Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Apr 29, 2007 at 7:08 AM
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I have been reading that there are a number of people that are having issues with their BRAND NEW Tacomas! I am not one of them (aside from my complaints about MPG on a 4 cyl), but I think we need to get some accurate numbers to go to Toyota with.
    PLEASE RESPOND TO THIS POLL/THREAD WITH THE FOLLOWING:
    1) Year or Build Date of your Tacoma
    2) Engine (V6 or 4Cyl)
    3) Drive Line (2WD, 4WD, and whether or not you have Traction Control or a Locker/LSD)
    4) Body Configuration (AccessCab/DoubleCab and Longbed/Shortbed)
    5) Suspension (TRD, PreRunner, or Stock)
    6) Discribe your issue/defect as best you can if you have any.
    May this bring us some good numbers! ;)
  2. Apr 29, 2007 at 9:04 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    1) 2007
    2) V6
    3) 4WD, Manual, LSD
    4) Double Cab/Short Bed
    5) TRD Sport Suspension
    6) I don't have any.
    Only when the engine is cold and the high idle kicks in. Once the engine is warm no problems. I don't really consider this a problem, just adding my opinions on it.
  3. Apr 29, 2007 at 1:12 PM
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    I will let you all know what issues are present in the 2007 trucks that I see coming into the dealership here and possible fixes.
    At present time, YOU ALL should be experiencing noises comin from the composite bed which
    Toyota has no known fix, but is well aware of it. Part of this noise is coming from the plastic fender wells in the rear.
  4. Apr 29, 2007 at 2:12 PM
    Steve762us
    Steve762us Well-Known Member
    1) MY07 built Jan 07
    2) Engine (V6) w/AT
    3) Drive Line (2WD,LSD)
    4) Body Configuration (AccessCab)
    5) Suspension (TRD Sport Prerunner)
    6) Wind noise from windshield (kazoo/fingernails on a blackboard) in crosswinds when over 65 MPH. Minor paint defect on hood (painted over some kind of debris)
  5. Apr 29, 2007 at 5:18 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    1. 2005
    2. v6
    3.2wd
    4. DC
    5. pre-runner
    6. when i took my "Diva" home and went back to the dealer 3 times re-aligning my wheels. now it only vibrates when i drive over 100mph.
  6. Apr 29, 2007 at 5:20 PM
    Ldytaco05
    Orlando, Fl.
    steve the cure for your wind noise is to apply 3m double sided tape on the front lower corner of your windows that should stop the noise. hope this helps
  7. Apr 30, 2007 at 5:07 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I am definitely having this problem. I only notice it when my rear sliding window is open. It sounds like something is loose in the bed. or that there is some plastic-to-metal action going on. I have pulled over a number of times to make sure that everything was kosher. Never came across the problem...
    :confused:
  8. Apr 30, 2007 at 5:08 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Nice! We should nominate you as our Baja driver if we ever enter into a race! ;)
  9. Apr 30, 2007 at 5:38 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    1) 2007
    2) V6
    3) 2wd
    4) Double Cab
    5) TRD Sport
    6) The only thing i see thats wrong w/ the Taco's is the hard dash and door panels, etc. You can run a toothbrush across them and scratch them up. I think that was a very bad design from Toyota. Something somewhat spongy would have been nice so you dont knick it all the time. Just my $.02.
  10. Apr 30, 2007 at 10:43 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    1. 2007
    2. V6
    3. 4x4
    4. Double cab
    5. TRD offroad
    6. I have some slight (barely noticable) vibration when i accelerate, but i think it is different that what most people are complaining of. mine only occurs when i accelarate slowly, it onlly happens between 5 and 10 mph and is only in first gear. it dissapears right before the trans shifts into second and does not continue in any of ther other gears. Mine is only present halfway through first gear, way before i hit 20mph
  11. Apr 30, 2007 at 11:47 AM
    CharlieX
    CharlieX Well-Known Member
    2) v6
    3) 2x4
    4) Double Cab Shortbed
    5) pre-runner
    6. Zero issues. But I DO have that noise from the bed. I thought it was just the metal parts of the tie downs I keep in the bed storage boxes banging around. Planning on cutting up some rubber pads to fit in there to minimize clanking.
