Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Oct 3, 2009 at 4:12 PM
    #361
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    Is this something that will be covered under Manufacturers warranty ?. Shall be thankful if u can reply to me.
  2. Oct 3, 2009 at 4:25 PM
    #362
    GTVAPSAMTIK
    SOHAIL
    Fort Carson, CO
    Can someone STICKY this post please. Best post ive red since Ive joined the forums 4 days ago.
  3. Oct 3, 2009 at 4:33 PM
    #363
    Strev
    Strev Member
    Boynton Beach, FL
    TRD Sport Prerunner
    A couple scratches on front bumper when garage door fell on it. Crease in the back bumper where my truck got into a fight with a pole.
    2006
    V6
    2wd
    Double Cab
    TRD Sport
    I have had problems with my AC... 1st I had a ticking in my fan ... they fixed it... now My ac wont turn on unless I turn it on and off real fast about 10 times.. My Compass/thermometer seems to not be working
  4. Oct 3, 2009 at 7:38 PM
    #364
    joe rhodes
    joe rhodes New Member
    Mine did that,they ordered and replaced the radio,now the new one does the same thing.I'm gonna buy a real radio pretty soon.
  5. Oct 3, 2009 at 7:44 PM
    #365
    TacomaZappa
    TacomaZappa Member
    Brian
    Orange County Ca.
    "09 AC Auto 6Cyl TRD SR5 Prerunner OR Stock
    Stock
    '09 AC TRD 2WD auto loaded Prerunner 1,300 miles.
    I have beat the crap out of this truck since brand new and have experienced none of the problems other than the crappy sound system.
    It's a truck, not a Rolls Royce.
  6. Oct 4, 2009 at 9:38 AM
    #366
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    I forgot to put my battery on the list.It was replaced at about 34,000 miles.
    P.S. The oil leak on the square cover on the number one head is still leaking after hosing it off. Not a big deal it's only 4 bolts and may take about 15 to 20 minutes to fix. Apparently the dealership tried to reuse the gasket when I took it back for the VVT problem.
  7. Oct 7, 2009 at 4:54 PM
    #367
    jinxed77
    06 4.0L TRD SR5 4x4
    I have a update. The square cover leak did continue to leak. The retarded Toyota tech put the freakin thing on backwards. The curved edge was to the inside when I believe it is supposed to be on the outside. I pulled it off and I could see bolt marks on both sides confirming it was on the other way at one point. Could someone look at theirs and please confirm this.
  8. Oct 15, 2009 at 1:38 PM
    #368
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    1) 2010
    2) V6
    3) 4x4 off road package
    4) double cab short bed
    5) TRD
    6) very minor issues:
    the left side of the tail gate does not close perfectly flush with the body. its about 1/4 inch off. (in fact, you can see it in my sig pic)
    the brake pedal makes a squishy, hydraulic sound when pressed. the brakes are perfectly fine, its just the pedal noise.
  9. Oct 15, 2009 at 11:03 PM
    #369
    notquiteright110
    notquiteright110 Active Member
    knucklehead
    NE Texas
    07 taco DC 4x4 debadged
    black head lights, flowmaster exhuast, cheep beep mod, rear fog lamps, more to come when i find the money tree
    1) 2007
    2) V6
    3) 4x4 DC
    Have 85,000 miles on it and took it in at 15000, told them about the truck bottoming out when hitting a small pebble on the road. Could not haul any thing heavier than my dog in the back. Finally saw the TSB when I had 75,000, thank God I kept the paperwork when I told them about the suspension problem, they fixed that. Clanking when backing up slowly within the first 20 feet, and when going forward. Dealership advised it was normal... Kept the paperwork. Truck wants to pull to the right now had it alligned at 80,000 was out on one part, still pulls to the right. Dealership said it was the tires and to check with the tire installer, starting the circle effect. Had an issue with the air conditioner blower motor ticking. Took it to the dealership several times and replicated the noise for them. The service tech asked if I really knew I was hearing things since he did not hear it... got really loud and angry with him chased him back in the dealership. Took it to another dealership and they fixed it first time. Will reccomend to anyone thinking about after market wheels make sure they do not use the sticky weights. I have had hell with keeping the weights to stay on, wheels have to be balanced every rotation, and sometimes between rotations. Other than the fore mentioned novel, I love this truck!!!
