DeMello Sliders (Rust)
Discussion in 'Technical Chat' started by testedone, Jun 7, 2011.
  1. Jun 7, 2011 at 10:25 AM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Anyone have this problem with their sliders?
    I had them painted and rhino lined but it looks like it's just road debris doing this based on the area affected... It's only the forward facing side..
  2. Jun 7, 2011 at 10:33 AM
    bskin
    bskin Well-Known Member
    Eagle River AK
    2016 DC TRD Off Road MT
    I have the same sliders and the same exact issue, I asked Demello and they said just hit them with a rattle can
  3. Jun 7, 2011 at 10:35 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    If they aren't properly prepped before coating them you will have these problems.
  4. Jun 7, 2011 at 10:39 AM
    testedone
    Rick
    U.S.A.
    I had mine powder coated by a local shop than a few months later the rhino over the powder coating..
    I think this is design flaw because so much of the bar extends downward and catches road debris and rocks as you drive
  5. Jun 7, 2011 at 10:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would agree with Paintdiddy and say your powder coater did a crappy job on the prep. I've got powder coated hardware and mounting brackets for my side steps on my 2007 and they now look about as bad as your 2010. They're basically 1/8 or 1/4" plate steel on edge so there's a large forward facing area catching road salt and dirt. If the powder coating wasn't applied propery, the rhino liner wouldn't have been effective either...
  6. Jun 7, 2011 at 10:47 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Road debris will chip paint/powdercoat. I can't really call it a design flaw- They are bars of metal made to protect the truck from objects on the ground/sides of the truck- OF COURSE they are going to stick out/down.
    Just use some emory/machine cloth or some sandpaper to clean it up and then rattle can it.
  7. Jun 7, 2011 at 10:48 AM
    bskin
    Eagle River AK
    Mine were sent powdercoated from Demello, they do catch a lot of debris which is good and bad, I figured I would just sand them down hit them with some primer and flat black spray paint.
  8. Jun 7, 2011 at 10:50 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It comes with the territory. All of the metalwork on my truck needs to be hit with sandpaper and spraypaint at least 2-3 times a year to keep the rust at a minimum.
    It's just like running uniball UCAs. They add to the capabilities of the truck, but also to the maintenance.
  9. Jun 7, 2011 at 10:53 AM
    testedone
    Rick
    U.S.A.
    so you say you agree, but yet yours are the same????
    Mine have been on there for 1.5 years I live in IL where we use salt for everything...
    I have seen other sliders here in IL that they have a higher angle (they hug the body a little better) that still look better than these..
    yeah...don't want to say design flaw..bad choice of words..just that I have seen others (mostly round tube) that don't experience.
    posting just to see if I was the only one, not to bash the product..
  10. Jun 7, 2011 at 2:14 PM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    I have seen round tube PC sliders do the same in less than 3 months. My round tube sliders still look new. A little pricey but, I base coated mine with POR-15 and top coated single stage spray paint.
    Pap
  11. Jun 7, 2011 at 2:56 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    As others have said its unavoidible. You can sand/prep/paint it with whatever you want the paint (even plasti-dip or everlube) will not hold up over time to debris. Maybe you could cover the supports with something solid?
  12. Jun 8, 2011 at 9:36 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    No mudflaps?
  13. Jun 8, 2011 at 11:47 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    if u put one up front it would help if u have a metal shop put a plate along the bottom and top it would stop for sure, or just bottom and put a 1/2 in hole in each gap as a drain it would stop
  14. Jun 9, 2011 at 6:25 AM
    testedone
    Rick
    U.S.A.
    yes I have mud flaps...
  15. Jun 9, 2011 at 6:30 AM
    paintdiddy
    shithead
    silver bullet
    I'm calling bullshit.why do you have to paint it when it never leaves the jack stands? :D
  16. Jun 15, 2011 at 10:19 AM
    JDEMELLO
    JDEMELLO Well-Known Member Vendor
    Corona Ca
    none
    Unfortunately anything you spray on there will sooner or later wear off. Over the years I have had everything powder coated on my truck and end up usually spray over it after a trip or two off-road. Bottom line is the sliders are in direct line from tires spraying everything from road salt to gravel.
    Spray paint wears off the fastest, powder coating last a little longer and I believe line-x last the longest but it also peels off if you use the sliders as sliders.
    Bottom line is anything mounted down there that are intended for trail use will rust over time.
    Yes the worse the prep is the faster it will wear off. Our powder coater sand blast and sprays the powder coating with a 7mil or thicker coating. We actually just changed our P/C again and they not only sand blast but chemical treat them as well.
