Degrees for TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muskwa, Nov 15, 2012.
  1. Nov 15, 2012 at 5:07 PM
    Muskwa
    Muskwa [OP] I don't roll on Saturday
    Carl
    In a van down by the river
    08 DC SB SR5 TRD OFF ROAD
    I searched the forum and found conflicting answers in the amount of degrees needed for TPMS sensors for steel wheels and alloy wheels.
    (20 degrees for steel wheels & 40 degrees for alloy....?)
    Does anyone know what the correct answer is?
    Thanks guys.
  2. Nov 15, 2012 at 5:34 PM
    JCBigler
    JCBigler Well-Known Member
    Chouteau, OK
    Silver 2010 4WD, SR5, DC, TRD OR w/tow
    stock, Yaesu FT-8800R with a Maldol EX-107B, rear breather mod
    I'm not actually sure what you are talking about. But I have found that when the weather turns cold, that my TPMS sensor will usually go off and I have to put a couple extra pounds of air into my tires. So maybe when the temperature goes down a few degrees, then the TPMS sensor sees it as a loss of air?
  3. Nov 15, 2012 at 5:45 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    I believe the OP is talking about the sensor its self. And the degree at which it sits in on the wheel. :eek:
    OP: I believe you are correct in that the steel wheel sensors are 20 and the alloy sensors are 40.
  4. Nov 15, 2012 at 6:46 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yup steelies are 20 and alloys are 40.