  12. Apr 30, 2007 at 12:28 PM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    1) 2007
    2) V6
    3) 2WD, Manual, LRD
    4) Access Cab
    5) TRD Off Road
    6) I've been looking for something to complain about but can't really find anything. My only problem is finding the money to upgrade and the time to take her out just for fun. In short, the best truck I've ever owned.
  13. Apr 30, 2007 at 12:44 PM
    sak3358
    sak3358 Well-Known Member
    1) 2007 (19 March 2007 Born on Date)
    2) V6
    3) 2WD, Auto, LSD
    4) Double Cab, Short Bed
    5) TRD Sport
    6) If, and only if I was real nit picky I would complain about the slight buzz I hear when going through the 30-45mph range. It's the overhead sun glass bin. If I take a small piece of weather stripping, it will go away. I don't hear anything else....I have the tunes cranking.
  14. Apr 30, 2007 at 5:16 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    1) 10/05 2006
    2) V6
    3) 2WD Locking rear diff
    4) doublecab short bed
    5) TRD off road prerunner
    6) I have no problems i would not call abnormal for a truck
  15. May 1, 2007 at 12:52 PM
    burfal
    burfal New Member
    1) 04/05 2005
    2) 2.7
    3) 2wd Auto
    4) Access cab SR5
    5) Stock
    6) I have the vibration when slowing down other then that I love my truck.
    I had a interesting issue with the Check Engine light coming on when there was a big temperature increase during the day. I would go out after work and the light would stay on for a week or so. Talked to the dealer and they said to remove the gas cap and put it back on, I guess to release presser built up during the day. When it happened for the third time I took it in and the error code pointed to the filter on the gas tank overflow, they changed it and it has not happened since.:)
  16. May 1, 2007 at 2:16 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Well that is definitely a new one, but I can completely see how that happens.
  17. May 2, 2007 at 2:00 PM
    sdupp
    sdupp SC Member
    SC
    White 07 PreRunner Double Cab SR5
    1: 2007
    2: V6
    3: 2WD Auto Trans & LSD
    4: Double Cab - Short Bed
    5: SR5 PreRunner
    6: I've noticed a Vibration problem when slowing down and the automatic transmission is down shifting @ 20 - 25 MPH. It's either third or second gear I feel the Vibration / Shuddering. I only have three thousand miles on my truck.. When I go in for it's first service I will mention the problem.
  18. May 9, 2007 at 12:17 PM
    Suzeiki
    Suzeiki Member
    2007 Tacoma, V6, 4x4,Access cab,TRD
    purchased 2-11-07
    Vibration at 20mph to 25mph and now a new vibration at 55mph. The driveline has been replaced twice. The Toyota folks tell us this is an "inherent" characteristic of the truck. ( ? )
    excuse me???????
  19. May 16, 2007 at 8:02 PM
    geoffho
    geoffho Member
    2007 Tacoma, V6 ,4X4, Dbl-Cab, TRD, Tow, 6spd - 700 miles - I have the windshield noise issue. Also some weirdness when shifting (lurchy from 1/2 and 2/3 and delay in accelerator response when i take my foot off the pedal) - but not sure if it is normal or not. No vibration issues or other problems.
  20. May 17, 2007 at 4:49 PM
    BigGeeDee67
    BigGeeDee67 Member
    1) 2006
    2) V6
    3) 2WD, LSD
    4) DoubleCab, Longbed
    5) TRD, PreRunner
    6) Delicate Windshield and it turned off on me twice on different occasions while I was driving. Luckily, I was driving in a Mall Parking lot.
