Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Dec 20, 2011 at 8:24 AM
    #541
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    #82 of 111 Re: New Tacoma driveline vibration! [nelz1] by will39
    Nov 16, 2008 (7:28 am)
    Replying to: nelz1 (Dec 12, 2007 10:59 am)
    Toyota now has fix for this,Rear motor mount replacement will stop this
    vibration, Had mine replaced with heaver mount,Moter was vibrating
    at 20 mph.Call your deler new bullitin out on this.
  2. Apr 14, 2012 at 8:57 AM
    #542
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The body cross member that supports the radiator, hood latch, grill and horns is made of sheet metal slightly thicker than heavy duty aluminum foil. My truck has only 28 k miles, but vibration from driving over the washboard roads into my town has started cracks near the spot welds where the outboard horn is mounted. I fixed it with a piece of 1/8" x 1" aluminum angle, but I think a stouter cross member should have been designed.
  3. Apr 14, 2012 at 9:55 PM
    #543
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Rattle is fixed, put a long piece of black plumbing insulation (dense foam) between dash and windshield and that took care of it! You hardly notice it! Now knock on wood there aren't any issues right now!
  4. Apr 14, 2012 at 10:14 PM
    #544
    tacomafide
    tacomafide Cheese it in there!
    Sean
    Alberta
    '10 DCLB TRD Sport+Leather Pkg.
    de-badged, de-stickered, no jewlery, level kit (removed after second front dif), tint, skid plate (now dented), front tow hook off of Land Cruzer, reciever d hook (cleavis), yellow wire mod, abs kill sw. mod, window visors, stubby antena, anytime reverse lights mod, anytime reverse camera mod, blizzacks on stealies, bed lights mod, weathertec mats allround,
    2010 v6 DCLB TRD Sport 32k km's bought new in March 2010
    On my 3rd blower motor (squeaks and sequels)
    Intermediate shaft (steering linkage) worn out at 20k km's WTF!!
    Cigarette lighter replaced (shoots out red hot and goes wherever it wants)
    Leaf spring isolater thingy replaced (worn out after 18k km's) causing rear end to squeak when suspension traveling WTF Again!!
    2nd wiper motor ( made a lot of noise)
    Dealer installed level kit removed after 2nd front diff replaced due to vibes @ 50- 60 km/h
    While they had it on the hoist the rear shocks blew out!!
    I'm sure there is more but I can't remember right now. I love this truck but it has had more problems than my last 2 new fords put together. Needless to say my friends and co-workers won't be buying a Tacoma any time soon.
    Even my wife who owns a matrix ( which is why I went with Toyota) won't be getting another one.
    Like I said ( and I might be crazy) but I love this truck and I stick up for it like its my family or something. I take a lot of ribbing about what a piece of shit this thing has been. Whatever. I'm a mechanic, I know things fail, but where's the F'n Kaizen??
  5. Apr 14, 2012 at 10:30 PM
    #545
    tacomafide
    Sean
    Alberta
    For what its worth on one of the MANY papers I got from the dealer after these bullshit repairs it said the squeaking in the blower motor was cause by the "brushes" . You could try ordering brushes if you are off of warranty. I would assume they are made of a different grade carbon or use a different binding agent if they have had so many problems with the oem ones.
  6. Apr 15, 2012 at 10:36 AM
    #546
    tacomafide
    Sean
    Alberta
    Dido
  7. Apr 24, 2012 at 5:42 PM
    #547
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    my exhaust is melting/bubbling the area behind the passenger back tire, bumper started rusting at 500 miles several squeaky blower motors, creaky/squeaky windshield that occasionally leaks.
  8. Apr 24, 2012 at 5:50 PM
    #548
    tacomafide
    Sean
    Alberta
    Yeah that's another thing exhaust staining up the bottom side of the quarter panel. The dealership ppl were like put a tip on, that way the exhaust comes out a little further away. And I was like "don't you think kaizen should have taken care of that when they built this pile. Buff that shit out and I'll be back tomorrow to check your work"
  9. Apr 24, 2012 at 6:11 PM
    #549
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    1) Year or Build Date of your Tacoma - 12/2007
    2) Engine 4Cyl
    3) Drive Line 2WD Base
    4) Body Configuration Regular cab 5 Lug
    5) Suspension Base
    Edit: Oh ya... I forgot about #6, defects or issues...