  10. Oct 17, 2009 at 2:48 PM
    #370
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    I have eight days/285 miles on my Taco's "clock". It's a 2010 Access Cab, 2WD, 2.7L/5spd/LSD, SR5.
    I've thoroughly examined the thing and not found a flaw. Everything works without strange noises. I've owned Toyotas for thirty years. If something was wrong, I'd know it. I'm a very sensitive guy.:rolleyes:
    First fuel refill was at 275 miles. The fuel gauge is accurate: 10.5 gal to fill a tank showing 1/2 full. 25.8 mpg for that bit of mixed city/highway driving (mostly city) was very satisfactory but I'm not going to shout about it until I have a 10-tank average.
  11. Oct 17, 2009 at 10:53 PM
    #371
    Reidm3
    Reidm3 Active Member
    2009 TRD Sport DC/SB V6 4x4 Auto w/5000 miles - bone stock
    I started the truck in my parking structure and drove it 20 feet before the engine sputtered and died. Annoyed, I didn't bother to diagnose whether there was fuel or spark, and had the truck towed to Toyota. The dealership has not yet looked at the truck, but is confident that they can diagnose and fix it on Monday. We shall see.
    This is the first new vehicle that I haven't immediately voided the powertrain warranty on, and oddly enough it's the first to break. :confused:
  12. Oct 19, 2009 at 11:26 AM
    #372
    somek1d09
    somek1d09 Member
    Brett
    Mendon
    08 TRD Sport
    Two Kicker L5 subs with a Kenwood 1800 watt amp and Dual indash moniter. Flowmaster 50 series single in dual out right infront of the rear tires. Future Mods: (Within next month) URD True Cold Air Intake Airaid Throttle Body Spacer Future Future Mods: (When I get the money.) Toytec 3" lift Bilstein 5100s all around URD Short throw shifter Tints Custom Paint Dick Cepek DC-1s with 31"-32" tires All New Door Speakers/Components Total Chaos UCAs Custom Upholstery HID lights/fogs much more to add later on!
    beyod my previous issues, i now have more to add.. My Tire Pressure Sensors are all gone or something the light won't go away and my tire pressure is all good, my airbag light just came on. E-brake sensor says the e-brake is engaged when it isn't and comes on when i start driving and hit the brakes to slow down or let off the clutch to go. bolts holding the bed down keep coming loose after i've torqued them down along with lock-tight. Tail-gate is extremely creased, yet i have not put any weight on it for an extended amount of time, nor have i dropped anything on it.. Dealer says warranty won't cover it.. The most amount of weight ever on the tail gate is 225lbs, and thats my dirtbike.. and i use a ramp to get the bike into the truck.
  13. Oct 19, 2009 at 12:35 PM
    #373
    itsaquiky
    itsaquiky New Member
    Fort Worth, TX
    Grey '22 Tacoma SR V6 4x4
    TRD Wheels, Tacoma tailgate black lettering, badge blackout
    1-2009
    2-V6
    3-4wd
    4-DC-short
    5-TRD
    6- I have noticed a lunging or jumping in RPMs when shifting from 1/2 or 2/3
  14. Oct 23, 2009 at 12:16 AM
    #374
    cwrose
    cwrose Don't spreadsheet this...
    Fairbanks, AK
    2023 Tacoma TRD OR DCSB in MGM
    1) 2006 (11/05 Build Date, 04/06 Delivery Date)
    2) V6
    3) 4WD, Automatic
    4) Access Cab, Long Bed (standard)
    5) Sport
    6)
    I. Lower Left Dash Panel poor fitment fixed under TSB (Don't ask me how, but the only dealer within 300 miles took 6 trips to the shop to fix it. I read the TSB and it was plain as day on how to fix it; I asked the service manager wtf? and got the standard apologies)
    II. Radio suffered catastrophic power failure three times, each one replaced under warranty. I sold my truck before anymore could die on me.
