Decent system without a sub?
Discussion in 'Audio & Video' started by FFRNDAN, Apr 4, 2011.
  1. Apr 4, 2011 at 3:36 PM
    FFRNDAN
    FFRNDAN [OP] Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    The stock non-JBL in my 2009 Access Cab is weak. I miss the system I had in my Jimmy, but don't want to lose a lot of space for a sub. I want to upgrade the existing Headunit and speakers so I can get that better low end back.
    I searched, but couldn't find anyone wanting to do a similar setup. Any suggestions, advice, tips? Thanks!
  2. Apr 4, 2011 at 4:49 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Get a new HU, good set of components upfront and run an amp to them. Put the amp under the passenger seat.
  3. Apr 4, 2011 at 6:03 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    If you are willing to spend a bit, remember the bigger the cone, the better the bass. And remember a proper install makes a bigger differences than anything else.
    Check out ItalyonStylons build :http://www.tacomaworld.com/forum/audio-video/59941-my-deadening-project.html
    And spend that much time on your door deadening.
    Then spend the dollars on a good amp, and some quality components. I am not a big fan of passive, or a huge ID fan, but it seems the ID XS69 components would suit you well.
    I would also consider many a 6.5 or 7" component sets.
  4. Apr 5, 2011 at 1:01 AM
    FFRNDAN
    Dan
    Edinburg, Oh
    Does anyone know what the top-mount depth is for the rear speakers?
    I got to thinking, and had an epiphany. What if it was possible to replace the speakers in the rear doors with small subs? Not ideal, and haven't even thought about an enclosure. Maybe.
    Another option would be mounting a custom enclosure to the rear wall in between the seat backs, above the rear console. Just thinking out loud here.
  5. Apr 5, 2011 at 4:20 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    I asked that question too - and although I still haven't pulled the door panels to look - most I talked to seemed to think the doors lacked sufficient metal structure to support the vibration a sub would put out.
  6. Apr 5, 2011 at 6:39 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    You say you have a 09 Access Cab....09+ don't have speakers in the rear doors. They are up in the headboard and a pain in the ass to get to.
  7. Apr 5, 2011 at 4:11 PM
    FFRNDAN
    Dan
    Edinburg, Oh
    Wow, I guess you are right. Cut me a little slack, Iv'e had the truck for less than a month now. Those speakers are definitely going to be used for my mobile CB/HAM install someday. :D
  8. Apr 5, 2011 at 4:20 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I could never hear any sound out of the rears in my 09 AC.
    I installed a set of BA PRO 60's and I have more than enough bass for me. I also have a JL Audio driving the components.
    Check with Marv and get install rings he sells they work. Also install some sound deadening in the doors it will make a huge difference.
    Go to a high end audio shop and hear the difference.
  9. Apr 5, 2011 at 4:37 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    From my experience w/o a sub, and I know I will get ragged for saying this. The factory speakers for whatever reason have better bass. :rolleyes: But on my last truck I had the same thought. Didn't want a sub box and with the amount of bass that the factory's had I thought that if I upgraded to some good aftermarkets it would only get better. I was wrong. Yes the highs were better, but the bass was a big loss, couldn't get any decent bass, and wound up adding a sub anyway. And this was with adding 6x9's in the front doors which replaced if I remember correctly 6 1/2's and upgraded the rear doors from like a 4 1/2 to 5 1/4. I did extensive research and bought what was supposed to be the best in terms of bass output. I was highly dissapointed. Of course I didn't do the components, maybe that was where I went wrong? :notsure: But they were about twice the price and I remember how good some 6x9's could sound in the rear deck of a car so I thought maybe I could get decent bass in the doors. :rolleyes: Oh, and I did have an amp also. Good luck.
  10. Apr 6, 2011 at 10:14 AM
    FFRNDAN
    Dan
    Edinburg, Oh
    I thought Mr. Marv had a sub-forum on here somewhere? Oh well, his contact info is in his sig. In my searches I've heard he has a new design for an enclosure that will replace the rear center console in my 2009 Access cab.
    I plan on either buying Mr. Marv's rings, or making my own. won't happen for another month or two, as my funds right now are going elsewhere.
  11. Apr 6, 2011 at 11:50 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    I am not surprised that factory speakers had more bass if you did not properly treat the doors. I have seen/heard it several times. It is not always the case either way, and sometimes just a speaker replacement does exactly what you describe.
    But if you are serious about no sub, you have to really work to get the best bass response. Optimal would be a in-door enclosure designed for the mid....
  12. Apr 6, 2011 at 1:36 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    This is a prime example of what I was talking about the other day when we were sitting in my truck Matt. I think a lot of guys would do really well with a passive 8" component system in the Tacoma. That would be enough bass for most I'd imagine.
    Maybe I should offer a kit :D
  13. Apr 6, 2011 at 1:52 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    If you could knock out some decent passive networks designed around the placement (switch polarity or change slope for each side, etc - whatever is needed to get the best sound with no processing at all) and get some good deals on some DIY drivers... Figure out a good tweet mount for whatever, since you have the depth back there...
    Would be a great idea, but many want a brand name, not DIY drivers.
    Probably better to sit on a high quality 7". less (or no) modification to the door, especially if you build the baffle and include it with the setup. I am not sure if you can do that with the 8"... Also probably easier to match up with a tweeter that far away from the driver, as it will play higher.
    ETA - I wonder if a driver like a Peerless would solve the fitting issue, as the "cut" may allow it to fit in that area without bulging or much modification on the vertical part of the door card...
  14. Apr 6, 2011 at 2:27 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Way ahead of you man..... ;)
    And I'm pretty sure you can get an 8 in the door without cutting metal. Just needs the proper baffle.
  15. Apr 6, 2011 at 2:52 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Steven, what would your best suggestion for components in the $100 to $150 price range for someone that has a sub? I'm going to dampen my doors but was looking at some decent Kenwood or Pioneer component sets with the baffles they sell on Crutchfield.
  16. Apr 6, 2011 at 3:08 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    intrigued... PM or text some info. I think I will be starting some stuff in my truck soon, if you have some ideas we can try it in mine before I start deadening for some base line. Looking at 1-2 weeks or so? After that I will (hopefully soon) be about as deadened as you, with processor, etc.
  17. Apr 6, 2011 at 3:12 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    OK with used, or need to buy new? Need to buy at a certain store, or OK with buying unheard?
    Power you have available, or running off stock or aftermarket head unit?
  18. Apr 6, 2011 at 3:30 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    I'm not picky as long as it sounds good. Used is fine if they come from a good home.
    They will be ran off a Kenwood DNX6140.
  19. Apr 6, 2011 at 7:29 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Find something stupid efficient that will make the most of the limited amount of power you have.
  20. Apr 6, 2011 at 8:17 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    Yup. But skip some Infinity speakers unless you like bright tweeters
