Debating 883 or 884 OME Coils
Discussion in 'Suspension' started by Mavrick, Mar 18, 2018.
  1. Mar 18, 2018 at 7:55 AM
    Mavrick
    Mavrick [OP] Well-Known Member
    2015 DCSBOR
    I have a 2015 double cab off road with stock suspension and need new shocks, in doing so I also want to swap out my front springs to stiffen up the front just a bit to deal with the mushy stock suspension. I don't really want to lift this truck but a little is ok if I don't have to lift the rear and that's why I'm leaning towards the 883 coils in the front. I'm posting this because there isn't much info out on running 883's on a gen 2 and looks like most are running the 884's. I plan on getting 5100's and setting the front at 0.
    Does this sound like a good plan?
  2. Mar 18, 2018 at 7:59 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I think keeping your coils and going with 5100s set on the second setting (0.85" lift) would be a good option. When I did this it was night and day over the original setup. Great ride.
  3. Mar 21, 2018 at 7:34 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I'm running 5100/883 on my 2.7l access cab, and it gave me 1.5" lift and rides much firmer in a good way. If you're just looking for a better ride with minimal lift, I'd go that way. 884 might give you 1.5"+ and leave you wanting to lift the rear too.
  4. Mar 21, 2018 at 7:44 PM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I got a full 3" with 884s on my 2.7 AC :eek:
  5. Mar 21, 2018 at 7:56 PM
    GDT
    Yeah that's why I went with 883s
  6. Mar 23, 2018 at 10:11 AM
    Mavrick
    2015 DCSBOR
    Your truck is lighter than mine so it make sense that you would get more lift. I would expect to get an inch on mine which is about where I want to be.
    What setting are you guys using on your 5100s? Did you use the bottom notch or go up one? I was planning on going with the bottom notch for the lowest setting.
  7. Mar 23, 2018 at 10:24 AM
    Doogz
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Yep I did the bottom notch. That should give you that inch.
  8. Mar 23, 2018 at 10:30 AM
    Mavrick
    2015 DCSBOR
    Ok cool thanks
  9. Mar 25, 2018 at 6:39 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I got ~1.5" on my Access cab with 883's. I put in a add a leaf in the rear to keep the rake.
  10. Oct 9, 2022 at 5:21 PM
    leduc4wd
    leduc4wd Well-Known Member
    Derek
    Kansas
    ‘23 DCSB TRD Off-Road / ‘17 Pro 4Runner
    Old thread I know but curious how that worked out for ya? Thinking of doing the exact same
  11. Oct 12, 2022 at 6:08 PM
    stec06
    stec06 Well-Known Member
    Sam
    SoPines
    '15 DCSB PreRunner 2.7
    Same here. How'd the 883s turn out? I have a 4cyl Prerunner double cab with 140k miles... want to refresh the suspension without going crazy and the 5100/883 combo looks good. Otherwise, I think I'd just get some 4600s, use the stock coils, and call it a day.
