Deck Plate Mod REVERSED!
Discussion in 'Performance and Tuning' started by Misterclean, Feb 19, 2013.
  1. Feb 19, 2013 at 9:24 AM
    Misterclean
    Misterclean [OP] Member
    Salt Lake City, Utah
    2004 Double Cab 4x4 TRD
    Transmission Cooler, 2" lift front/w Billy 5100 Coilovers, 2" Pro-Comp AAL Rear/w Billy 5125's, Epoxy frame coating, Thule Basket W/Outdoorsman 300 bed rail towers, Black wheel coat
    After almost a year, I've found that the DP Mod is a huge waste of time. It's my belief that people have an "initial perception" of performace gains due to the added exhaust note... but in reality, performace, especially at higher RPMs has been hindered! Unless you appreciate the added noise associated with the mod, which has become quite annoying... and the frequent filter changes, it really hasn't accomplished a thing! This includes gas mileage!
    Anyone else found this to be true!??
  2. Feb 19, 2013 at 10:55 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This has been my experience as well. Unfortunately, I've not seen an advantage of MPGs or power increase by running with the plate open. I just leave it closed all the time now so I don't have to remember to close it for dusty trail conditions.
  3. Feb 19, 2013 at 12:34 PM
    pipelayer_99
    pipelayer_99 Well-Known Member
    I actually lose MPG's and it's not because I rev it higher with it taken out. I do take off the plate when I'm going into the mountains as the extra air defintely helps. If I'm on the trail i leave it in so the dust and water is less likely to get to the filter.
  4. Feb 19, 2013 at 12:35 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    That ass dyno might not give you accurate readings all the time...
  5. Feb 19, 2013 at 12:37 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I think my ass dyno needs a calibration.
  6. Feb 19, 2013 at 12:45 PM
    blake5995
    Blake
    Truckee, CA
    I think a lot of people need re calibration, maybe we can do a group buy on re calibrations.
  7. Feb 19, 2013 at 3:51 PM
    Misterclean
    Whole lot of growl and no real BITE! I removed the silencer box a long time ago and the combo of both mods made my teeth chatter and gave me a headache! LoLoL :frusty: When I finally put the cap back on because of the noise, is when I realized how much more fuel economy and top-end performance I had been missing!
    As far as filters... I don't believe in washables. Or oiled for that matter. Not on a truck that I've put 170K on ..and plan on keeping for another 100K! JMO
  8. Feb 19, 2013 at 5:28 PM
    chriss
    chriss Well-Known Member
    chris
  9. Feb 19, 2013 at 5:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the deckplate was dynod to have gains
