Defects or Issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 007Tacoma, Apr 29, 2007.
What kind of issues/defects are you having with your Tacoma?
  1. Electrical Issues (wiring, lighting, gauges, starting, battery, etc...)
    10.1%
  2. Strange Noises (clunking, whirring, popping, etc...)
    23.1%
  3. Wind Noise (excessive wind noise in the cab at any speed)
    14.1%
  4. Vibrations during Acceleration
    13.3%
  5. Vibrations during Cruising
    10.2%
  6. Vibrations during Deceleration
    7.7%
  7. Lunging or Jumping in RPMs
    14.0%
  8. Other issues (please describe in your post)
    11.6%
  9. None (I am blessed)
    34.7%
  1. Sep 13, 2008 at 1:18 PM
    #101
    poleman72
    poleman72 Well-Known Member
    Virginia
    02 Prerunner
    hmmm, from all the replies it seems that this truck is not a good buy.
  2. Sep 13, 2008 at 1:19 PM
    #102
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    no. not at all. any truck is going to have some sort of little thing. but toyota is the best in quality as far as im concerned
  3. Nov 6, 2008 at 9:23 AM
    #103
    flyjbaker
    flyjbaker Well-Known Member
    2009/4L Auto/DC/LB/4x4
    Engine noise under acceleration. Almost sounds like an exhauset leak. Sounds horrible actually. Let y'all know as it progresses and what the dealer does if I take it in. I will let it break in a little more before I complain(only 350 miles on it)
  4. Nov 6, 2008 at 11:13 AM
    #104
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    05 TRD off Road, double cab.
    The only issue I have had in the front fender wells, the drivers side doen't line up well, and those push pins keep falling out. I have replace them 4 times since 05. But HA I fix them up now!!
    Other than that, (which is meaningless) no issues and would buy another.
  5. Nov 6, 2008 at 12:50 PM
    #105
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    17 trdor dcsb 6mt
    MY05
    V6
    6spd
    access cab
    airbag light is on, checked seat connections and dash switch, reset computer by disconnecting the battery for 5 hours. Haven't had the cash to get it investigated
  6. Nov 6, 2008 at 2:23 PM
    #106
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    2008 V6 Manual Access Cab TRD Sport
    Almost have 8000 miles on it now, only real thing i could complain about is I wish the brakes were a little better. 4 wheel disc would have been nice.
  7. Nov 6, 2008 at 6:00 PM
    #107
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    2008
    V6
    4WD
    DC S/B
    SR5 4x4
    Color-Desert Sand
    Purchased 9/2008
    The clear coat paint on the hood had several blemishes. It appears that when it was applied, grit got in the final coat before it dried. Barely noticeable, but I see it. The dealer tried wet sanding to no avail. I am mneeting with the District Factory rep tomorrow at 1100 hours. I'm hoping for a repaint of the hood...
  8. Nov 7, 2008 at 1:02 PM
    #108
    JustinDA4
    JustinDA4 Member
    Baton Rouge
    07 Double cab-SB PreRunner V6
    1) 2007
    2) V6
    3) 2WD
    4) DoubleCab - SB
    5) PreRunner
    6) Black sand pearl
    I Freakin love my truck!!..........The only thing that I have noticed is that the tire pressure light comes on a good bit. I have checked all tires except the spare tire. I have a felling this is the problem. Is there any way to reset the tire pressure light without having to put air in the spare tire all the time?:confused:
  9. Nov 7, 2008 at 1:47 PM
    #109
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    1)05/2008
    2)V6/6psd
    3)4WD TRD Off Road #2 Locker
    4)Access Cab
    5)TRD Off Road #2
    6) Water leak since new Toyota tried to fix three times. Now working with National Center for Dispute Settlement, have arbitration hearing on 11/18/08. Asked for new Tacoma with same options & color.
    I'm waiting to get outcome.
    I will need to get very loose visor clips fixed and window sweek.
  10. Nov 7, 2008 at 2:13 PM
    #110
    Mr.Ed
    Wilbur's Barn
    First Tacoma
    08/15/99
    1999 TRD Off Road, Locker, TRD 15" X 10" wheels
    V6/5SPD
    Extra cab
    Nine years, 222,115 miles not one problem. Two sets of front breaks original disks, original rear shoes just cleaned. Original clutch and the most unreal part all the original blubs! The truck had all service work done at Toyota of Libertyville. Just had third set of tires put on before it was sold. Blower motor made small noise and seat belt was warn. Also had to replace MAS blub two times. One AC recharge. City/HWY combo MPG 20.5.
