Deep water issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgrande, Oct 18, 2009.
  1. Oct 18, 2009 at 4:30 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    So afer my first stint with going through water, I sucked up some water on my air filter. After posting a thread about it and getting some help from tacomaman and others, I decided to make up an intake for going through deep water. This was my first time doing something like this and looks weren't a real big issue. Here's the making of it.
    Started with a 4" metal duct tube I picked up from HD
    Sealed the end cap to the tube with some apoxy
    cut a shroud to keep splashes off the new initial air filter
    After the first test.
    Here you can see the extra filter I put on. Just a filter sheet from the AC aisle folded in half. It did a good job and caught some mud.
    Now, here's the issue. I still took up water on my air filter.
    From looking at it, seems that these two little holes in the filter housing are what's taking up the water.
    Does anyone know what these holes are for? Can I plug them up so water doesn't soak up my air filter anymore? Also, I had originally planned on naming this the florida mod since flooded, muddy roads are what we have here. Unfortinatley, due to my current obligations to the Marine Corps, I had to build and test it in North Caralina.
  2. Oct 18, 2009 at 4:52 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    maybe look into getting a snorkel....either way, plaugging the holes cant be that bad if they are extremmely little...maybe they are for drainage....
  3. Oct 18, 2009 at 5:01 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    I couldn't get a snorkel. I just don't love they way they look enough to do something like that. Drainage is the only thing I could think that the hole are for, however obviously mine are doing the exact opposite. Maybe I could slap some duct tape on there before I head out. Then when I'm done just take it off, leaveing the hole to do whatever it is they do.
  4. Oct 18, 2009 at 5:23 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    ya, or go to HD and get some little rubber plugs or something...but duct tape is usually the way to go :)
  5. Oct 18, 2009 at 7:44 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Yeah, your homemade filter looks way better. :crazy:
  6. Oct 18, 2009 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OP....If you want a functional filter/water protection, your gonna have to get the air from a safe location from water. Thats gonna be out side of the engine compartment and up high.
  7. Oct 18, 2009 at 7:48 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    If you're really concerned then it's best to "go all out" and install a snorkel.
  8. Oct 18, 2009 at 7:49 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Damn, how deep was the water you drove through?
  9. Oct 18, 2009 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, I dont think that flex tube you have is water tight.
  10. Oct 18, 2009 at 7:57 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    It does look better, because when the hood is down, it's invisible.;) Obviously it's not on all the time, I would just put it on there when I was going to be going through some water.
    Chris, I was trying to get my air from a better spot, I figured with it being there, and with the splash gaurd, It would keep it would keep most of it out. Which I think it did, but now it looks like the problem has been those little holes letting the water get to my air filter. There isn't some sort of super important reason they can't be coverd up prior to getting dirty is there?
  11. Oct 18, 2009 at 8:05 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    samster, it was pretty deep, the second time around it came over the hood a little. I had my girl shoot some video, when I get a chance I'll upload it.
    Chris, you may be right. As of now it seems fine, it's an alluminum tubing I got from the plumbing section. I suppose I could do more to water proof it. But it may not be worth it if pugging the hols solves the problem.
  12. Oct 18, 2009 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The holes are there to let water escape from the air box. A better design would be to run some tube up to the "A" pillar of the truck, via inside the fender.
  13. Oct 18, 2009 at 8:11 PM
    Amos
    Amos Well-Known Member
    Daniel
    Huntsville, AL
    09 4x4 DC sport
    if your gonna be running through water that deep you need a snorkel, but I think you would also need a diesel engine?
  14. Oct 18, 2009 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    These engines are fine submerged...For short periods. Dont treat it like a submarine.
  15. Oct 19, 2009 at 7:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    :facepalm:
    Stay out of the deep stuff. What's the point? Sooner or later it'll bite you in the ass and you'll end up with a lot of expensive repairs.
    Do you know what hydrolocking is and what not to do and how to revive an engine if you need to (and if its possible)??
  16. Oct 19, 2009 at 2:00 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Yeah, you're right. I should probably quit while I'm ahead. But it's so much fun! We've gone through alot of water growing up on my old man's hunting lease.Only once did my brother get stuck in my dads chevy and hydrolock. He was able to just pull it out with our buggy, clean the plugs, change the oil and it ran fine afterwards. But I know it can be much worse than that.
  17. Oct 19, 2009 at 2:09 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I'd avoid the deep water these things are not sealed up like an H1, and I'd hate to see you get a huge repair bill or even a breakdown in the middle of nowhere
  18. Oct 19, 2009 at 2:17 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    After talking to a buddy he showed me these.
    http://www.outerwearsracing.com/tech.html
    Anybody run them? Not trying to give myself to cross anymore rivers in my truck, they just look like something worth picking up. It says they make custom ones, maybe they could do one up for the stock set up.
  19. Oct 21, 2009 at 6:02 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Snorkel... get 'er done.
  20. Oct 21, 2009 at 6:39 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    today I noticed a kind of grinding sound comming from my belt or fan. It's not the normal squekey belt noise, it's more of a low pitched "dry" noise. Sounds like maybe a bearing or shaft isn't lubed up is just spining dry. I didn't have a crayon to rub on the belt, so I used some candle wax. That didn't get rid of it so I went to the auto store and picked up some belt conditioner, which still didn't get rid of the sound. Any ideas?
