Denso plugs: Which one is best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by User Name01, Jul 5, 2014.
  1. Jul 5, 2014 at 6:36 PM
    User Name01
    User Name01 [OP] Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
  2. Jul 5, 2014 at 7:42 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Stick with what came on the truck regular denso plugs... Just changed mine today...
  3. Jul 5, 2014 at 7:46 PM
    Madcat207
    Madcat207 Well-Known Member
    FL
    08 Double Cab Long Bed Sport
    Curious.. why would you advise to use an inferior product? From all my reading, the iridium last a stupid long time, and they should spark just like anything else... so.......?
  4. Jul 5, 2014 at 9:54 PM
    User Name01
    Bolbi Stroganovsky
    What I was thinking. Iridium is better, according to everything that I have read on here. I just don't know which ones.
  5. Jul 6, 2014 at 9:18 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I don't think that you can go wrong with the Iridiums.... 100K and stock for most Toyota products. I'd check ebay and www.rockauto.com though, your price may be a bit high.
  6. Jul 6, 2014 at 11:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Toyota designed the engine to run with the standard copper core plugs.... use them. They actually produce a better spark than iridiums as there is much more of a sharp edge than the small iridium center electrode.
  7. Jul 6, 2014 at 4:12 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    When I change my plugs I am going with the NGK Iridium plugs. When working on motorcycles(rice burners), NGK was the better plug and Denso was second choice. But that is just my opinion.
  8. Jul 6, 2014 at 4:21 PM
    nd4spdbh
    SoCal
    its funny on the plugs that come in the 3.4L 5VZ-FE in the 1st gen taco, they are as every other yota motor split NGK / DENSO ... and for those style of plugs (dual ground center electrode) the NGK's showed MUCH less wear on them time and time again compared to the denso's
    But its seemes to be just the opposite with the 4.0L 1GR-FE, the densos wear much better than the NGK's
    Id vote pull a plug from either side and see which one looks better and go with that brand.
  9. Jul 6, 2014 at 7:21 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    Everything I have read says to use the same plugs ( denso replacements). They were great for the time I ran them..so why switch ?
  10. Jul 6, 2014 at 10:17 PM
    mesohungry
    mesohungry Active Member
    southern cali
    2010 DC TRD Sport LB
    Denso's looked in much better shape than the NGK's when I removed them today, just bought the truck, and decided to do a 60k. guess the original owner never changed them.
  11. Jul 6, 2014 at 10:22 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^this
  12. Jul 6, 2014 at 10:49 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    They spark better because copper conducts better. Since copper conducts better it doesn't last as long as iridium.
  13. Jul 7, 2014 at 1:57 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    The standard copper core plugs do not have a copper tip. It is a nickel alloy which is still softer than iridium. A copper tip would be way to soft to be used in a combustion engine it would probably be shot the first time you ran it. Iridium plugs also have a copper core, but it is tipped with iridium. A website with a good description. https://www.sparkplugs.com/glossary/8/spark-plug/N
  14. Jul 8, 2014 at 2:18 PM
    User Name01
    Bolbi Stroganovsky
    I replaced my plugs with the IKH20 plugs. I feel the trck different, a good different. So far the start up is smoother/quicker, i feel a more solid pull at low RPM. Then again, it might all be psychological.
  15. Jul 8, 2014 at 6:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I used the same ones that were in it. The stock plug.
    I haven't updated my ignition and can't see how I'd benefit much from better plugs.
    I plan to change my plugs again in 60k miles.
    It's not that hard to do on these trucks.
  16. Jul 8, 2014 at 9:18 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Its 30k mile intervals.
  17. Jul 8, 2014 at 9:39 PM
    TnShooter
    Deogee
    STOCK
    You are correct. And I personally think this is only to comply with the Emissions Control warranty. I no longer have any warranty, so I'm opting for the 60k intervals. Not saying it is the what anyone else should do. It's just what I'm doing.
  18. Jul 8, 2014 at 9:41 PM
    pinktaco808
    pinktaco808 Hot Steppa
    anyone have a how to on changing the spark plugs? i never changed it on my truck or any car before. I have the 4 cylinder truck single cab. I have the spark plug and most of the tools any help thanks.
  19. Jul 9, 2014 at 6:57 AM
    User Name01
    Bolbi Stroganovsky
  20. Jul 15, 2014 at 12:26 PM
    pinktaco808
    thanks man
