Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Oct 30, 2009 at 8:44 PM
    #381
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    1. 2008
    2. V6
    3.4WD/LSD
    4. DoubleCab, Shortbed
    5. Trd, Rugged trail
    6. When I go over speed bumps at about 5-10 miles mph it sounds like my bed is loose, a clunk sound. I guess you could say a little ticking from the engine.
  2. Nov 5, 2009 at 1:29 AM
    #382
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    1.2006 SR5
    2.TRD 4x4
    3.BFG ATs
    4.V6 Six Manual
    5.K&N Air Filter
    AC Compressor won't engage after 41k miles. AC amp unit accessory cable came loose and broke, replaced o-rings and got system recharged. Hear a light clicking noise from the left rear driver side door. Pull on door lightly and noise goes away and only on highway speeds.
    Found out today truck was in a front end accident w/ prior owner. Was never disclosed to me by the selling Toyota dealer. Bought certified used with 34k miles and no record on car fax of prior accident. :eek: Who knows what other abuse its' been through with only one previous owner.
    Hear light engine ticking noises. When clutch is disengaged, hear a slight rattling noise from left undercariage. When clutch is engaged, slight rattling sound is quiet but still lightly present. Also, when engaged in reverse and letting off clutch; hear slight ticking clunk noise from rear undercariage.
    Have driven vehicle offroad several times. Any relation to the condenser coils or amp unit disconnecting while offroading is beyond me. Or possibly caused by front end accident, prior damage and never corrected.
    Last, whenever offroading and applying brakes to stop either suddenly or from a down hill sloap; hear front left and right front winding noises near the front axles and brake pedal apears to stiffen when applied.
  3. Nov 5, 2009 at 6:54 AM
    #383
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    1) 2009
    2) V6 Auto
    3) Prerunner Off Road package
    4) Double Cab/short bed
    5) 4 5100s with Eibach coils on the front (1.6" lift) and waiting to do rear TSB when the TSB is updated for 2009 vehicles
    6) I bought the truck brand new and when I first received the truck it did not want to crank on the first time for the first couple of weeks I had it (bad gas I think). Only once I had the light behind the stereo go out until I hit a large bump and it came back on. I can't wait to get the REAR TSB done!
  4. Nov 7, 2009 at 5:40 PM
    #384
    rustyg61
    rustyg61 Active Member
    Rusty
    Texas
    09 Double Cab, Speedway Blue
    Chrome front grille, cruise control, intermittent wipers, NASTA Nerf Bars. Fog Lights JVC Stereo Pioneer speakers
    09 Double Cab
    V6 Auto
    Every time I wash the truck I get water coming out between the door panels & the metal part of the door. There is always water on the door sills when I open the doors after washing on all 4 doors. Twice I have had water coming out my front passenger side speaker grille. It looks like the bottom seal on the window is 1/8" too short which leaves a gap for water to run inside the door. I pulled the panel off & pushed the plastic sheeting into the the glue strip around the door, but it still leaks. There should not be water inside the door to begin with! I haven't brought it back to the dealer yet, but will be bringing it in next week.
  5. Nov 7, 2009 at 5:50 PM
    #385
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    i have had that happen before too, after washing. cause i wiped down those parts and saw more water and dirt coming out of the areas you mentioned. but never through the speaker grille yet. thats whacked either way. let me know what the dealer tells you. might have mine checked, too.
  6. Nov 7, 2009 at 6:20 PM
    #386
    rustyg61
    Rusty
    Texas
    Will do!Mine has been doing it since I got the truck in August, but I didn't pay it much attention until I saw it coming out the speaker grille last week!
  7. Nov 7, 2009 at 6:31 PM
    #387
    thejetarmy
    thejetarmy Member
    09 4X4 6sp Sport
    1) 2009
    2) V6 6Speed
    3) 4X4
    4) access cab
    5) TRD Sport
    6) Stereo fades in and out while listening to the radio but not on aux. Took it to the dealer and a new radio is 6-8 weeks backorder.
  8. Nov 15, 2009 at 7:00 AM
    #388
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    - '09 regular cab 2WD.
    - 2.7L/auto.
    - Built 12/08 in Cali and bought new 4/09.
    - Driven 10K miles.
    - No issues of any kind.
  9. Nov 15, 2009 at 11:15 AM
    #389
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    2005 Access Cab 4x4 TRD OR
    5 speed auto
    I challenge anyone to beat this list:
    - Rear leaf TSB (replaced leaf pack due to excessive bottoming)
    - Torn front mud flaps replaced (design flaw with '05 flaps)
    - Air Conditioning compressor replaced (bit the bullet)
    - Front bumper TSB (new aluminum cross member due to design flaw)
    - Exhaust Manifold TSB (new manifolds due to exhaust ticking)
    - Two oxygen sensors (facked during exhaust manifold TSB)
    - Rear actuator replaced for the locking diff (locker wouldn't engage)
    - Rear locking actuator position switch replaced on two separate occasions (located on rear axle)
    - Premature death of various bulbs and leds in the dash area.
