Deck plate vs K&N cold air intake?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Feb 27, 2010 at 10:37 AM
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    Lakewood, CA
    04 Double Cab PreRunner SR5 TRD
    Which do you think is better?
  2. Feb 27, 2010 at 10:49 AM
    smallcandle
    smallcandle The clown has no penis...
    Brian
    South-central Kansas
    02 DC TRD SR5 4X4
    Deck plate mod, Maglite console mount, Husky Liners front and back, Black powder coated OEM rims, BF Goodrich All-Terrain KO's 265/75/16, Grillcraft MX black insert, Hella 500FF mounted behind grill
    Without any statistics to back me up I'm going to say the deckplate mod. It definately makes a noticeable differnce in throttle response and engine tone, not to mention the fact that it costs less than $20.
  3. Feb 27, 2010 at 10:52 AM
    2004Taco
    Lou
    Lakewood, CA
    Ya, i did it already to my taco. I was just curious if the K&N was better.
  4. Feb 27, 2010 at 10:53 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    im 98% sure that its been dyno'ed and the deck plate is better by a good amount
  5. Feb 27, 2010 at 11:01 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i done both... i like the throttle response with the K&N better...
    plus if you wheel hard or break a motor mount, the stock tube can break off right at the intake box...
  6. Feb 27, 2010 at 12:21 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    K&N has dyno's on their website guaranteeing ~10HP gain at ~4800 RPM's. Im guessing that the deckplate mod is not far behind, but def not better.
    It will also depend on the season. In the summer, the deckplate mod would perform a bit better as its better at getting cooler air isolated from the engine, however during the winter I see the K&N manifold doing very well.
    One thing to keep in mind, the K&N isnt very isloated when you are doing soime heavy off roading. The deckplate mod can be closed to protect your engine
    Lastly, the deckplate mod cost about $200 less than the manifold and is much easier.
    Which is better is up to you :thumbsup:.
  7. Feb 27, 2010 at 12:23 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    didn't chris do a dyno test? pretty sure deckplate mod came out on top. but I think mike probably has a good idea too!
  8. Feb 27, 2010 at 12:28 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    for me, the HP gains aren't as important as i dont drive faster than 70 on the hwy... i do a lot of street driving and offroading, so bottom end and throttle response are more of what im after...
    just depends on how u drive though...
  9. Feb 27, 2010 at 4:24 PM
    2004Taco
    Lou
    Lakewood, CA
    I do more ONroad driving then OFFroad.
  10. Feb 27, 2010 at 4:26 PM
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    you did the deckplate. now just go and buy a k&n drop in filter. Best of both worlds!
  11. Feb 27, 2010 at 4:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes I did. K&N showed no gain, the Deck plate did. Almost 8 hp on the 3.4, and 5 hp on the 2.7.
  12. Feb 27, 2010 at 4:33 PM
    chazjb
    chazjb Well-Known Member
    James
    Oregon
    2015 DCSB Sport
    Anywhere you look some are gunna say one is better than the other. IMO i think you should go with the deck plate first ( i just ordered mine ) because it only costs $15 so how can you go wrong? If you dont like the performance or whatever with the deck plate then go with the K&N. At least you wont pay for the K&N then realize that the deck plate could have done just as good.
  13. Feb 27, 2010 at 4:34 PM
    2004Taco
    Lou
    Lakewood, CA
    I didnt the deck plate and i have the K&n Dropin filter. Did that the same time i did the deck plate mod ;)
  14. Feb 27, 2010 at 8:15 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    In that case, the K&N wins:
    http://www.knfilters.com/dynocharts/57-9015_dyno.pdf
    (keep in mind this is a manufacturer test)
  15. Feb 27, 2010 at 10:50 PM
    Drews Tacoma
    Drews Tacoma Member
    Drew
    San Jose
    99 Gold TRD
    Flowmaster Exhaust, Wheelers/Alcan Leaf Springs, Bilstein 5100's, All Pro Shackles, K&M air filter, braided brakeline extension
    K & N is the best! I just cleaned mine and I am so glad that I bought one because it runs so much cleaner after the filter has been cleaned:)
  16. Feb 28, 2010 at 2:49 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    I have the deckplate mod and drop in K&N. Combo works great and I did notice a little quicker throttle response over stock. (3.4 V6) I had the K&N FIPK cold air intake on my older '92 3.0 V6 Toyota Pickup and the gains seemed to be about the same. Different motors, I know, but for a price difference of $200+ I would go with the deckplate. Plus, you can always put it back to stock just by screwing the cap on.
  17. Feb 28, 2010 at 5:57 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I dont think there is any noticable diff between the DP mod and K&N manifold. It all depends on how much money you have.
  18. Feb 28, 2010 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  19. May 7, 2010 at 5:59 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    How do you clean it?
  20. May 7, 2010 at 6:34 PM
    troy_279
    troy_279 Active Member
    Canada
    02 Double Cab TRD
    So where is a good place cheap place that you guys are ordering your DP? I'm in Canada and I stopped at a marine shop and the only thing they had to order had a 2.75 collar underneath so that would put it about through the air filter. I assume the ones you guys are using is a flush mount? The only reason I want to get it done as I'm getting 16 MPG with mostly slow highway driving!
