Debate: lift vs no lift 285s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TCprerunner, Jul 16, 2013.
  1. Jul 16, 2013 at 9:13 AM
    TCprerunner
    TCprerunner [OP] Well-Known Member
    Back story..
    I am getting 285s I also will be getting icon mid travel setup at some point but not any time soon. Anyways, since I will have my 285s first and I want to run the least amount of lift possible I am going to trim/cut beat the shit out of everything to get as close to full flex on factory suspension as possible and I don't see why I would having a problem doing so..
    Measurements at full flex on 265s in the rear I have we'll over 1" clearance everywhere but the top of the fender ( the lip to be exact ) and I'm at about
    1-1/4 " there so would for sure need cut rolled..
    Up front I already know a lot of the plastic liner will need to be removed and a lot of work on the cab mount and beating the shit out of the pinch weld but other then that I don't see any problem areas that trimming (including the listed areas) won't fix ..
    I almost know this is possible just from measurements I have been taking over the last couple weeks. What do others think.. People who have tried and by try I don't mean minimum trimming and possibly spacers because of the uca if that's a issue.
  2. Jul 16, 2013 at 9:26 AM
    TCprerunner
    Sorry going on a 17x8 wheel with 4.5 backspacing and going to be running bfg at ko ta's 285/70r17 or cooper discovery stt 285/70r17
  3. Jul 16, 2013 at 9:29 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  4. Jul 16, 2013 at 9:30 AM
    TCprerunner
  5. Jul 16, 2013 at 9:41 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Also maybe look into the Cooper STMaxx. Hearing lots of good stuff from friends who run them!
  6. Jul 16, 2013 at 9:42 AM
    TCprerunner
    Will do!
  7. Jul 16, 2013 at 3:53 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You can do it no problem. In fact you are doing it the right way unlike 99% of the trucks on this site. You see, lift or no lift when the shock is at full compression the tire ends up stuffed in the same place. 'Course, spacer lifts reduce the uptravel some...and drop bracket lifts change where the tire tops out, but still should be checked the same way. I pop the coilovers out, put the tires back on and let the truck off the jack. I have chalk handy and mark anything that rubs. Chop, cut, hammer it out of the way and let it off the jack again... then turn the tires, full lock to lock, and trim some more. Don't forget to leave a little more clearance than you need to account for bumpstop compression and frame flex...
  8. Jul 16, 2013 at 4:28 PM
    TCprerunner
  9. Jul 16, 2013 at 4:31 PM
    TCprerunner
    Thank you, you are just backing what I already knew I could do and was told would be in usable and pointless.
  10. Jul 16, 2013 at 5:20 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Looks like glass upfront.
  11. Jul 16, 2013 at 5:25 PM
    TCprerunner
    Read his build he has a lot more then glass he was showing pictures of the trimming cutting and bfg modifications and the best way to so it.. Almost positive the Torres there are a lot bigger then 285 :p
  12. Jul 16, 2013 at 5:27 PM
    TCprerunner
    Rubbing makes you a cool kid, right?
  13. Jul 16, 2013 at 7:44 PM
    TCprerunner
    Lol
  14. Jul 16, 2013 at 10:19 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Those pics are crazy?! You'll have to do a CMC for sure, and a $hit ton of cutting and crap to get a 285 70 17 to fit non lifted.
    Subbed'
    Thanks,
    Brett
  15. Jul 16, 2013 at 10:29 PM
    TCprerunner
    It's going to happen and I will keep everyone updated just a matter of time or getting my tires sold to pay for new ones.. Pretty sure his pictures are 37" h1 setup though a lot bigger then what I will have as I said though I could be wrong about his pictures cause he did run 33"s for awhile