    - New fog light switch
    - Four new TRD OR Aluminum rims (peeling, bubbling finish)
    - Blown out front Bilstein shock (replaced with Bilstein 5100's on my dime)
    - Two rear side axle seals replaced (leaked gear oil in rear drums)
    - Rear brake shoes and drums replaced due to contamination from leaking side axle seals
    - Rear mud flap torn (replaced on my dime)
    - Rack and pinion replaced (worn internal bushings - clunking noise)
    - Lower control arms and ball joints replaced (excessive play)
    - Front left caliper replaced (seizure)
    - Front brake pads replaced due to seized caliper
    - New hinges on drivers door (worn pins/bushings)
    - Heater / AC control box replaced due to non serviceable, burnt out LED back lighting.
    - New sway bar bushings due to excessive play/clunking
    - New battery
    - One of the rear "updated" TSB leafs snapped (replaced on my dime).
    - Front right wheel bearing imploded
    - Front right brake caliper seized
    - Brake pads replaced again due to seized caliper
    - Another new front rim replaced under warranty.
    - Replaced all 24 lug nuts due to aluminum caps falling off/disfigured.
    All this in 93,000 miles. I use my Truck, but NEVER abuse it.
  10. Nov 29, 2009 at 7:31 PM
    #390
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Dude, I am sorry to hear you had all of those problems.:eek:
    My 05, that I bought new, 48K now, has never had anykind of issue besides a bad battery once & the 4 shitty tires I replaced at 28K. :confused:
  11. Dec 2, 2009 at 10:48 AM
    #391
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Two Issues. 1.) Squeaky ass springs in the rear, wtf?
    2.) I have to turn my front rotors almost daily with all the front braking power, thus vibrations while decelerating.
    Anyone throw a disc conversion on the rear yet?
  12. Dec 2, 2009 at 10:49 AM
    #392
    AzPrerunner05
    Tucson
    Oh the design flaw with the front mud flaps on the 2005's, the problem is they crack after landing.
  13. Dec 3, 2009 at 5:19 PM
    #393
    lightfire
    lightfire Well-Known Member
    I hope you are kidding...
    This thread is making me paranoid about a near future purchase of a Tacoma. I have a 93 toyota 4x4 with over 300,000 miles and it has had NONE of these issues. everything is still tight, no noise. I also have a dodge diesel with over 100K on it and it has NONE of these issues. Is Toyota making a piece of crap now?
  14. Dec 3, 2009 at 5:33 PM
    #394
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    i think the dealer is feeding you fluff and a lie of crap. Mine used to do that until i had my tires rotated. i think the main issue is either front end alignment or a tire wear rotation issue. that doesnt make sense for it to steer to the right. they just tell people anything to avoid fixing the issue. took me several times of going back to the dealer under warranty to have them fix a similar issue on an 2004 i once had. they ended up replacing the steering rack but made me wonder if that even was the issue. i think the older toyotas are built better, from seeing all the issues people are having with the new ones? :confused: keep in mind, they are no longer truly built in japan anymore and imported and put together in california or in the USA someplace. so the quality of workmanship is no longer good?
  15. Dec 4, 2009 at 12:33 AM
    #395
    bigsur
    bigsur Well-Known Member
    Stephen
    Big Sur, CA
    2010 4dr 4x4 short bed
    2010 DC TRD 4x4
    1500 miles
    No problems yet, none anticipated for the future.
  16. Dec 5, 2009 at 8:40 AM
    #396
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    2008 Access Cab
    TRD Sport
    18,000 Miles
    My windows sometimes rattle if they are only partially down.
    My rear springs were squeaking (fixed with some WD-40).
    Clutch pedal squeaks certain days (WD-40 helps for a day).
  17. Dec 6, 2009 at 1:57 AM
    #397
    tictoc
    tictoc Active Member
    HAWAII
    FABTECH
    fabtech 6 in,33 procomp x terrain/micky thompson 17" beadlocks,steering stabilizer kit,k&n 77 series intake with throttle body spacer,ravin exauhst
    1) 2005
    2) V6
    3) 4wd LSD
    4) access cab
    5) TRD 6 in fabtech lift w/ dirt logic shocks
    6) buzzing noise from winsheild area at high speeds, airbag light turns on happend to me twice...a lil high pitched trow out bearing sound from my trans...goes away wen i engage the clutch, torque bolt became loose from large amounts of off-roading... after i tightened them it went away,somewere in the steering has a knock once in a while wen off roading,right side lower ball joint went super fast! so did the right side tie rod end with it.
  18. Dec 6, 2009 at 2:05 AM
    #398
    alvto
    alvto Active Member
    :spy:its not the truck its the driver rule of advice dont drive the truck let the truck drive you!! lol
  19. Dec 6, 2009 at 6:42 AM
    #399
    cdon38
    cdon38 Member
    texas
    07 tacoma sr5 prerunner trd
    Had same issue with wind noise, dealer resealed windshield, good to go
  20. Dec 6, 2009 at 1:16 PM
    #400
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    2008
    2x4 Manual
    Access Cab
    SR5
    Everything stock except BF ATs
    No problems really. Rear suspension was a bit squeeky a couple of times, but that went away. Clutch pedal used to creek and squeek but dealership fixed that no problem.