    III. During extreme cold weather (-40F or colder), interior dome light and door ajar light would not turn off no matter how hard the door was shut. Problem never fixed as it "could not be duplicated" by the tech. I don't find this a fault with the truck however, as everything breaks in that type of weather.
    IV. Engine tick was too annoying, so I had the TSB for new exhaust manifolds performed. Didn't fix the problem.
    V. I'm not going into detail because I get tired of explaining it to people, but on three occasions my truck suffered sudden acceleration. Each time was at a stop light and was calmed by putting it in neutral and shutting the engine off. Toyota says it's "driver error".
    VI. I never got a copy of the TSB, but apparently Tacomas with certain build dates were shipped without a piece of foam? around the airbox or something. Basically, when in reverse, it made for a slight rattle (plastic on plastic noise) near the passenger front quarterpanel. Toyota fixed this; I didn't ask them to elaborate, but the noise went away.
    VII. Heater core was replaced the first winter, as it developed a nasty whine. Bad enough that The radio couldn't drown it out. Oh, and it stopped blowing warm air right about when the temperature dipped below zero. Dealership said many earlier 2nd gen models had defective heater cores.
    VIII. Overhead console/compass failed. Replaced under warranty. Apparently that is common.
    I think that's about it. Nothing that made me despise my truck, but between the many little issues and the way the dealership handled them, I am glad that I sold the truck. I'm probably going to purchase another one next year, so hopefully some of those little issues have gone away. :pray:
  15. Oct 23, 2009 at 12:44 AM
    #375
    cwrose
    Fairbanks, AK
    Whoa! It's taken me quite a while to find someone with a similar problem. This happened to me on my Access Cab. The dealer could never replicate the problem, so it wasn't fixed. I asked that they replace the door sensors, but they wouldn't without experiencing the problem themselves.
  16. Oct 23, 2009 at 1:33 AM
    #376
    SubFrozen
    SubFrozen r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    1) 2007 Tacoma
    2) V6
    3) 4WD, Automatic
    4) Extended Cab, 4' bed
    5) TRD SR5
    6)
    When radiator is out of fluid, it will not pull from the reservoir, which will keep any low fluid light from coming on even if you fill the reservoir (Which will stay full). When radiator has no fluid, and sensor is not in liquid, reports normal running temperature. This caused a total failure of the engine.
    Anyone experience anything similar?
  17. Oct 24, 2009 at 10:15 AM
    #377
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I thought i read another from you about a missing hose clamp?
    If the case, it sounds to me like the beef would be with the last person who serviced it (the radiator / coolant) in that case. If you bought it used, did you get or at least look at the maintenance records and try and find out who serviced the radiator?
    Tough break, either way.
  18. Oct 24, 2009 at 2:34 PM
    #378
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I just bought a used 06 prerunner sr5 and I noticed on both sides under the door area theres a line in the paint that looks like sorta orange peel. Like I said its on both sides. I doubt the truck has been in an accident I had an autocheck done by experian and nothing came up. Is this just a bad paint on the weld area or what. Thanks
  19. Oct 24, 2009 at 3:03 PM
    #379
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    They all have that to help prevent rock chips.
  20. Oct 30, 2009 at 8:27 PM
    #380
    TA06CO
    TA06CO TA06CO
    Arvada, Colorado
    06 TRD O/R, 3in. Pro Comp Lift
    Brush Guard, 3 Stage Tonneau Cover, Side Steps, Silverstar Ultras, 3in. Pro Comp Lift w/ AAL, ES3000 & ES9000 Pro Comp Shocks, 285/75/R16s Yoko GEOs, Differential Drop, Carrier Bearing Drop...
    Just today I started to back out of a parking spot and it sounded like a terrible clunk, I first thoughtcarrier bearing /u joints etc. Took it to a shop and lifted it up. Not finding anything wrong. Although the sound still existed. Went home and thought to look at the drive shaft itself. Suddenly noticed there was a piece of protective metal between gas tank and drive shaft, maybe 3 inches or so, the metal was bent from offroading and was touching the drive shaft, this was something I would have never thought about. Now this piece of metal is very thin and easily bent out of place. I bent it back and took a spin and sound was gone.
