Decreased Power?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymac10, Sep 21, 2021.
  1. Sep 21, 2021 at 4:21 PM
    jaymac10
    jaymac10 [OP] Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Owned my 2013 4.0L Sport since new. Just in the past 2-3 months, I feel like the power output is less. Mostly at higher highway speeds - just seems more sluggish.
    Synthetic oil just changed as well as a new engine air filter.
    The engine air filter was pretty old/grubby. Definitely left it too long before replacing. We had massive forest fires/dense smoke this summer too which didn't help.
    I did not clean the MAF sensor. Should I clean MAF?
    Also, does disconnecting the battery re-set the ECU learning of the fuel/timing? (Used to have a Subaru STi which I think did that)
    Any other suggestions?
    Thanks,
    Jay
  2. Sep 21, 2021 at 4:29 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, clean the MAF sensor. How many miles on your spark plugs?
  3. Sep 21, 2021 at 4:39 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  4. Sep 21, 2021 at 4:50 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Do the battery disconnect re-boot. An extraordinarily bad tank of gas can cause all sorts of trouble - and the re-set procedure is short and painless. I usually give the last tank of gas a good dose of injector cleaner (PEA additive). Refill with the best source of daily driver fuel - and disconnect the battery for a few minutes.
    May take the system a minute or two to "re-learn" on start-up but don't stress over it. It may not start on the first try - but usually takes off and runs on the second.
    ohcaltexscar and Marc70 like this.
  5. Sep 21, 2021 at 5:14 PM
    winkel
    Corydon, IN
    Some folks have less than stellar results with the iridium plugs in these engines. I would recommend changing to a simple copper core plug set and see if this remedies your problem. It would be cheap and relatively easy to confirm. Seriously, give this a shot.
  6. Sep 21, 2021 at 5:19 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    All good replies here. My money is on the MAF & throttle body being a little gunked up from the smoke. It's not like we're running HEPA filters in our air intakes.
    Another obvious one is check your tire air pressure. That'll bog you down a bit if it's low.
    wi_taco and tsb like this.
  7. Sep 21, 2021 at 5:48 PM
    winkel
    Corydon, IN
    I've cleaned my throttle body a couple of times and each time it was a pretty clean to start.
    Although, I drive in pretty clean conditions. Still worth checking. Just do it when the engine is cool or the cleaner will evaporate before it has a chance to do any good.
  8. Sep 21, 2021 at 5:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Might want to post your mileage and type of transmission bud. It would help us make suggestions easier. :thumbsup:
  9. Sep 21, 2021 at 6:26 PM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    2nd yes to MAFS cleaning. No offense, but for you to have to ask, I would recommend learning how to do it properly. YouTube has many good how-tos on this. Very sensitive device and not cheap to replace. Also, Throttle body cleaning might add to the overall responsiveness. Also, plugs and even plug wires under the right conditions often can rob high rpm performance. How many miles did you say? Many overlook weakened fuel pumps or restricted flow fuel filters on high mileage trucks.
  10. Sep 21, 2021 at 6:38 PM
    Pearson
    Elliott
    Lexington Texas
    Well here's more to consider, There is an alarming rate of reported counterfeit NGK iridium plugs being sold on eBay yes even Amazon. Frankly what I am hearing is symptoms much like what you are describing with your loss of power and even have heard of damage being caused by them.
    Sorry to be that guy but I would check it out. The last guy that I learned about did a video showing how to spot the diff. It was insane, I would never pick up on the subtle differences in packaging and the plug them selfs. The only way to know for sure is to call NGK customer service and confirm their lot number. At least that's what the guy I'm speaking of did. Anyhow, sure enough, they were fake. This is why I only buy plugs from the dealer these days.
    Sorry to be alarming, but this is a real thing nowadays. I would find the box and be on the phone with them ASAP. Good Luck and please keep us posted.
    One of many videos on the topic,
    https://www.youtube.com/watch?v=Lr9J3eQk-kE
    TacoFergie likes this.
  11. Sep 21, 2021 at 6:40 PM
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    X2 on the tire pressure at highway speeds.
  12. Sep 21, 2021 at 7:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are no spark plug wires to replace. We have coil over plug ignitions.
    Pearson[QUOTED], TnShooter and tsb like this.
  13. Sep 22, 2021 at 8:45 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks guys! Truck is an automatic. 118,000Klm.
    I'll clean MAF first and see how that goes.
    Will report back soon.
    Jay
    TnShooter likes this.
  14. Sep 23, 2021 at 6:53 AM
    mitchbuck
    mitchbuck Well-Known Member
    Cape Cod
    12 Taco 2xCab SR5
    I had noticed this too on my 2012 about 2 years ago. I cleaned the throttle body as suggested using a post here and I couldn't believe the difference it made it felt like a new engine haha! I tow a ~5000lb boat too so the increased power was notable and very welcomed as well.
    jaymac10[OP] likes this.
  15. Sep 23, 2021 at 7:10 AM
    Csharp987
    Csharp987 Navy Chief
    Bob
    Athens, Ga
    07' Prerunner | SR5 | 4.0L | Double Cab | Tan Interior
    If you're going for MAF, do throttle body at the same time. It's an extra 10-15 minutes.
  16. Sep 23, 2021 at 9:42 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks for the video/info!
    While I'm not 100% certain, I'm pretty sure I got authentic ones. I didn't spend $25 for a 6 pack on Amazon like this guy did but more like $130 for six :)
  17. Sep 23, 2021 at 9:43 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks, can I use the same MAF cleaner on the throttle body or is it a different cleaner?
  18. Sep 23, 2021 at 10:43 AM
    Pearson
    Elliott
    Lexington Texas
    Know way to know without contac
    No way to know without contacting NGK with your lot number information. Understand that the price you paid has nothing to do with it. Certainly worth the time of a phone call.
    I may add that I actually had the occasion to call them myself for plug to plug comparison information. The tech answered my call on the 2nd ring and fired right back with the information I was seeking.
    https://ngksparkplugs.com/en/about-us/contact
    CUSTOMER SERVICE
    1-877-473-6767, dial #3
    hours: 8:30am – 5:00pm
    Monday-Friday EDT
    TECHNICAL SUPPORT
    1-877-473-6767
    Dial #1 (Application Support)
    Dial #2 (Advanced Tech Support)
    hours: 9:00am -5:00pm
    Monday-Friday EDT
  19. Sep 23, 2021 at 11:22 AM
    Pearson
    Elliott
    Lexington Texas
    Right you are, sorry, speaking in general. In this case perhaps a new boot & spring kit with the sparkplug replacements. (condition dependent) If it has been a while or never it's a good idea to have them on hand.
    Jimmyh[QUOTED] likes this.
  20. Sep 23, 2021 at 1:54 PM
    Csharp987
    Bob
    Athens, Ga
    I don't know. I went to Advanced Auto and bought the CSC MAF cleaner and the CSC Throttle Body cleaner. I didn't compare ingredients.
