Usually people rave. Please come back on and let us know how the Deavers work out for you.
    Thanks again. Rep for actually updating this issue. So many people let these types of threads die with no resolution.
  13. Apr 19, 2010 at 10:43 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    My old jeep did that death wobble crab before too. The front steering shock went out.
    Sounds like the problem on your toy might possibly be the driveshaft? I could be wrong though.
  14. Apr 19, 2010 at 3:30 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    This is intresting.
    I wonder if the leaf springs (TSB ones) were the same exact size. If one of them was slightly different, it would cause the driveshaft to operate at a different angle. You would have noticed a slight different in ride height in the rear. Somthing is up with this. There is more to this story then the dealership is giving you.
