Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. May 14, 2011 at 8:22 AM
    #501
    rockinthesix
    rockinthesix New Member
    Chase
    Canada
    2011 SR5 4x4 Access Cab (4cyl)
    headlights
    1) 2011
    2) Engine (V4)
    3) Drive Line (4WD)
    4) Body Configuration (AccessCab)
    5) Suspension (Stock)
    6) Whistling noise from windshield (kazoo) in crosswinds when over 110 Kmph. 75db wind noise from rear of cab at any given time during >70Kmph speeds.
  2. May 14, 2011 at 10:18 AM
    #502
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    1) 2010 model (built at Toyota de Baja California in 2009)
    2) V6
    3) 4WD, Traction Control and Locker
    4) Double Cab, shortbed
    5) TRD Off Road
    6) NONE... Best Tacoma I have had of the three!
  3. May 14, 2011 at 1:44 PM
    #503
    MattS67
    MattS67 Well-Known Member
    2) 4.0 V6
    3) 2WD
    4) Double Cab Long Bed
    5) TRD Sport
    6) Mild vibration when cruising between 45-55mph. I plan to bring this to the dealer's attention when I take it in for its first oil change and request a road force balance.
  4. May 14, 2011 at 1:59 PM
    #504
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    Bad clutch! My 2010 4 cyl., 5sp., 4X4 developed a slipping clucth at only 6,000 miles. It was particularly noticeable when I accelerated in 4th or 5th. The dealer could not reproduce the slipping so I waited another 500 or so miles and took it back. It appears ther is a 'silent recall or shop bulletin with a specific number on clutches. The plates made in Mexico tend to develop bent the fingers. I requested a replacement with the Japanese manufactured pressure plate. They took it all apart and replaced the clucth, pressure plate, and all related parts free. They also provided a free loander car during repairs. I had to be persistant, but they did fix it effectively. It now has the full wanrrenty on it. My truck has got 9,850 miles on it. It was frustrating, but eventually I was very satisfied.
  5. Jun 30, 2011 at 8:30 AM
    #505
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    2008 Rugged Trail Edition TRD V6
    Vibes between 15-10 TSB done but turned out to be Airaid Shroud
    Daytime Running lights have melt spots.
    N0 other issues.
    18MPG city/21Hwy
  6. Jun 30, 2011 at 10:38 AM
    #506
    NoDrAmA357HK
    NoDrAmA357HK Well-Known Member
    Michael
    North Carolina
    2011 Timberland Mica DBL CAB 4x4 TRD Sport
    3" Pro Comp w/ AAL, 17x9 -6 Offset 4.75 Backspace Pro Comp 7033, LT285/70/17, Xtreme M/T Pro Comp - 67285
    1) 2011
    2) V6
    3) 4x4
    4) Double, Short
    5) TRD SPORT
    6) Needs 3" lift, 32's and Road Armor/ARB/Relentless Bumper from Factory :)
  7. Jun 30, 2011 at 1:16 PM
    #507
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    the climate fan squeaks like crazy when on #1 or 2. i actually now have a noise when the air conditioning compressor is running and its not the initial clunk of it coming on either it like a clatter of some type and its consistent the whole time the compressor is running.
    it also sounds as if there is a leak somewhere on the exhaust system, but i believe that this is common with these trucks and there is nothing actually wrong, but they will be hearing about it and checking it out anyway.
  8. Jun 30, 2011 at 1:27 PM
    #508
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    1) 2011
    2) 4.0L V6
    3) 4 x 4
    4) Double Cab, Short Bed
    5) TX Pro
    6) I believe it's all across the board for all Tacoma's but I have always (for the short period of time I have had the truck) noticed it's "spongy" or "soft" brake pedal. It seems to have enough braking power when you really need it but not enough easy "intermediate" or light braking. Ah well, the truck's awesome otherwise. :goingcrazy:
  9. Jun 30, 2011 at 1:48 PM
    #509
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    1) 2010
    2) V6
    3) 4WD, and Traction Control
    4) DoubleCab Shortbed)
    5) Stock
    6) Have had 3 front diffs in my truck, 4 blower motors, and it has 35k miles. Now I am taking it in for the popping noise the front end makes when going up or down a hill at low speeds with an angle. For example, coming out my driveway. Also will have them check out the vibe at 20 mph and the grind at 60 mph
  10. Jul 3, 2011 at 12:51 AM
    #510
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    1. not one damn thing!.
    2. '' '' '' '' ''!.
    3. ect , ect, ect.........................:D
  11. Jul 3, 2011 at 6:58 AM
    #511
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    What the heck Toyota! I pay over 20k for a truck and the speedo is off almost 10mph. and you can't fix it?
  12. Jul 3, 2011 at 7:08 AM
    #512
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i had a pussy magnet installed and the first one broke so i up graded it and now they chase after my truck whilst throwing their undergarments at me :)
  13. Sep 1, 2011 at 3:28 PM
    #513
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    1) 2011
    2) V6
    3) 4wd with ATRAC and locker
    4) Access cab
    5) TRD with 3" spacer lift in front and 285s
    6) My leaf springs squeak like a bitch!!! but other than that no real serious problems
  14. Sep 1, 2011 at 3:43 PM
    #514
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    1. 2002 49k
    2. 2.7
    3. 4wd open rear
    4. extended cab
    5. Stock suspension
    6. Dash board rattles(pass. side. Side window of extended cab latch broke. Emergency brake cable broke, other than that it is a good truck.
  15. Sep 1, 2011 at 3:53 PM
    #515
    Paulie
    Paulie
    USA
    Tacoma
    Amsoil chain lube can be used as an undercoating. don't use tradition undercoating. I go under my truck every year and touch it up. It will last forever that way.
  16. Sep 1, 2011 at 4:20 PM
    #516
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    1) 2011
    2) 2.7
    3) 4x4 W/LSD
    4) Access Cab
    5) SR5, 5100's F/R, Eibachs, Toytec.5 spacer dr/s, .25 p/s, rear spring tsb w/Toytec 1" blocks
    6) Only issue i have had was the blower motor squeak. Oh and the lack of money to mod...
  17. Sep 26, 2011 at 12:24 AM
    #517
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Forgot how many times i posted on this thread. MY 1999 was bullet proof, my 2009 has had more fucken problems than I can remember. I still like it, but if you put a NEW 1999 & 2008 the same Tacomas I had. I would take the 1999 - this just in it was a 99 the last year for 10x31 tires. Like I was saying that little truck was like a Jeep pickup but better than jeep crap. I'd take a new one, put a blower on it, small lift & tires. Dam I miss that fucken Taco. I'm not saying I don't like the 2008 it's bigger and so on, but the 99 has my heart. Thats all:eek:
  18. Sep 26, 2011 at 12:29 AM
    #518
    Mr.Ed
    Wilbur's Barn
    That is my 2008 not 2009, my other one was a 1999. I wish I had the money to put one away for 10 years. Miss that truck.
  19. Oct 20, 2011 at 8:31 PM
    #519
    coloradotacoma
    coloradotacoma Well-Known Member
    1) September 2011 Build Date
    2) V6 Automatic
    3) 4WD w Traction Control
    4) DCLB
    5) TRD Sport
    6) Odd Shifting/Not shifting down till RMP's are pretty high. Does this Randomly
    Feels wrong when shifting, like it doesn't want to get into the right gear.
  20. Oct 20, 2011 at 8:32 PM
    #520
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    2009 TRD O.R.
    DCSB
    4.0V6
    Auto
    285/75/16
    Stock wheels
    3" Toytec with AAL
    5100 Bilistein
    C-my build page. No issues with my truck
