Demello Slider install questions...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Jul 2, 2009.
  1. Jul 2, 2009 at 7:25 PM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    So I stopped by Tractor Supply after work tonight and picked up some clevis shackles for the new bumper, which is coming in a few weeks from now, after a really LONG day at work. I got home and saw the Demello sliders waiting for me by the garage door so as any mod addict would do, I came in, changed clothes and began the install.
    There were no instructions but things seemed pretty straight forward. I must say that I am beat and barely have one side installed after about 3 hours. :rolleyes:
    I finally got the front bolt and washer installed on the drivers side (how the heck is anyone supposed to reach that?) I thought about snaking the bolt in from the inside and installing it backwards, but I just couldn't bring myself to do it. After about an hour I got the front bolt, nut, washers installed. I did manage to drop a ratchet wrench into a little tiny channel inside of the frame rail, and for the life of me, I cannot get it out.
    Since it was getting late I decided to attempt to drill the holes in the bottom to install the remaining bolts and finish the one side tonight... well, after about 15 minutes of drilling I made my way through the frame rail, but the hole in the back (by the gas tank) has 2 separate materials of steel and I could NOT get through the second material with my drill. What type of drill bit or end mill is everyone using to get through that steel?
    I figure I'd come in, rest up and attempt the other side in the morning, but doing this solo is tough.
  2. Jul 2, 2009 at 7:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    weld on FTW!!!
  3. Jul 2, 2009 at 8:14 PM
    salsataco
    salsataco Well-Known Member
    Cobalt bitset, some wd40 and a drill doctor to sharpen the bit as it gets dull. Makes the frame seem like butter.
  4. Jul 2, 2009 at 8:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    x2..
    x2.5
  5. Jul 3, 2009 at 12:34 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Any good drill bit will be dulled by the metal and the heat. Get some cutting oil and spray it in the hole every 30sec or so.
  6. Jul 3, 2009 at 3:53 AM
    DrRabbitFurHead
    Salem, VA
    OK, so later this morning I'll stop and get some cutting oil and a couple of 1/2" cobalt bits. My cobalt set only goes up to 3/8" so I used a black oxide steel bit (dry) and that wasn't the way to do it. I wouldn't mind welding it on, but I don't know anyone with a welder and just dropped $420 at the body shop for 'fixing' my cab mounts. I can't imagine what they'd charge to weld it up.
  7. Jul 3, 2009 at 6:36 AM
    The_Hodge
    SC
    i only paid like $100-125 on two seperate occasions getting sliders welded on. its not that much weldng
  8. Jul 3, 2009 at 7:19 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I like welded, but thats me.
  9. Jul 4, 2009 at 4:44 AM
    DrRabbitFurHead
    Salem, VA
    OK, so I blew $18 on a 1/2" carbide drill bit and completed 5 of the 6 required holes before the bit became toast. I also went through a bunch of wd-40 for coolant as the big box store didn't sell cutting fluid. It looks like I'll have to drop another $18 for the last hole.
    Is everyone SURE that if I'm running 6 or 7, 1/2" bolts per side that I'll be able to safely use the sliders for a jack recovery point if needed? They sure seem stout as snot after drilling the holes and using the hardware, but welding could still be an option if someone has experience that the bolting doesn't work. Also, my 9 year old daughter was able to take her skinny hand and arm and reach up and recover my ratchet wrench! I owe her $1... should that count toward my mod total? :)
  10. Jul 4, 2009 at 6:13 AM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
    tensile strength on those bolts is 21,300lbs.
    http://dodgeram.org/tech/specs/bolts/SAE_bolt_strength.html
    i used a "nitro bit" (not as good as Cobalt) and some cutting fluid when i installed mine. all six holes with one bit, that is still sharp. the trick is to let the bit do the work. don't push as hard as you can, and you don't need to spin the bit as fast as the drill will go. heat is what destroys the bit. the cutting edge gets hot, then loses it's temper, then becomes dull. i also used a 3/8" bit for a pilot hole, using a transfer punch to get it centered.
    which sliders did you get? std. roundtube? hybrid? rock crushers?
  11. Jul 4, 2009 at 6:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. This counts tward the install. ;)
  12. Jul 4, 2009 at 6:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1...Mine are solidly metal gobbed on there. I love 'em!! and yes...the dollar is without a doubt "install cost"
  13. Jul 4, 2009 at 6:34 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
  14. Jul 4, 2009 at 6:55 AM
    DrRabbitFurHead
    Salem, VA
