Deckplate Mod and Snorkel?
Discussion in 'Performance and Tuning' started by climber-420, Jan 7, 2009.
  1. Jan 7, 2009 at 8:50 PM
    climber-420
    climber-420 [OP] I love tight cracks
    CO
    2004 Gold Ext Cab TRD 3.4L V6 Manual
    255/85/16 BFG KM2's, 3" OME lift, Dakar's, Nitrochargers, Grey Wire Mod, ARB Bumper, ARB CKMA12 air compressor, WIts End Pacifier, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets, Titan Rod Vault, Extreme LED's front and rear,
    So I have been wondering about this for a while? Can you actually have a snorkel with the deckplate modification? I know that the deckplate has the removable insert for it, and should be sealed with some sensor safe sealant, but will it really do anything? I have been on this forum for a bit and haven't seen any threads, or posts regarding this at all. I have looked on TTORA, this site, expedition and overland sites, and nothing. Any info from anyone, or just chat about it to see what people have to say.
  2. Jan 7, 2009 at 8:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont see why it wouldnt work. Just re install the deck plate cover, and it would be fine.
  3. Jan 8, 2009 at 7:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Times 2. The deckplate is designed to be waterproof, WHEN PROPERLY INSTALLED!!!!
  4. Jan 8, 2009 at 8:00 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    As a sailor I can verify that a properly installed deckplate with a well maintained gasket is indeed waterproof. Installed on the air box it probably wouldn't leak before getting to a depth that would require the truck's driver to be wearing scuba gear.
    I would inspect the gasket and replace it if it's dried out before risking the truck. I give the ones on my boats an occasional daub of teflon grease.
  5. Jan 8, 2009 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Roland, sorry to go OT here, but what is a good grease to use on a boat? Will Mobil 1 be ok?
