Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Oct 14, 2012 at 8:37 PM
    #561
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    1. 2008 (39,994miles)
    2. V6
    3. 2WD. No TC/Locker
    4. Access Cab
    5. PreRunner
    6. no problem that I know of so far. typical noise for a truck here and there, it ain't a Lexus.
  2. Oct 15, 2012 at 9:16 AM
    #562
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    1. 2008 89,000 miles
    2. V6
    3. Double cab Pre Runner E-Locker
    4. Every now and then when i come to a complete stop I get a huge rear end thunk. I have no idea what it is and it trips people out the whole truck moves. Its always done it and toyota just said that was normal. Never had a rear end issue but it sure does drive me crazy.
  3. Oct 15, 2012 at 10:00 AM
    #563
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I used to notice that to when I would pull into my driveway. I want to say it was the sound of gas sloshing around in the tank.
  4. Oct 15, 2012 at 10:19 AM
    #564
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    1) 2011
    2) 4 banger, 5 speed manual
    3) 4x4
    4) Access cab
    5) SR5 stock
    6) Only problem I had was the weak rear leafs that squeaked, got those TSB'd however and never had a problem since. It now has a stiffer ride, but it's a truck, not a Cadillac.
  5. Oct 15, 2012 at 4:03 PM
    #565
    SaraLynn44
    Sara Lynn
    Fresno CA
    08 PreRunner
    Oh no my is an actual thunk of the rear end its loud and you can feel the gears finally settle... no idea why but it hasnt broke yet so whatever
  6. Oct 27, 2012 at 2:00 AM
    #566
    Slizzy
    Slizzy Well-Known Member
    BC Canada
    '09 MGM TRD Offroad
    Bilstein 5100's @ 1.75" front & 5100 rear, Pro Comp 7089 16x8 4.5"BS, 265/75/16 Duratracs, color matched grille, black emblem
    I just bought my truck ( 09 access) and I just heard it for the first time. That's exactly what I thought it was.
    Seems silly as I just filled the tank. It's kinda loud and it shakes the truck lol.
    Lol... I though maybe I was being paranoid... The after effects of driving a broken down 94 pickup...
  7. Dec 30, 2012 at 10:20 PM
    #567
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    1) 2013
    2) V6
    3) 4WD A-TRAC
    4) DC LB
    5) TRD SPORT
    6) Front end squeak...whining wiper motors...windshield whistling...blown speaker...oh ya fogot to mention it sputters on start up occasionally in cold weather sitting overnight...
  8. Jan 7, 2013 at 8:56 PM
    #568
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    By blower motor squeal. Do you mean the high pitched ringing sound when you first startup?
    Do you ever let it sit in the "on" position before you actually start the engine? I always do this, especially if it's sit for a long time. If you listen closely you can hear the fuel pump kick on and build pressure etc.
    1, 04/2012
    2, V6
    3, 4WD A-TRAC
    4, DC SB
    5, TRD Offroad
    6, Passenger vanity mirror turns on/off when in use going over bumps, or if you tap it lightly with your hand. Loose connection or something in there.
    Otherwise I'm not sure if anything else is a problem... except for sag in the 2 leaf springs on the rear. When I turn off the parking brake and let off the actual brakes if I keep my foot lightly on the pedal I feel a slight "dragging" vibration or something in the pedal. I'm worried about this 'cause the last car I drove had a similar sensation and I found out I was running on no drums in the back... Also do you guys feel like the TPMS is a bit slow to notify? I don't know if I fully trust it but if I find out my tires wear incorrectly due to it they'll be replacing those WITH the TPMS.
  9. Jan 7, 2013 at 10:14 PM
    #569
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I always turn the ignition to the on position...wait 5 secs or so for the computer to wake up then turn it over...
  10. Jan 7, 2013 at 10:31 PM
    #570
    12TRDTacoma
    Rob
    Concordia
    Boosted
    2012
    V6
    4WD
    DC LB
    TRD Sport model
    Where to start:
    - alignment has never been right from day one, slowly drifts to the right during highway and some city driving.
    - ABS and VSC light are on at 6000 miles
    - intermittent sort of stutter or shuddering sensation when driving at parking lot speeds for a brief period of time then it goes away shortly after.
    I think that's all for now.
  11. Jan 8, 2013 at 3:48 AM
    #571
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    2007 Prerunner dcsb v6 auto
    No problems!
    Jim
  12. Jan 8, 2013 at 4:41 AM
    #572
    10DC4x4
    10DC4x4 Well-Known Member
    I have a 2010 Tacoma DC 4x4 6 speed, Took it in for the tsb on the clutch bearing, , to find out the TRANSMISSION. was bad!!!!!!!! They replaced it free of charge but out of all the people that have loved their truck and haven't had any problems, Why and I the lucky guy that gets a bad egg. FML lol
  13. Jan 8, 2013 at 8:11 AM
    #573
    replica9000
    2019 T4R ORP
    I didn't know you could get double cabs in 6spd. What was the symptoms of the transmission?
  14. Jan 8, 2013 at 8:29 AM
    #574
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Not feeling good about upgrading after reading some of these post...
  15. Jan 8, 2013 at 8:33 AM
    #575
    replica9000
    2019 T4R ORP
    What did you upgrade to? My truck is just about 5 years old without any real issues.
  16. Jan 8, 2013 at 8:41 AM
    #576
    DikDikerson
    DikDikerson Well-Known Member
    Devon
    Calgary
    13' 4x4 DCLB TRD Sport
    1) 2013
    2) V6
    3) 4WD
    4) DC LB
    5) Stock Suspension
    6) I get an intense clicking noise when I start it up in cold weather, usually when it's below freezing. It sounds like it's coming from the driver's side of the engine. Lasts about 30 seconds then goes away. To me it sounds too loud to be "normal" like the dealership said it was.
  17. Jan 8, 2013 at 9:59 AM
    #577
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Fuel injectors bud. I wouldn't worry about it. The sound intensifies the lower the temperature gets during initial start ups.
  18. Jan 8, 2013 at 10:00 AM
    #578
    DikDikerson
    Devon
    Calgary
    Good news, thanks
  19. Jan 9, 2013 at 4:57 AM
    #579
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    I'm looking at the 2013's.
  20. Jan 9, 2013 at 4:58 AM
    #580
    10DC4x4
    Just the same squeak that all the manual transmissions have . Nothing that seemed like internal transmission failure.
