Decreased Power?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymac10, Sep 21, 2021.
  1. Sep 23, 2021 at 2:00 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
  2. Sep 23, 2021 at 2:00 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    My truck did not like iridium plugs. Lost 2-3 MPG. :crapstorm:
  3. Sep 23, 2021 at 2:03 PM
    rnish
    Tacoma 2nd gen
    Yes they are different. Cleaner is $5-6 per can. Much less if you catch a sale. One can lasts me years. I use the recommended (different) cleaners on the MAF and throttle body.
    Pearson and ohcaltexscar like this.
  4. Sep 23, 2021 at 2:05 PM
    ROAD DOG
    FEW
    what toyota engineered / built essentially for evevry one
    everything
    all the time
    the hype associated with accessory marketing moves stock off o shelves
    tho some may actually last longer........................they may NOT spark with more energy
    down a 1/2 step on on cylinder performance
  5. Sep 23, 2021 at 3:48 PM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    I don’t know the make up content one to the other. I do know that they make one for each task. And I have heard Many say not to use the Throttlebody cleaner on the mass airflow sensor. It would be very beneficial for you if you have not cleaned a throttlebody before to watch a few videos. It’s not as it would seem to be. The procedure is much more than just unloading the can on the throttlebody brow etc. I know of a very good video I will link to this conversation later this evening when I return home if it would be helpful.
  6. Sep 23, 2021 at 4:25 PM
    Csharp987
    Csharp987 Navy Chief
    Bob
    Athens, Ga
    07' Prerunner | SR5 | 4.0L | Double Cab | Tan Interior
    I already know that and already know how to clean both.
    I think you meant to quote the op.
    Pearson[QUOTED] likes this.
  7. Sep 23, 2021 at 4:31 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    def want to make sure they are not too cold or hot. Lots of talk on this in the S/C thread. Most stick with the factory plugs on the non boosted engines. But that helped I swapped mine and they were toast. MAF got a good cleaning.
    Also a couple other things could be PCV valve and even the fuel pump could need a swap.
    Pearson likes this.
  8. Sep 23, 2021 at 4:45 PM
    Pearson
    Elliott
    Lexington Texas
    You’re absolutely right, no insult intended. Most anybody that has seen me move around this forum knows that I have trouble turning on a PC let alone posting and navigating through all of the content with any sort of grace.
    Csharp987[QUOTED] and winkel like this.
  9. Sep 23, 2021 at 6:10 PM
    Pearson
    Elliott
    Lexington Texas
    This is interesting, I went through something similar with a K&N filter on my Focus. I installed it and lost 2-4 mpg and had a catalytic code within a week. Switched back 8 weeks later everything was back to normal.
  10. Sep 24, 2021 at 7:38 AM
    jaymac10
    jaymac10 [OP] Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks guys, removed and cleaned the throttle body yesterday. It wasn't really dirty but there was still some dirt in there to clean.
    However, the MAF sensor definitely was pretty dirty on the one side!
    Will report back the next time I'm on the highway to see of there's been an improvement.
    Cheers,
    Jay
    Pearson likes this.
  11. Sep 24, 2021 at 10:19 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Maybe you got the fake ones?
    Pearson likes this.
  12. Sep 24, 2021 at 10:46 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I had an odd power loss feeling when on highway and at higher RPM's. I cleaned my MAF yesterday and everything's back to normal it seems.
    I noticed that one side of the bulb part sticking down was dirty. Also make sure you cleaned the two smaller wires inside the tunnel area with the cleaner. I'm thinking those are more important to keep clean.
    FWIW, I also found out the fuel filter is in the gas tank. It seems URD makes a kit to move it out.
  13. Sep 25, 2021 at 5:43 AM
    Pearson
    Elliott
    Lexington Texas
    There could be something to this. I actually spent many years serving the ceramic industry. While there I had the pleasure of working with Champion, Auto Light, and several others right on their R&D and production floor.
    Oversimplifying the process but two of the most important factors in a plug are predictable conductivity and the life cycle of performing their task. I feel sure that anyone willing to make counterfeits are not expecting repeat customers and is not concerned with the quality of materials used in their offerings.
    So on the surface, you might look into and consider the possibility. GOD HELP US!
