Decision time...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gusher, Jun 16, 2010.
  1. Jun 16, 2010 at 3:52 AM
    gusher
    gusher [OP] SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Well, here's my odometer as I arrived at work this morning:
    This gives me 12 miles to decide whether or not to get the Toyota Platinum Extended Warranty. I am 99% sure I'm not going to get it for the following reasons:
    1. My truck is lifted so most suspension parts would be not covered
    2. Had the rear TSB done at 30K miles and my dealer replaced all of my shocks at that time even though I had a TRD and the TSB didn't call for tha
    3. I plow with my truck so just about anything suspension/transmission related would not be covered
    4. I have had zero problems with my truck
    So, my feeling is that I will most-likely not incur $889.00 in repairs in the next four years which is the cost of the 7yr/100K plan I was considering.
    Any thoughts??? Thanks in advance!
  2. Jun 16, 2010 at 4:18 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I'd also factor in whether or not you're able to fix any potential problems on your own or if you'd need to take it in to have most of the work done.
  3. Jun 16, 2010 at 5:02 AM
    gusher
    Greg
    Hudson NH
    Good point...fortunately for me...my old man is a television repairman, he's got this ultimate set of tools. I can fix it. :D
    Seriously, aside from the TSB, I've done everything to my truck and feel confident that I can fix most anything that comes up. I know that I can get some great tech support here so I think I'm good-to-go... :thumbsup:
  4. Jun 16, 2010 at 6:34 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Agree with not extending the warranty, especially with the limited coverage. Not much chance of our Tacomas having many costly issues up to 100K miles. Save that $900 for mods/tires.
  5. Jun 16, 2010 at 9:04 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    x2. What are the chances the warranty is going to pay for itself? My guess is pretty slim given the exclusions, your use of the truck, and reliability of the truck.
    I plow with mine, now at 68k, and zero issues.
  6. Jun 16, 2010 at 11:57 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Dont get it....You own a Toyota, youre fine.
  7. Jun 16, 2010 at 12:01 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I don't see how plowing will kill your warranty. Just take the plow off before hitting the dealer.
    While yes, I agree the chances you won't need it are pretty slim, but also think about how much things cost on this truck. For the additional components going out on your truck, the compass temp sensor for one, is almost $1000 in itself.
    As for powertrain.... you have 5/60k on that. So, you're only going out on accessory type crap (gauges, electronics, window motors, ect). Your engine/trans/diff(s)/transfer case.... whatever is applicable for your truck is still covered.
    Remember, Manguson Moss Act means they must PROVE your mod absolutely caused the failure, not the other way around.
  8. Jun 16, 2010 at 1:09 PM
    JKD
    JKD Well-Known Member
    I look at things like, how much does an alternator/power steering pump/etc. cost to replace. If those are covered, and you're going to keep the truck for a long while, I'd weigh the cost of the ext. warranty against the probable cost of repairs between now and whenever the warranty is up.
