Delete
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ace7196, Jan 11, 2018.
  1. Jan 11, 2018 at 7:50 PM
    ace7196
    ace7196 [OP] Member
    Delete
    Volksparts likes this.
  2. Jan 11, 2018 at 7:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Could you maybe take a small generator camping instead?
    Rotekk and Dhannah like this.
  3. Jan 11, 2018 at 7:55 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    They sell battery low voltage disconnects. We use em in our work trucks for lights and radios.
    Shuts everything off when battery drops below a certain voltage so you can still start the vehicle
    Rotekk, Drunken Chewbacca and Dhannah like this.
  4. Jan 11, 2018 at 7:57 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    stealthmode and shakerhood like this.
  5. Jan 11, 2018 at 7:58 PM
    Radarninja
    Northern California
    06 taco
  6. Jan 11, 2018 at 8:02 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I think you could install a battery box in the bed and use the wiring from the tow wiring to charge it. My RV trailer has dual deep cell batteries that get charged when I'm towing. If the 3rd gen is like the 2nd it's won't matter if you have the tow kit. The wiring was/is factory installed while the tow kit is port installed. A motorcycle battery would probably fit in the cubby in the bed pretty easy to keep the wiring close.
    Edit - When the ignition is off you are isolated from the main battery
    ace7196[OP] likes this.
  7. Jan 11, 2018 at 8:04 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Check galls.com for the battery cut off.should be cheaper.
  8. Jan 11, 2018 at 8:04 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
  9. Jan 11, 2018 at 8:04 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Depends where you shop. Ebay for welding cable, Walmart or eBay for a battery box, and shop around(not the big fancy Overland dual battery kits) for an automatic charge relay.
    A 2nd battery will run your accessories a lot longer than a battery low voltage cut off. A duralast gold 27f has a reserve of 165min(cant find amp/hour rating), a Northstar 27f has a reserve of 195min (92ah), but those capacities are until they are fully discharged. Think how long it would take for you to reach the 11.7 volt cut off.
    ksj and ace7196[QUOTED][OP] like this.
  10. Jan 11, 2018 at 8:06 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Better price point for OPs usage.
    The only downfall being runtime. Think how long it would take for you to reach the 10 volt cut off.
  11. Jan 11, 2018 at 8:07 PM
    YamaDirtrider
    Josh
    Elizabeth CO
  12. Jan 11, 2018 at 8:15 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    You can get the 7blade plug as a replacement end and make you own wires into the cubby
    ksj likes this.
  13. Jan 11, 2018 at 8:16 PM
    ksj
    Pacific NW
    265/70-17 KO2
    etrailer.com or the like should have something. As I remember there is a connector down there you can order from Toyota and just cut off the other end. Others have soldered into the existing.
  14. Jan 11, 2018 at 8:21 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    https://www.amazon.com/dp/B001EOWPOA/ref=cm_sw_r_cp_api_cDdwAbTF5WK7J
    Any local auto part store should have this on the shelf. Just add the leingth of wire you need to make it to the cubby. This way you don’t have to cut up any factory wiring.
  15. Jan 11, 2018 at 8:43 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    No, this plugs in like a normal trailer wound. I’m assuming you wound not want this plugged in all the time. So you could roll up the wire and store it all in the cubby till you need it and just plug it in.
    If you want to plug it all in behind the bumper you’d proably have to get the specific plug from a dealer. It wound be replacing the bumper plug. And wound not allow the plug in bumper to work until you switch the plugs. Coins be costly depending on what dealer cost is
    Alternative wound be to tap into or solder in on the wire before the plug at bumper and run wire over. Just needs to make sure it well taped/sealed up so it dosent corrode.
  16. Jan 11, 2018 at 9:07 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    [QUOTE="...Edit - When the ignition is off you are isolated from the main battery[/QUOTE]
    Good conversation OP, thanks for your post! It sounds like a great idea to use a harness plug as a temporary power source for charging an auxiliary battery in the bed- but I wanted verification on this- when the ignition is off, all power is cut off at the trailer harness? I was told by a trailer salesman that the truck battery could still be drained if the trailer was connected. Misinformation, or maybe only true for domestic trucks? Anyways, thanks for helping me with my power project!
  17. Jan 11, 2018 at 9:09 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
  18. Jan 11, 2018 at 9:19 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Buy an aftermarket jumper battery that charges from accessory port.
    Jaque8 and IronPeak like this.
  19. Jan 11, 2018 at 9:34 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Get devices (fan, led lights) with USB power supplies and use a backup battery power supply, a 20k MaH will run lights and a small fan through the evening and charge your phone too. I have the Anker 20100 MaH, as well as a 8k that doubles as a jumper pack and these work great.
    This string is 40ft long and ran all night with most of the battery life left.
    https://www.amazon.com/dp/B06XWPSCQ...2W&pd_rd_r=WS41NCF379RAZHRH0S5Y&pd_rd_w=vWqc7
    Fan
    https://www.amazon.com/dp/B075278Y3...Uw&pd_rd_r=WNVY2AHT05X5PH17YHB1&pd_rd_w=gsua1
    ksj likes this.
  20. Jan 11, 2018 at 9:43 PM
    ksj
    Pacific NW
    265/70-17 KO2
    These are also awesome for daytime charging of battery and accessories with the appropriate controller.
