Delayed Oil Filter Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JBry562, Sep 1, 2022.
  1. Sep 1, 2022 at 8:45 PM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    This one works great. Use it on my 4Runner oil changes.
    geo8866 and Shellshock[QUOTED] like this.
  2. Sep 1, 2022 at 8:54 PM
    MGMDesertTaco
    @Jesse46
    Last time I used an extension with the motive wrench I stripped the extension hole. :annoyed: Switched to using a socket and 1/2 ratchet to break the canister loose and haven't had any issues since. :fingerscrossed:
    Jesse46 likes this.
  3. Sep 1, 2022 at 9:44 PM
    saint277
    saint277 Vigilo Confido
    oh thanks, thats helpful.
    44-16 Taco and Chew like this.
  4. Sep 1, 2022 at 9:46 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    No problem, if that doesn't work get a first gen.
    69 Jim, 0xDEADBEEF and AxisCab like this.
  5. Sep 1, 2022 at 11:03 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    In this case, a free oil change was not worth the price.
    69 Jim and AxisCab like this.
  6. Sep 2, 2022 at 7:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    The older one with the slots reported from dealers cracked many of those housings, and caused them to leak, the newer version doesn't, and works very well. I was told this right from a rep at motvix.
  7. Sep 2, 2022 at 7:56 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I assumed it (the screwdriver) was in reference to the do-fus who over tightened?
    jneutron likes this.
  8. Sep 2, 2022 at 7:58 AM
    jneutron
    jneutron Well-Known Member
    Colorado
    2022 ORDCSB Cemint RIP-15 DCSB TRD MGM
    MGMDesertTaco[QUOTED] likes this.
  9. Sep 2, 2022 at 8:01 AM
    LunarTeal
    LunarTeal Rarely interested....
    I think you're fine - get it when you can as soon as you can.
    Personally - I run synthetics and consider the filter change to be a bit more important to me than necessarily hitting a specific miles on the oil. For context - I've worked with and at some of the largest trucking/transportation companies in the world. Our engineers worked directly with petroleum engineers and OEMs. Oil tends to get dirty before it "wears out" so I want my filter always working and available to get the dirt first and foremost. So in an EGR engine that dumps soot into the oil pretty heavy - we'd go 75k miles on an OCI (With data that said we'd probably be okay to 125k) so long as we were replacing filters on a 25-35k cadence. Vastly different volume/systems than the 3.5 of course but the 3.5 puts a lot less demand on the oil too.
    For me - I go 5-6k on oil but always make sure I find the best filter I can, especially when it comes to efficiency.
  10. Sep 2, 2022 at 8:02 AM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    How in the absolute fuck do you strip the socket hole out? Never in my life have I heard of anyone accomplishing that. It can’t move once it’s in there and it’s just one size :rofl:
  11. Sep 2, 2022 at 8:13 AM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Those oil filter caps are only supposed to be torqued to 18 ft. lbs. and the filter drain plug 10 ft. lbs. Basically hand tight, never use the wrench to tighten it unless its a torque wrench. Even with it hand tight the caps can still be a bear to get off because of the heating and cooling cycles.
    eurowner likes this.
  12. Sep 2, 2022 at 8:26 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Would not surprise me if a large percentage of the dealers skip the filter change.
    zoo truck, AxisCab and Turd Ferguson like this.
  13. Sep 2, 2022 at 8:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    ahh yes, the obligatory gen 2 troll. Things are so good in their world, they can't help but to share their enthusiasm, in hopes of changing other's minds.
    JmsWms likes this.
  14. Sep 2, 2022 at 9:56 AM
    MGMDesertTaco
    When it's 100 plus degrees outside in AZ metal is soft. Also, the filter cartridge was over torqued. :benchpress:
  15. Sep 2, 2022 at 10:18 AM
    #35
    eurowner
    eurowner Duke Sky
    Scoty
    There is a crapload of seal drag on these canisters. It was not "over-torqued".
    Use a 1/2" breaker bar that is at least 20" or longer, get the correct canister "wrench" and slowly with torque turn the bar counterclockwise; proper tecnique needed.
    Using a 3/8" wrench doesn't play well neither does going fast.
    Vlady likes this.
  16. Sep 2, 2022 at 10:23 AM
    #36
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it does if you have a 2.7
    AxisCab likes this.
  17. Sep 2, 2022 at 1:04 PM
    #37
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Why is that kid constipated?
  18. Sep 2, 2022 at 1:08 PM
    #38
    Sungod
    Sungod Well-Known Member
    St Augustine
    Expert? You mean it is on the internet so it has to be real, right?
  19. Sep 2, 2022 at 1:18 PM
    #39
    WCTRDTaco
    WCTRDTaco Well-Known Member
    2018 Tacoma TRD Off-Road 4X4
    So quick with a smart ass answer, so slow to learn who the guy is. Bugger off Timmy.
  20. Sep 2, 2022 at 1:21 PM
    #40
    saint277
    Hes a man taking apart a neglected 2.7, not sure what it has to do with the topic at hand.
