Deeezy's Locked Sport Grocery Getter Build
Discussion in '2nd Gen. Builds (2005-2015)' started by deeezy, Aug 26, 2014.
  1. Aug 5, 2015 at 12:07 AM
    #541
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    I guess.."Go Big, or Go Home"...:D
  2. Aug 5, 2015 at 1:06 AM
    #542
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    :wave:Me too
  3. Aug 6, 2015 at 1:04 AM
    #543
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    me 3 :spy:
    squint0241 likes this.
  4. Aug 6, 2015 at 5:05 PM
    #544
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    I'm thinking we all head to Dana's for a chop session. Massive tape and cut event! :)
  5. Aug 6, 2015 at 5:08 PM
    #545
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    What's the source for the trim? And how much is needed?
  6. Aug 6, 2015 at 5:11 PM
    #546
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    You need to take number and get in the back of the line.:p
  7. Aug 6, 2015 at 5:12 PM
    #547
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Damn...thought I was first...:D
  8. Aug 6, 2015 at 5:56 PM
    #548
    deeezy
    deeezy [OP] Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Edge trim is from McMaster Carr. 2 part #'s, one for sheet metal and one for thicker plastic flares: 8507K11 and 8507K65. They come in 10 , 25, 50 foot lengths. I would get enough so if you mess up you have extra to redo some areas. Same with the plastic flare clips, I believe rka has the pn for those two types from Amazon. I have to redo a small section on my truck.
    I personally won't chop anyone's fenders because I'll probably mess it up. It's not something that can be done perfectly and probably better if the owners cut their own. lol. I can definitely show you exactly how I did mine. And just for the record, mine are not perfect. They might look good in pictures but there's definitely areas that could have been done better. I can lend a hand if anyone needs help though.
  9. Aug 6, 2015 at 6:11 PM
    #549
    deeezy
    Dana
    Hawaii
    Fender flare clip PN. I ordered these from Amazon and they fit. There's more of one color on each fender, these chinese clips are opposite color coded to what is really on the truck.
    Red/Orange clip part number 90904-67037 and
    Blue 90904-67036
  10. Aug 6, 2015 at 6:14 PM
    #550
    rka
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
  11. Aug 6, 2015 at 6:18 PM
    #551
    deeezy
    Dana
    Hawaii
    Yes, those blue and red clips work. I ordered those part numbers already. Those clips are definitely needed if you want to put your flares back on.
  12. Aug 6, 2015 at 6:21 PM
    #552
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Is a jig saw the best tool for cutting the fenders? I was wondering if a sawzal or dremmel with a metal cutting blade would be more precise...
  13. Aug 6, 2015 at 6:24 PM
    #553
    rka
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    I think I'd use a jigsaw for metal and Dremel the plastic.
  14. Aug 6, 2015 at 6:26 PM
    #554
    deeezy
    Dana
    Hawaii
    I tried about a half inch with a dremel and just couldn't do it. lol You might be better with that tool than me so it might be better, but I couldn't use it. I couldn't make the line as straight with it as I could with the jig saw. My lines are straight, it was applying the edge trim that I messed up a little spot. You'll see when you start dremelling it. And you'll take hours and hours with the dremel.
  15. Aug 6, 2015 at 7:44 PM
    #555
    deeezy
    Dana
    Hawaii
    Front of the rear fender. Nutted and bolted since there is no fender support there.
    The rear fender support can still be used. I just bent the support back a little so the holes lined up and the stock bolt could still be used.
    Stock bolt looking from under:
    Don't really need the front fender support bar since the area is so small after trimming.
    Nate87, rka and squint0241 like this.
  16. Aug 6, 2015 at 7:57 PM
    #556
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Sweet truck.
    deeezy[OP] likes this.
  17. Aug 6, 2015 at 9:33 PM
    #557
    rka
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    My plan was to Dremel the plastic but if u say jigsaw better then that's what I'm using. Btw it looks great! That's exactly what I want to achieve. Now how are u attaching the required mudflaps??
  18. Aug 6, 2015 at 9:50 PM
    #558
    deeezy
    Dana
    Hawaii
    Thanks man!
  19. Aug 6, 2015 at 10:03 PM
    #559
    deeezy
    Dana
    Hawaii
    Yeah man, the jig saw kind of wants to cut in a straight line on it's own. I know if I kept using the dremel, the cutting wheel would have skipped and bounced and dinged the flare. lol. I did use the dremel to start every cut so I could get the jigsaw blade in there.
    I def wanna help you guys out, I just don't feel comfortable cutting someone else's nice truck. :eek:
    I cut some "L" angle aluminum I found at work and plan to use those as mounting brackets. You won't see any of the bolts attaching the flaps if they are attached to the sheet metal under the plastic flare. Well, that's what I'm picturing in my head. I want to get the 315's mounted before I drill any holes for the flaps so I can make sure they cover the entire width of the new tire.
    If you're more comfortable with a Dremel, I would try that first.
  20. Aug 8, 2015 at 7:12 PM
    #560
    deeezy
    Dana
    Hawaii
    The front fender flares were bugging me because after trimming I had only the plastic clips holding them on. I made some small aluminum brackets to bolt the flare in the front of the front fender.
    It's a lot more solid now
    Painted all the hardware black so it's not too noticable
    The front and rear flares are all now bolted to the fender instead of just having the plastic clips holding them on.