  10. Jun 3, 2012 at 3:30 PM
    #550
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    2009
    2) Engine (V6 or 4Cyl)
    V-6
    3) Drive Line (2WD, 4WD, and whether or not you have Traction Control or a Locker/LSD)
    2-wheel drive
    4) Body Configuration (AccessCab/DoubleCab and Longbed/Shortbed)
    Access cab
    5) Suspension (TRD, PreRunner, or Stock)
    TRD
    6) Discribe your issue/defect as best you can if you have any.
    DTRL's are melting the lenses. Suspension 'clunks' or unwinds when stopping.
    Ray
  11. Jun 3, 2012 at 5:09 PM
    #551
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    1) 2012 Tacoma
    2) Engine 4Cyl
    3) Drive Line 2WD Auto Traction Control, LSD
    4) Body Configuration AccessCab
    5) Suspension PreRunner
    6) No Problems at all.
  12. Jun 3, 2012 at 5:15 PM
    #552
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    No problems with my truck at all, my truck info is under my username. Oh there is one annoying thing, I cant seem to get my 4wd to engage when offroad, I eventually gave up and just chalked it up to not having a front diff and transfer case.
  13. Jun 11, 2012 at 7:38 PM
    #553
    NoDrAmA357HK
    NoDrAmA357HK Well-Known Member
    Michael
    North Carolina
    2011 Timberland Mica DBL CAB 4x4 TRD Sport
    3" Pro Comp w/ AAL, 17x9 -6 Offset 4.75 Backspace Pro Comp 7033, LT285/70/17, Xtreme M/T Pro Comp - 67285
    1) 2011
    2) V6
    3) 4x4 Sport
    4) Short Bed
    5) TRD
    6) Blower Motor for A/C squeal/chirp - Fixed/Resolved by Dealership
  14. Jun 11, 2012 at 8:10 PM
    #554
    superfair92
    superfair92 Well-Known Member
    Tennessee
    12 Tacoma TRD Sport DC 4x4
    Debadged, Step Tubes, Tint, WeatherTechs, Extang Solid TriFold
    1) 2012 Tacoma (Built 3/12)
    2) v6
    3) 4WD w/ Traction Control
    4) DoubleCab Shortbed
    5) TRD Sport
    6) 1 month old 3,000 +/- miles (Yes 3k) no problems to date
  15. Jun 16, 2012 at 5:15 AM
    #555
    11Speedway
    11Speedway Well-Known Member
    Held Hostage in Tennessee
    Stock 11 TRD OffRoad Access Cab
    I have the windshield wind whistle issue, along with easily marring interior.
  16. Jul 23, 2012 at 8:44 AM
    #556
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    1) 20102) V6
    3) 4wd off road
    5) TRD OR
    6) Blower fan replaced 4 times now
  17. Jul 23, 2012 at 9:09 AM
    #557
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    2012 Off-Road Double Cab Automatic
    6300 Miles
    * Acceleration Vibration (Stock Suspension)
    * My brakes squeal when i stop
    This coming week will be the third time they will work on the brakes. They stop squealing for a little while after they work on them and then go right back to loud as hell.
  18. Jul 23, 2012 at 10:44 AM
    #558
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    2011 standard cab 4 cylinder, 4 spd. automatic, 4x4. ~18K miles
    recently had the second replacement of heating/cooling blower fan/motor assembly for ticking and rattling noise. Still under warranty.
    First replacement was about 10 months ago for the same issue.
  19. Jul 25, 2012 at 11:53 AM
    #559
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    2012
    V6
    4WD, ATRAC & Locker
    AC/LB
    TRD
    6) Describe your issue/defect as best you can if you have any.
    Right front CV joint developed a click after 3 days/180mi. Going into dealership on Friday. I'm guessing they'll find no grease in it. Will update this post with the resolution.
  20. Oct 14, 2012 at 7:04 PM
    #560
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    1) 2012
    2) V-6 with auto
    3) 4WD with TC
    4) Double Cab
    5) TRD
    6) nothing - and after just finishing a 2597 mile road trip pulling a 3000 lb trailer
