Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Apr 4, 2008 at 4:31 AM
    #81
    Johnpa
    Johnpa Member
    South Florida
    2007 SR5 PreRunner, Roof Racks, Short Bed in Radiant Red
    Extang Tonneu Cover, Nasta Bars, Magnet Bra, BedXTender,
    1) 2007
    2) Engine (V6) Automatic
    3) 2WD
    4) Double Cab Short Bed
    5) Prerunner
    6) Wind noise from windshield when driving on highway with crosswinds.
  2. Apr 4, 2008 at 11:15 AM
    #82
    eye one
    eye one Well-Known Member
    1) 2006
    2) V6, 5sp Auto
    3) 4X4
    4) Access Cab
    5) TRD Off Road
    6a) Wind noise
    6b) Noise from the bed (only heard when slider open)
    6c) Doesn't always track straight, pulls left a little sometimes right sometimes wanders. Very minor annoyance, might just need to check tire pressure
    6d) Blown speaker, think it's right rear. Hear distortion at loud volumes.
    10,500 miles on the odometer, ownership for 3 almost 4 weeks now. I enjoy jumping in the truck and driving it, almost as much as my old WRX. I really looking forward to taking it off road soon, bought it to take on the beaches to surf fish. No major problems, only a handful of very minor issues/annoyances.
  3. Apr 6, 2008 at 7:57 AM
    #83
    revn247
    revn247 Active Member
    SoCal
    TRD Off Road 6spd Toytec stage 3
    Eclipse AVN-6620 w/ Sirius
    1) Year or Build Date of your Tacoma
    2008 2) Engine (V6 or 4Cyl)
    V6 3) Drive Line (2WD, 4WD, and whether or not you have Traction Control or a Locker/LSD)
    4WD 4) Body Configuration (AccessCab/DoubleCab and Longbed/Shortbed)
    DBL Cab 5) Suspension (TRD, PreRunner, or Stock)
    TRD OR 6) Describe your issue/defect as best you can if you have any.
    A) These are "features" of the emissions control that I absolutely want removed. The RPM surging between shifts. ( kicks up between shifts ) B) The RPM's coming up to almost 1500 while braking in neutral. This stops when you come to a complete stop. If you leave it in gear until just before coming to a stop you feel the vehicle wants to surge forward ( almost like the brakes give up then grab again...for lack of a better description) C) Soft brake pedal Is this combination (V6 w/ 6speed manual) designed to waste fuel in order to get better emissions???? So burning more fuel to get better emissions is a good trade off.....I don't see where that's an advantage. In addition...I thought the SR5 package (included w/ OR or Sport packages) came w/ a full set of gauges???? When did this change.. Sorry for the rant.
  4. Apr 6, 2008 at 7:00 PM
    #84
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    1] 2008
    2] V6
    3] 4WD, no traction, no locking diff
    4] Access Cab / Regular bed
    5] TRD SR5 Sport
    6A] Transmission
    - Seems like when I press the clutch to shift gears the RPMs rev up a little
    - Shifting from 2nd into 3rd is not as smooth as the other gears (but that is the same as my WS-6)
    - Letting off of the gas (usually while in 2nd), the truck slows down (engine braking), but sometimes feels as if the tranny shifts up a gear on its own like a automatic after a certain speed or RPM. This is usually right before coming to a stop.
    - Shifting from 4th to 5th sometimes kinda feels the RPMs jump up enough to momentarily feel like I'm shifting to a lower gear.
    - I'm going from a 330HP WS-6 6spd sports car to a 240HP Tacoma 6spd truck, so I'm expecting different behavior, but is all of this normal?
    6B] Paint
    - The last 4 inches of paint near the bottom of the sides of the truck seems like it was painted over lumpy (galvanized?) metal. Not sure if this is a anti-rust thing or painting error on both sides. The strip is even on both sides like it was done purposely.
    6C] E-brake
    - I can dis-engage my e-brake without pressing that little button, but I still have to rotate it. Still does it's function fine.
    The truck has just under 700 miles as the moment, so far no other complaints.
  5. Apr 7, 2008 at 8:41 AM
    #85
    iwc3714
    iwc3714 Well-Known Member
    PreRunner SR5
    Bull bar, oem side steps and 18" Enkei
    Built like a rock.
    Oh wait a minute quality is job one.
    Wooops wrong ads that goodness:devil:
    Not one problem.:thumbsup:
  6. Apr 7, 2008 at 9:02 AM
    #86
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    2008 DC Short Bed 6 Speed 4.0 V6 TRD Sport SR5..
    Just over 700 miles on the ODO.
    Got used to the odd shift points on my 6 speed (used to a 5 speed)
    -Still hate the RPM surge upon shifting
    -Same as noted before about 1st to 2nd shift, it isnt grinding, but it isnt as smooth as other gears
    -Interior scratches too easily.
    -and welcome me to the club of the vibration on deceleration I would say from about 24ish mph down to 12-15ish. Started around 500 or so on the ODO, and is getting progressively more noticeable. Fuel load, and ultimately rearward weight distribution affects this noticeably (IE Full tank of fuel Vs. almost empty).
    Waiting for them to add the 08's to the rear spring TSB, although I'm pretty sure the dealer would do it if asked (going to lunch with the guy who sold me the truck tomorrow, will bring it up).
    Also noticed one 1/2 inch long extremely shallow scratch in the clear coat on the passenger side door so I'll take it as the paint is easily scratched (noticed on preflight lol).
    Overall, I love this truck. Based on my observations regarding weight on the rear end affecting vibration on deceleration - misaligned drive line components seams like a logical explanation, not saying its right, but it should be an easy fix.
