Deck Plate Refined. . .
Discussion in '4 Cylinder' started by InfidelTaco, Aug 5, 2010.
  1. Aug 5, 2010 at 12:29 PM
    InfidelTaco
    InfidelTaco [OP] No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    For all you 4 bangers out there, 1st and 2nd Gen's:
    One of our brother members, to some of us Warrior Brethren-98tacoma27, used his recon skills and found an interesting article.
    The use of a velocity stack or box air port to refine the deck plate mod for 1st gens or maybe, just maybe the 2nd gen elbow delete[???]. I dont know if this is a repost or if anyone has tried this, maybe i should have conducted a search first, but im just throwing it out there. It is current and definitely interesting.
    Anyone?? :crapstorm:
    Ben[98tacoma27], dont mean to take ur spotlight, just utilizing the knowledge that u have provided and sharing it with our community directly.
    Thanx
  2. Aug 5, 2010 at 12:32 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Paper Bag Brigade Leader serves this forum well!
  3. Aug 5, 2010 at 12:33 PM
    InfidelTaco
    G
    PNW
    Prerunner
    Agreed.
  4. Aug 5, 2010 at 1:02 PM
    98tacoma27
    Ben
    Not Beech Creek
  5. Aug 5, 2010 at 1:30 PM
    scocar
    scocar hypotenoper
    Very interesting, but it seems to suffer from a couple key operational considerations:
    1. You can't close it up for dirty offroad/wet/submerged/smog registration conditions.
    2. I couldn't even read the Dyno curves, but the article indicates that most of the gains come at RPMs much higher than you typically would drive these engines, which are designed for low-end torque.
  6. Aug 5, 2010 at 4:05 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    X2, def like being able to close up the air box when need be, and I don't think many people put their RPMs up that high very often
  7. Aug 5, 2010 at 8:16 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I agree that the dyno curves were hard to read and it would be nice if the chart was bigger. However, it looked pretty clear that there was a larger difference between the curves at lower RPM's than at the peaks. Still hard to tell how much though.
  8. Aug 6, 2010 at 4:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think it would be better to have a "stack" that could fit into a deck plate. Then you could remove the stack and close the plate back to stock for offroad/muddy/wet conditions.
  9. Aug 6, 2010 at 5:05 AM
    Jigzor
    Pennsylvania
    What if you had a outer lip from the stack on the outside, then use a rubber-maid like cap to cover it. Something rubber that could pop on instead of the typical screw on ones you see?
  10. Aug 6, 2010 at 5:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Not a bad idea, but where would you find one?
  11. Aug 6, 2010 at 5:23 AM
    Jigzor
    Pennsylvania
    Well I guess trying different containers until you find one that fits is an option, but a slow process unless you're lucky. I found some caps for velocity stacks that are meant for carbs. Another option could be to use a rubber cork like piece.
  12. Aug 6, 2010 at 5:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    hhmmm..............or duct tape.........:D
  13. Aug 6, 2010 at 5:50 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I guess I could rummage throught the wifes tupperware. :D
  14. Aug 6, 2010 at 6:00 AM
    Jigzor
    Pennsylvania
    Just think, if someone finds a container that has a fitting lid, they can donate the container portion to Chris so he can have a dedicated bondo mixer. The wife will be happy the dinner doesn't taste like bondo!
  15. Aug 6, 2010 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What vehicle was this dyno performed on?
  16. Aug 6, 2010 at 6:12 AM
    98tacoma27
    Ben
    Not Beech Creek
  17. Aug 6, 2010 at 6:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Aug 6, 2010 at 1:02 PM
    afd23a
    The Dynamo of Dixie
    how about something like a fernco pipe cap?
  19. Aug 6, 2010 at 1:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Nice, thats a realtively quick install/removal too.
  20. Aug 6, 2010 at 1:22 PM
    scocar
    scocar hypotenoper
    That's exactly what came to mind! Might be tricky getting it in behind the wash reservoir spout with the way the velocity stack sticks out plus the depth of this. Probably have to trim the caps' depth down as much as possible to there is just enough left for the hose clamp to seat on.
    But again, is any of this worth it if the performance increase is not better or just marginally better the than DP by a couple hp? Really need three runs on the same truck on the same day: stock, DP, and VS. And it might still be just an exercise of picking flea shit out of pepper...
