Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Jan 9, 2013 at 12:03 PM
    #581
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Be careful, they are also known to have notchy shifting, and also sychro failure. I recommend all manual owners to buy the TRD shifter because it seems to get the shift gates dialed in correctly. As far as the synchro's go be very careful with those. I suggest doing some research on the different kind of oils that are out there for it. As far as I know synchro's are made of brass so you have to get something that plays well with those.
  2. Jan 9, 2013 at 8:05 PM
    #582
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    One thing to keep in mind is you're at a place where a ton of guys are willing to voice any small issue they've had and those will be talked about extensively. MILLIONS of people own Tacoma trucks and are just in love and will tell no one over the life of the vehicle, this is just how it works. Unhappy people will seek out people to complain to and happy people are far more likely to just not mention it to anyone.
    Read up. But take it with the knowledge that someone who reads 100 bad reviews and considers it a bad truck is selling them self and the truck REAL short.
  3. Jan 9, 2013 at 8:31 PM
    #583
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    ive been hearing alot of popping strange noises in my front driverside shocks
    . plastic idk what the hell it is
  4. Jan 10, 2013 at 5:03 AM
    #584
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Yea I understand that the guy with a problem usually is going to make the most noise...I own a 2001 Tacoma and love it, I'm just planning to upgrade while I can still get good money for my old truck! Reading around just to see what people are saying.
  5. Jan 10, 2013 at 5:32 AM
    #585
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    85K miles, 6 years, non warranty problems= $90 mud flaps Solved by Weather Tech!
    Pretty good record I'm thinking and I'm talking from the perspective of a half century of vehicle ownership.
    Is it perfect? No!
    Is it better than the competition? For me there was nothing close. For you?
    Would I buy one again? Yes, if they made some significant changes other than BNG.
    And for those who say they don't make them like they used to I say Thank God!
    Jim
  6. Jan 10, 2013 at 10:10 AM
    #586
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    1) 2011 built Sept. 2010
    2) V6
    3) 4WD, Traction Control
    4) DoubleCab, Shortbed
    5) TRD
    6)
    - 1000 miles: leaking refrigerant from AC condenser fitting, cross-over pipe rattling on heat shield, stripped engine cover bolt.
    - 5,000 miles: blower motor tick/squeal.
    - 10,000 miles: Not defects but observations-> a pop in the steering wheel when moving back and forth rapidly, engine sputter when cold and sitting overnight (only once), thud sound from rear when stopped and then releasing the brakes (maybe axle wrap), forward lurch when stopped and the AC kicks in (my 2003 did this also)
    Overall a really good truck and much safer for someone with a family. From an offroad perspective I do miss my 2003.
    RJM
  7. Jan 10, 2013 at 3:14 PM
    #587
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Most syncro failures can be linked to drivers that rest their arm on the shifter lever when driving, which causes excessive wear.
  8. Jan 10, 2013 at 5:04 PM
    #588
    Teton Tacoma
    Teton Tacoma Well-Known Member
    Wydaho
    2016 Off Road M/T
    Can't get the damn thing into Lo 4wd. :mad:
  9. Apr 28, 2013 at 11:08 AM
    #589
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    2013 Base
    Standard Cab
    4 cyl
    5-Speed
    2WD
    6,000 miles.
    No issues to date.
  10. May 9, 2013 at 1:27 PM
    #590
    Syncros
    Syncros Well-Known Member
    06 Access Cab V6 4wd. It continues to be very reliable but has some annoyances.
    - Cold start engine rattle. This is not the "normal" ticking sound, it's much louder and goes away within a few minutes of driving. Can't pin point it with my stethescope, it's been an on going problem for over 40,000km, has not gotten any worse. Piston slap is my best guess.
    - Exhaust manifold "flutter" noise at certain RPM's since I have owned the truck, I was well past the warranty before I realized there was a TSB to upgrade to the 07+ tubular style manifolds. :mad:
    - No grease zerk on the drive shaft slip yoke, next time I have to pull the drive shaft to grease the splines im just going to add my own zerk.
  11. May 9, 2013 at 1:43 PM
    #591
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    1. 2006
    2. V6
    3.2WD
    4. DoubleCab
    5.TRD Sr5 PreRunner
    6. No Issues, best & most reliable vehicle every owned!!!
  12. Jun 22, 2013 at 9:26 PM
    #592
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    1) '08
    2) V6
    3) 4WD
    4) Double Cab
    5) TRD
    6)Grinding/Clunking going in to 3rd
  13. Sep 22, 2013 at 8:08 AM
    #593
    04TacoOwner
    04TacoOwner New Member
    04 Tacoma Double Cab
    2004
    Tacoma
    V6
    Double Cab
    TRD
    I love the truck but I've got one major problem. About 6 months ago I noticed a rough texture to the paint on the roof. Within a month the paint deteriorated to the point where rust began to show through. The roof has been waxed in the past but I will admit that it didn't always get waxed as often as the rest of the truck because it is more difficult to reach. I've seen a few other posts about this problem.
  14. Sep 22, 2013 at 3:16 PM
    #594
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    1. 2012
    2. V6
    3.4WD
    4. DoubleCab
    5.TRD SKEWP
    6. Fine women all over my shit, blocking my view, it's really dangerous. I'm suing toyota. Anyone wanna class action w/me?
  15. Sep 10, 2014 at 2:00 PM
    #595
    Turttle98
    Turttle98 Active Member
    Abel
    California
    06 trd sport dbl cab 8.5 inch lift diamond whit
    8.5" lift kit with fox coilovers and double rear 2.5 fox shocks with bypass reservoirs on each side Kenwood ktv-516 indash kit Kenwood door speaker Kenwood tweeters 10" kenwood sub
    What did you do mine shuts off all the time especially at a stop like engine and power I need help
  16. Feb 4, 2015 at 2:51 PM
    #596
    ChadsPride
    Sponsored by TacomaWorld.com
    1) 2015 Texas Edition Super White
    2) V6 Automatic
    3)2WD, has traction control
    4) Double Cab, Short Bed
    5) Pre Runner - Stock suspension
    6)There is a buzzing noise coming from the glove compartment area, happens from 1000 to 2000 rmps. Not too extremely consistent but it happens just about every time i step on the gas in these ranges. Somebody, Anybody, please send me a PM if you know any way to make it stop. I just bought this brand new truck and the buzzing is about to drive me out of my mind.....HEEEEELLLLLLPPPPPPPP
  17. Feb 5, 2015 at 6:46 AM
    #597
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    This is kind of a goofy way of hopefully stopping the sound, but it has worked for me on other cars. Get some foam rubber and stuff it between cables and such behind the glove box. If you can take it out that might make it easier. This is to isolate the ''noise maker". One time I also took out the screwsl holding a glove box in place and made like little foam washers to further isolate the noise maker. That worked immediately and for the 10 years I had the car. It is cheap and easy and MAY work. Good luck.
    Silvert
  18. Feb 5, 2015 at 7:20 AM
    #598
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    1) 2014
    2) V6 Auto
    3) 4wd
    4) Double cab, short bed
    5) TRD Sport
    6) Some of the biggest things I have noticed about this truck is the wind noise when driving on the interstate. The rattle i randomly have that sounds like it is coming from my entune head unit. My rear leaf springs squeak on and off. Random axle wrap thunks when I come to a stop sometimes.
    Must of these issues are minor, but they are still annoying with a brand new truck.
    But all and all I do love my truck and I still think the 2nd gen Tacomas are one of the best looking trucks ever produced!