    BEST AUTO I EVER OWNED!!!:D
  11. Nov 7, 2008 at 2:53 PM
    #111
    Mr.Ed
    Wilbur's Barn
    Call Toyota start a case if they can't fix it you have a clame. Get the paper work and send it in. Toyota stands behind there autos. Just so you know, the reason I have a new one they gave me $14,115.00 buy back for my 1999 with 222,000 miles. Frame rust.:)
  12. Nov 7, 2008 at 3:51 PM
    #112
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    1) 07
    2) V6
    3) 4x4 w/rear locker
    4) Access Cab, long box
    5) TRD Suspension
    6) Loan payments still.
  13. Nov 7, 2008 at 4:18 PM
    #113
    grivera
    Hanover, MD
    I met with the rep this morning; he said it "railroad debris" (WF?)
    Toyota is going to repaint my hood.
  14. Nov 7, 2008 at 8:41 PM
    #114
    wawireguy
    wawireguy Well-Known Member
    08 4cly Access Cab 4x4 Manual
    -1st gear is to steep, concerned with clutch failure
    -2nd is to high when going into a stop light at slowing down then having to acclerate if it turns
    -5th gear is only usuable over 70mpg, geared really high
    -While acclerating it sounds like there is a exhaust leak
    -AC makes loud noise when starting sometimes
    -shifting makes noises, minor but doesn't sound nice and smooth like I'd expect
    Better than a Dodge for sure. Better than a Ford, they suck and break a lot. Better than a Chevy.. ???
  15. Nov 7, 2008 at 9:01 PM
    #115
    replica9000
    2019 T4R ORP
    Well I was a GM guy and the Tacoma pulled me away from getting the S-10 ZR2 I always wanted...
  16. Nov 7, 2008 at 9:17 PM
    #116
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Thank God.
  17. Nov 7, 2008 at 10:29 PM
    #117
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    1) Year or Build Date of your Tacoma
    08/Cali Plant
    2) Engine (V6 or 4Cyl)
    4.0
    3) Drive Line (2WD, 4WD, and whether or not you have Traction Control or a Locker/LSD)
    2WD, e-locker
    4) Body Configuration (AccessCab/DoubleCab and Longbed/Shortbed)
    Access Cab
    5) Suspension (TRD, PreRunner, or Stock)
    TRD Pre-runner
    6) Discribe your issue/defect as best you can if you have any.
    a) Vibration at most speeds. Have had the Rugged Trails replaced under warrenty, put the credit toward BFG All Terrain KO's. Issue improved but still there.
    b) Vibration on acceleration (as seen by other members, I believe it might be slop in the carrier bearing).
    c) Passenger suicide door vibrating on bumps. I finally identified where it's coming from yesterday. The door has slop when closed, and on bumps/washboard/ect (even some tarmac bumps) it rattles. So so annoying, going to call Toyota service for some warrenty work on monday.
    That's really it... mostly just annoyances but.. still stuff that drives me up the wall. I'd still have traded and did it all over again though.
  18. Nov 10, 2008 at 5:08 PM
    #118
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    1) 2008
    2) Engine 4Cyl
    3) Drive Line 4WD
    4)Body Configuration AccessCab
    5) Suspension Stock
    6) Discribe your issue/defect none!!:D
  19. Nov 10, 2008 at 5:37 PM
    #119
    Steve762us
    Steve762us Well-Known Member
    Nah...you're seeing a lot of first time truck owners, probably with no more than a few years of driving experience under their belts, who are still thinking "car", while driving a truck; that, and factor in the reality that people with a proclivity to whining are more likely to post than the norm.
    "Railroad debris" was probably the agent's way of describing damage incurred during rail transport, when the vehicles were moved from ports of arrival (or even cross country from Fremont) to regional distribution points, and thence to dealerships.
  20. Nov 10, 2008 at 6:45 PM
    #120
    flyjbaker
    RR debris is very common to cars.....and is cleared up with a clay bar!