    I have also noticed slight wandering, I think its just like a young puppy, and it wants to play, and search and sniff, so its no problem, just got to keep an eye on it, or before you know it, it will be playing in the garbage again.
  7. Jul 28, 2008 at 1:12 PM
    #87
    2ndtaco07
    2ndtaco07 Active Member
    Santa Monica, CA
    07 TRD PreRunner
    Rear Suspension TSB 5100 up front @ 1.75
    1) 2007
    2) V6
    3) 2WD,auto
    4) Access Cab
    5) TRD Off Road SR5 prerunner
    I am getting Vibration sounds around the front passenger tire when the truck is put into reverse. It's pretty loud. Any one else?
  8. Sep 1, 2008 at 6:01 PM
    #88
    mcmikey
    mcmikey New Member
    2008 Tacoma
    I have the same 50+ mph vibration, mostly felt in the steering wheel. I've had the tires rotated and balanced 5 times, and the dealer measured everything and found it within factory spec. Has done it since new (2008 double cab, V6 4x4, AT). Extremely aggravating. The salesperson I bought it from has agreed to trade his truck with mine for a week to see if he can get some action. Would the driveline misalignment manifest itself with a steering wheel shudder?
  9. Sep 1, 2008 at 6:57 PM
    #89
    revn247
    SoCal
    I have/had this. Mine was when it moved in reverse. Stealer said it was my after mkt. radio...LMAO at that one. Just trying to weasel out of it. I take the radio out (AVN6620) and bring it back. They confirm that its not the radio. DUH.
    Turns out there is a TSB for it. EG5035 Air Intake Hose Rattle, Part no. 17882-0P010.
    It appears to be the end part where it enters the fender or is the part inside the fender. I still have lots of mud/dirt on the rest of the intake hose.
    I got a survey about the "service" I received. I told them they need better techs! My radio is the cause...WOW.
    For reference: 08 Dbl Cab 6spd TRD OR w/ Tow pkg.
    Now for the squeaky clutch......
  10. Sep 1, 2008 at 7:01 PM
    #90
    revn247
    SoCal
    Make sure that the place doing the balancing uses the correct adapter. ALL toyota trucks (Sequoia, Land Cruiser, 4Runner, Tacoma) are lug centric, not hub centric. If they balance it w/o the adapter (majority of vehicles) it will NEVER be balanced on the truck.
    You can tell by the lug nuts oh the vehicle if its hub centric or lug centric.
    HTH
  11. Sep 1, 2008 at 7:48 PM
    #91
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    1) 2009
    2) V6 4 liter
    3) 2WD, 6-speed auto
    4) Double Cab
    5) TRD Off Road SR5 PreRunner
    Less than 100 miles so far.
    I don't think the tires were properly balanced. Or maybe Bridgestone tires just suck. I never liked the ones on my Kawasaki.
    The truck seems to wander on the freeway with no load in it. I haven't tried it with a load on yet.
    No unexpected vibrations yet.
    I only got two D-rings in the bed.
  12. Sep 1, 2008 at 10:16 PM
    #92
    WestTexasTacoma
    WestTexasTacoma Active Member
    El Paso TX
    08PreRunner TRD Sport DC
    Jason Bed Cover, K & N Drop in Filter, Flowmaster 40 series Bilstien 5100's front TSB done
    1. 2008
    2. 4.0 V6
    3.2wd LSD
    4.Double Cab
    5.TRD Sport
    6. No issues :)
  13. Sep 12, 2008 at 10:10 PM
    #93
    hardin083
    hardin083 Well-Known Member
    Florida
    08 Prerunner SR5
    MODS: 3" EZ lift with 1.5" rear blocks,blacked out emblems,belt chime mod,20%tint job,driveline vibration TSB done,harsh ride TSB,285/75/16 nitto terra grapplers,EGR in channel window visors/future mods:seat covers, blacked out rims.
    2008 SR5 V6 prerunner double cab. i am having small vibration between 0-10 mph, whether stopping or accelerating. It seems to be slightly worst after putting my 3" lift on. Was considering going to the dealership but was curious on everyones opinion if i should take the lift off first? before taking it in. Cause we all know they will probly try and blame the lift and void the warranty or something. other than that i love my truck.
  14. Sep 12, 2008 at 10:49 PM
    #94
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    before you take the lift off, crawl under the truck and loosen the bolts for the center support bearing in the middle of the drive shaft, spray some silicone spray on the bearing/bushing, and maybe adjust the spot where the bushing is. then tighten the bolts and go drive it......may make the small vibes disappear.
  15. Sep 12, 2008 at 11:07 PM
    #95
    hardin083
    Florida
    08 Prerunner SR5
    thanks i'll try that tomorrow morning when i get off of work. might save me some time and hassle. ill let you know the results.
  16. Sep 12, 2008 at 11:17 PM
    #96
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds good man......let me know!!:)
  17. Sep 13, 2008 at 2:20 AM
    #97
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    I just have problems whit my cruise drive I turn on but never work some body can helpme with this issue,
  18. Sep 13, 2008 at 2:46 AM
    #98
    04asphalt
    04asphalt Well-Known Member
    PreRunner
    says I already voted??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????:eek:
  19. Sep 13, 2008 at 2:48 AM
    #99
    04asphalt
    PreRunner
    driveline vibration defect under acceleration!:mad:
    all other defects are minor
  20. Sep 13, 2008 at 5:16 AM
    #100
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    2008
    V6
    4WD
    Access Cab
    TRD
    None
    I have 7,000 miles on it now and am very happy with it.
